chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Fri Nov 11, 2011 3:26 pm Post subject: Heat in fall, A/C in spring |
Funny to see the cycle of posts.
Query for the crowd, need a second opinion.
Was messing around with van last week. Finally attached new heater hoses to front heater assy and got nothing but cool air. I was down a couple quarts as far as capacity, and was wondering WTF? Rear heater cranks and is blowing hot.
Checked around the valve to make sure it was opening when it was supposed to, and it seems fine.
Controls seem to be working fine, although I realized PO has faceplate velcroed on.
Felt the hoses underneath, and did not get a great reading as the fan kicking on was warming them.
Went inside, felt up the two hoses leading into the core and had one warm, one cool. Am now thinking core is blocked and in need of replacement. But needed to ask a stupid question, these cores dont get vapor/airblocked do they? Its a direct feed from motor, and rear core is getting fluid so must be a clogged core right?
Van was refilled on steep incline, on ramps so I am sure system is bled of the majority of air. Actually have a great new trough in my yard due to 1WD getting bogged in wet grass on the incline. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
Bassyaks Samba Member
Joined: October 06, 2010 Posts: 1137 Location: S.E. Connetitcut
Posted: Fri Nov 11, 2011 5:21 pm Post subject: |
Make sure there's not a cut off valve inline before the heater. |
Posted: Fri Nov 11, 2011 5:40 pm Post subject: |
No additional valves to turn off prior to core. I had thought of installing g one, so I was aware of the lines as I was playing around. Think the fecker is clogged. PO had lines plugged off with dry erase markers. Maybe a clue to its prior history. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Fri Nov 11, 2011 7:00 pm Post subject: |
If you are concerned that the heater core may be plugged, you can check for this by detaching the hoses and blowing through them (mind you don't sip the coolant!)
If there seems to be a blockage, you can isolate the heater core in place by detaching the hoses, drain the coolant, and fill the heater core in place with a product called CLR.
See: http://www.youtube.com/watch?v=dqvDD_L7Y_M
http://www.jelmar.com/CLRbasic.htm
It helps a bit if you heat the CLR in that it works faster. Do not use Drano or any such drain cleaner as they are tool harsh. Repeat the CLR treatment if the first time does not clear it. If all else fails, you are removing the dash and the heater/vent box and replacing the core.
This CLR treatment usually works, but no promises. _________________ '86 Syncro Westy SVX |
