60freak Samba Member
Joined: October 08, 2002 Posts: 861 Location: Indiana
Posted: Mon Nov 18, 2002 5:07 pm Post subject: BRM center caps? |
Anyone know who or where I can find a set of center caps for Flat Four BRM wheels for a BUS, not a bug, I have the bug center caps already, I need "deep dish" style caps to fit on a '60 bus. Many Thnx.-Mark. |
66split Samba Member
Joined: August 19, 2002 Posts: 809 Location: Bham, WA
Posted: Mon Nov 18, 2002 5:12 pm Post subject: BRM center caps? |
the only place i have seen them was on ebay. I think the website is ispwest.com. |
rizzag Now Wut?
Joined: April 19, 2001 Posts: 3116 Location: Keizer, OR
Posted: Mon Nov 18, 2002 5:13 pm Post subject: BRM center caps? |
www.vwispwest.com his ebay name is pimppride |
UZI Platinum FUBU
Joined: February 08, 2002 Posts: 13335 Location: phila-DELFT-ia
Posted: Mon Nov 18, 2002 7:34 pm Post subject: BRM center caps? |
i wouldnt worry about it. i got a set of the machined billet aluminum ones, they still werent deep enough and i thought they looked dumb. too klunky. just leave them off. did you try to fit the BRMs on the rear of your bus yet??? |
Posted: Tue Nov 19, 2002 8:15 am Post subject: BRM center caps? |
Yes, the BRM's are already on the bus, they fit just perfect! There seems to be a lot less road noise in the bus too with them. I've seen the big "clunky" caps, I don't think I want those big 'ol things, was kinda hoping to find ones that are similar to the bug ones I have, but deeper. |
Empicollector Samba Member
Joined: March 02, 2002 Posts: 316 Location: Seattle, WA
Posted: Tue Nov 19, 2002 1:52 pm Post subject: BRM center caps? |
I put BRM`s on my bus about 3 years ago and at the time there wasn`t any extended caps avaible,so I made a set of adapters- extenders--- my self on a Lathe. Used round aluminum stock --Turned one end down to fit cap hole end on wheel--went over 1 inch--bored end to fit cap that came with wheel--polished clear coated installed with caps ---Look Good--Bill |
Posted: Tue Nov 19, 2002 2:17 pm Post subject: BRM center caps? |
Cool, I wish I had a lathe to do that! Now, I wonder if there is any other way to make "extenders" to fit the caps that I have now? Thanks for the input Bill! -Mark. |
Posted: Tue Nov 19, 2002 2:33 pm Post subject: BRM center caps? |
Yes--- Thats what you use --the Caps you have now Bill |
UZI Platinum FUBU
Posted: Tue Nov 19, 2002 3:53 pm Post subject: BRM center caps? |
glad you got them on. some folks have had trouble fitting them because of the offset. |
Posted: Tue Nov 19, 2002 5:00 pm Post subject: BRM center caps? |
yeah I was told that before I put them on. They fit real nice though, about as close as you can get without rubbing the wheelwells. |
EddieWouldGo Samba Member
Joined: July 09, 2008 Posts: 20 Location: Victoria, British Columbia, Canada
Posted: Mon Dec 20, 2010 5:36 pm Post subject: |
California Import Parts carries several center cap's for the BRMs. There's the flush mount one, a deep one, and an in-between one. I just put my 15x5.5 BRMs on my stock '65 (195/65 15 Falken Tires), and the bastards rub. Can anybody tell me if a straight axle conversion will fix this? I'm just waiting on the parts to show up.
Link to the Canadian CIP site...
http://www.cip1.ca/SearchResults.asp?Search=brm&Search1=Search
By the way 60Freak.....Love the avatar. Trailer Park Boys rock!!! |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
KamperKitJay BDM Hit Man
Joined: May 13, 2003 Posts: 404 Location: San Diego CA.
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Wed Dec 22, 2010 7:46 am Post subject: Re: BRM center caps? |
Talk about digging deep for an old thread!
UZI wrote: |
i wouldnt worry about it. ... just leave them off. |
When I first got my BRMs and found out the caps would not fit on the rear, I left them out. However, as soon as I washed the bus I found a major flaw in leaving them out. The BRMs are so "flushed" into the drums that they will hold water between the rim and the drum. So you wash and dry your bus, take it for a spin and find this water splashed all over it. It doesn't all go away at once either and it's a bitch trying to dry it out with a rag.
At the time, there was no availability to ANY type of cap to remedy the situation so I decided to make my own. Wanted to use the original caps so I made a spacer to just clear the rear axle nut. IMO it looks much better than the extremely protruded cap offered for buses today. Also, I like the "even-ness" of using these spacers on all 4 rims rather than just on the back.
_________________ Some people are so busy being clever they don't have time enough to be wise. |
steveo_32 Samba Member
Posted: Wed Dec 22, 2010 9:01 am Post subject: WOw |
Eight year old thread BACK ON TOP BABY!!! |
DannoT Samba Member
Joined: September 15, 2007 Posts: 249 Location: Up where the air is thin
Posted: Mon Jun 10, 2013 8:24 pm Post subject: |
I just picked up a set off repop empi 15x5 brms for my 67, stock height big nut rgb, does any one know if Ill need any type of spacer to fit them? Im also assuming Ill need the deep dish caps for the rear but the gist of this thread sounds like they are a bit of an eyesore, are there any other caps out there that are more elegant and will will fit?
And you can call me Indiana jones cause I just dug up this ancient thread |
DannoT Samba Member
Posted: Tue Jun 11, 2013 11:23 am Post subject: |
Any one have any idea? Homemade cap spacers are fine so long as they dont require a metal lathe. |
pyrOman Fire Master
Posted: Wed Jun 12, 2013 6:35 am Post subject: |
Are your BRMs Flat-4s from Japan?
If so, I do have an extra set already made... just have to find it after my latest move! _________________ Some people are so busy being clever they don't have time enough to be wise. |
