ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Posted: Mon Nov 14, 2011 5:28 pm Post subject: Engine fire cause by... |
.... a faulty fuel pressure regulator.
It broke inside and started spaying from the air nipple, the vacuum hose broke and fuel went onto the distributor cap... igniting the fire.
It's the second time I see that kind of engine fire in my shop.
Just saying, FPR are getting old also.
Ben _________________ Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta
phlogiston Samba Member
Posted: Mon Nov 14, 2011 5:51 pm Post subject: |
a couple years ago, i replaced a regulator that was leaking slowly. it looked like the fuel was seeping out where the 2 pieces of metal are bent together at the rib/flange in the middle. |
goskiracer Samba Member
Joined: January 15, 2009 Posts: 339 Location: Oslo, Norway
Posted: Mon Nov 14, 2011 6:41 pm Post subject: |
^^^ same as above. I also observed a FPR leaking fuel around the rolled seam where the two halves come together. _________________ 86' Syncro 2.2 Vanistan, WBXhaust, ski-pole shifter for +11hp |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Mon Nov 14, 2011 9:01 pm Post subject: |
Happened inside YOUR shop?
yikes.
scary. |
Posted: Mon Nov 14, 2011 9:29 pm Post subject: |
No, it came like that. 2 childes where sitting in the back, luckily the old fire extinguisher worked.
This is a FREE warning, for those of you that can afford a new FPR, do it, for the rest of you, you may just die in you beloved van. That said, some of you guy driving a 25 yo van just don't get it.
My time is precious, when I take time to warned you here take that as a blessing.
Period. _________________ Working with rust, grease, dirt and dust is a sad truth.
Youtube http://www.youtube.com/user/ftp2leta |
Posted: Mon Nov 14, 2011 11:24 pm Post subject: |
OMG, thank you for logging in today...and posting.
now the post for newbs can be...
change fuel lines
change FPR
kamzcab86 Samba Moderator
Posted: Mon Nov 14, 2011 11:50 pm Post subject: |
$120 vs. burned-up priceless funmobile... One more thing added to the growing repair list. _________________ ~Kamz
2016 Golf GTI S
Crankey Samba Member
Posted: Mon Nov 14, 2011 11:55 pm Post subject: |
if one was to R&R the FPR, could it be mounted outside of the engine bay ?
thanks for the heads up on this. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Tue Nov 15, 2011 12:07 am Post subject: |
Thats a great idea. Perhaps relocate it somewhere down by the fuel pump while redoing the fuel lines. Somewhere, I dunno - oh, maybe somewhere that's not directly atop the hot exhaust for instance??
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Timwhy Samba Member
bluefirefly Samba Member
Joined: March 16, 2011 Posts: 438 Location: Calgary, Ab
Posted: Tue Nov 15, 2011 5:36 am Post subject: |
Be sure to get a good one.
I just replace a coolant level sensor and started leaking after 4 days from the connector plug!
Not sure if I want to have the same problem with a FPR!
Do you know a good and trusted brand name? _________________ 86 Syncro Tintop G60
work in progress ...as always! |
reluctantartist Samba Member
Joined: August 13, 2006 Posts: 1927 Location: Bloomington, IN
Posted: Tue Nov 15, 2011 7:00 am Post subject: |
Timwhy, Beck Arnley really is a re-seller. Often times their parts are Bosch or similar brand names. I have one and have had no problems with it. Keep in mind if you find a NOS regulator you will still need to be observant of its functioning. It is still over 20+ years old and anything that contains any variation of rubber in it is suspect for failure. But that said it is less likely to leak than what you have now. Too bad there is not a list somewhere from bosch and other manufacturers of the life span of various parts. I have a 1998 beetle and 2002 volvo and I am starting to wonder if maybe I need to be doing fuel injection R&R on those too. _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
SteelB12 Samba Member
Joined: December 21, 2010 Posts: 591 Location: Central Virginia
Posted: Tue Nov 15, 2011 7:05 am Post subject: |
Looks like they could be made in China. They could still be good I guess, but the $120 Bosch would have a better reputation. _________________ 1987 Westy |
Dant Samba Member
Joined: November 15, 2007 Posts: 126 Location: T County, Ohio
Posted: Tue Nov 15, 2011 7:15 am Post subject: fuel pressure regulator |
I had one of these fail and was filling #2 cylinder with fuel. I thought I had a bad starter, cranked a second and stopped. Just locked it seemed. After installing a new starter with no better results I started taking spark plugs out and cranking. When I got to #2 it cranked and blew the fuel out. Large puddle on the floor! Oh shit! I was very lucky.
This made me wonder about the alcohol in the fuel now. There must be a rubber diaphragm that would be damaged by our fuel?
Anyhow, if you have symtoms that make you think hydrolock, (wtf) maybe it is, only locked with fuel.
Dan _________________ 90 Carat
97 Jetta GLX
87 GL (nobody wanted it)
91 Syncro (Stripped,Plain Jane,fixed vent windows,no tach) also rusty. Hurray for me! |
elsyr Samba Member
Joined: May 06, 2008 Posts: 270 Location: North Florida
Posted: Tue Nov 15, 2011 7:23 am Post subject: |
When I started replacing things on Brunhilde's motor, while we had it out to do the heads, the FPR was one I waivered on, since it was a relatively pricey part to replace and I did not have any reason to believe the one in there was bad. I'm glad, seeing this, that I went ahead and did it. I also really like the idea of moving it to a different location.
Doug _________________ '89 Carat "Brunhilde" |
Posted: Tue Nov 15, 2011 8:20 am Post subject: |
Advance has this for $66
BWD/Intermotor Fuel Pressure Regulator _________________ 1987 Westy |
teej Samba Member
Joined: November 26, 2010 Posts: 897 Location: Seattle
Posted: Tue Nov 15, 2011 9:13 am Post subject: |
kamzcab86 wrote: |
$120 vs. burned-up priceless funmobile... One more thing added to the growing repair list. |
I hear that. I also have to wonder how much the harsh salt/rust conditions in Ben's area, where accelerated rust/rot effects everything metal, plays a role in these failures.
But I will probably add it to the list too. . . _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Tue Nov 15, 2011 9:44 am Post subject: |
Wonder if the flexible cloth vacuum line, which is only pushed on should be secured with a clamps. Ive seen the small lines with mini clamps on them on other makes. Volvo turbo comes to mind.
If the FPR fails internally and starts leaking, the fuel will always go into the intake and not jet over to the distributor and light up. Be careful, like in Dant's experience, and only catch fire if you get a fuel hydro-lock..remove the plugs and spin the engine over with the spark plug wires in the neighborhood of the spark plug holes! |
