debbiej Samba Member
Joined: December 14, 2008 Posts: 1554 Location: las cruces, nm
Posted: Wed Nov 16, 2011 10:26 pm Post subject: GoWesty/Shurflo? |
decided to order the shurflo (I think) faucet from Gowesty. got an email from them that the part might not work. I assume that because it is sold as a eurovan camper faucet, it came up as not for my year westfalia (84)
I've looked, and it seems to be the shurflo faucet that so many on the samba have installed in their westys.
could it be different from the 'other' shurflo faucets? |
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Thu Nov 17, 2011 12:49 am Post subject: |
I did Shurflo mod. The model # is 94-009-10. I drove down to a Marine West store and got both pieces of what madspaniard did in this thread.
The Antenna Deck Mount is just a plastic adapter plate. You could just make one.
One thing is that using the Shurflo you will loose your city water hook up.
The Delta Six is the way to go if you want city water hook up. _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
kamzcab86 Samba Moderator
Posted: Thu Nov 17, 2011 1:07 am Post subject: |
Cripes... GW emailed me a "warning" as well that there was a conflict and I emailed them back with the following:
a) a link to TheSamba thread about the Shurflo being installed in Vanagons;
b) a link to the antenna base required;
c) a followup message with the attached photo and told them that they ought to get the antenna bases and sell them and the faucets as a package for Vanagon owners:
GW is selling the OEM Delta6 faucet, so that'd be a conflict of interest... I presume.
But... after my email (and maybe others'?), you'd think they would've taken that automated "part conflict" message out of their system. _________________ ~Kamz
2016 Golf GTI S
Posted: Thu Nov 17, 2011 6:50 am Post subject: |
thanks, I will go ahead with the order. so no wiring differences? I'm easily confused by wiring diagrams. I don't use the city (pressure) hookup, so no problem there. I just wanted to make sure it was the same faucet folks were using in the previous threads about the shurflo. I don't think go westy sells the delta 6 though. I'd debated back and forth about the two. |
GBA 88West LA Samba Member
Joined: September 04, 2008 Posts: 1279 Location: New Hampshire
Posted: Thu Nov 17, 2011 10:24 am Post subject: |
is the one GW sells the same model refernced above that is proven to work _________________ 88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th..solar powered cabin |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Thu Nov 17, 2011 10:40 am Post subject: |
The Shurflo has 2 wires, comes in bright white most commonly but a light grey with black trim is around too. The grey looks better in a grey interior Westy. Not sure which GoWesty is selling but their photo looks like the bright white one. There are some other odd color scheme versions.
It is a common part carried by boat stores and some RV places. You can save some money if you look around online.
Mark
debbiej wrote: |
Posted: Thu Nov 17, 2011 12:47 pm Post subject: |
GBA 88West LA wrote: |
is the one GW sells the same model refernced above that is proven to work |
If you're referring to the Shurflo, yes. And it works like a dream.
crazyvwvanman wrote: |
It is a common part carried by boat stores and some RV places. You can save some money if you look around online. |
GW sells only the white version; looks just dandy with the gray interior, IMHO. And, yes, no wiring differences.
Not to take business away from GW, but the Shurflo (no matter the color) can indeed be found cheaper elsewhere. The only reason I bought it at GW is I was pressed for time and knew GW would get the faucet to me before leaving on a trip (as opposed to my local West Marine that didn't have it in stock and wanted to charge me an extra $25 to get it to their store before their usual Thursday deliveries). _________________ ~Kamz
2016 Golf GTI S
Franklinstower Samba Member
Posted: Thu Nov 17, 2011 1:09 pm Post subject: |
my complaint with the Delta 6 stock faucet is flow. It is too fast with no control. Does the Shurflo regulate the water flow better? _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
Posted: Thu Nov 17, 2011 1:32 pm Post subject: |
Franklinstower wrote: |
my complaint with the Delta 6 stock faucet is flow. It is too fast with no control. Does the Shurflo regulate the water flow better? |
No comparison... one has no control, the other has glorious control. If you don't mind the lack of city water, it's worth swapping. I thought I'd be lost without city water, but after installing the Shurflo I haven't looked back. I'm now looking to remove the connection as a whole and do the popular exhaust fan mod with the hook-up. _________________ ~Kamz
2016 Golf GTI S
markz2004 Samba Member
Joined: November 13, 2007 Posts: 944 Location: Portland, OR
Posted: Thu Nov 17, 2011 1:37 pm Post subject: |
When comparing the two, shurflo makes the delta 6 faucet look silly and outdated. It makes the sink useful again. _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
izzydog Samba Member
Posted: Thu Nov 17, 2011 2:51 pm Post subject: |
What I like about my Shurflo mod is the same thing I like as my Vitrifrigo fridge mod: I TURN IT ON AND IT WORKS! AMAZING! |
Posted: Sat Nov 19, 2011 7:23 pm Post subject: |
I am so happy! pump and faucet work!! a lot of the wires to my pump were cut and gone, and I'd never had an electric faucet that worked. I spoke to go westy on friday so I had a basic idea of the 'circut'.
it didn't work at first, so relieved to find a wire had pulled loose. the flow control is amazing, and the way it swivels....
I LOVE IT!! thanks all! |
madspaniard Samba Member
Posted: Mon Nov 21, 2011 2:46 pm Post subject: |
kamzcab86 wrote: |
well, they listened, here is their solution, just came out
http://www.gowesty.com/ec_view_details.php?id=23537&category_id=253&category_parent_id= _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Mon Nov 21, 2011 3:25 pm Post subject: |
madspaniard wrote: |
well, they listened, here is their solution, just came out |
And you don't don't any props at all?? _________________
TheAndante wrote: |
70 KG Coup
Posted: Mon Nov 21, 2011 5:57 pm Post subject: |
kamzcab86 wrote: |
http://www.gowesty.com/ec_view_details.php?id=23537&category_id=253&category_parent_id= |
Huh! How 'bout that?!
Now, GW, where's my commission?! _________________ ~Kamz
2016 Golf GTI S
Posted: Mon Nov 21, 2011 11:10 pm Post subject: |
70coupyel wrote: |
And you don't don't any props at all?? |
it makes me more happy to know people on The Samba found my idea useful for their Westys! I have taken many ideas from others here so giving something back just feels good _________________ 1991 Westy auto w/ Peloquin TBD
Posted: Mon Nov 21, 2011 11:27 pm Post subject: |
it makes me more happy to know people on The Samba found my idea useful for their Westys! I have taken many ideas from others here so giving something back just feels good |
Indeed... and you know, I applaud GW for stepping up to the plate, but IMHO, the modified antenna base looks better, like it's all one unit. So, I thank you for discovering that little gem. _________________ ~Kamz
2016 Golf GTI S
Posted: Tue Nov 22, 2011 1:03 am Post subject: |
SS on SS I think it might leak. Hope you don't have young kids.
I like the plastic base one better. _________________
TheAndante wrote: |
70 KG Coup
Timwhy Samba Member
Posted: Tue Nov 22, 2011 3:42 pm Post subject: |
Hey Shurflo fans,
I used two "door knob guards" from Home Desperate as the base. They are round, white and stiff enough plastic to do the job of holding the faucet in place in the hole in the stainless sink top, which is larger than the base of the Shurflo. You need a way to fill the hole in the sink top and the door guards work really well and are easy to drill out.
My faucet:
Door guards:
Jeff |
