Anti-freeze/coolant recommendations
Page: Previous  1, 2
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sun Jun 17, 2012 9:27 pm    Post subject: Reply with quote
It must be another Miracle happenening here.
Running 5/30 water thin oil in that engine when the the suggested oil during the summer months is minimum 15/40, just plainly is insane.
It's not suggested in your owner's manual, it's not suggested in the Bently, it's not suggest by any competant VW dealer.
How you came upon this wacky Eurika on your own--and then braodcasting it live, is beyond me.
FYI--there is some sort of combustion by products found in every internal combustion engines coolant.
Not on day one.
Maybe not on day two.
But on day 679 the coolant wil have some sort of combustion related contamination.
The coolant will be suspending some sort of garbage in it.
It's DCA level will be down--regardless of how much & how often you add that subaru jello & allow to float around in the system--how mch sealer can a system hold in suspesion without screwing something up?
If you had hung a water filter set up on the engine that would grab most of the crap outa the system, this would ave been the right way to go--no problem.
You'd have to eliminate the Subaru seal a meal garbage --it would plug the filter up right away,and deem it worthless.
Plus--to never change that coolant is a fools wish for longevity.
Tell me you have a spin on water filter with a conditioer pill in it only on that engine, & I'll believe you don't ever change the coolant.
Until than--I'd keep this one to yourself--I sure wouldn't be announcing the haphazzard methods you are practicing to screw up your cooling system.
T.K.
randywebb
randywebb is offline
PostPosted: Mon Jun 18, 2012 12:44 pm    Post subject: Reply with quote
what is DCA ?
does the Subaru product not also contain conditioners and other additives, besides having a stop leak function?
My goal is not to keep the same coolant in there for decades, just a few years, and it is not clear to me why a long-life coolant with ot w/o additional additive packages can last 10, 20 or more years in other alloy motor cars, but not in a Vanagon(?)
1986 2.1L Westy 2wd Auto Trans.
Wildthings
Wildthings is offline
PostPosted: Mon Jun 18, 2012 1:20 pm    Post subject: Reply with quote
randywebb wrote:
what is DCA ?
I don't think it would be wise to try and run any engine that long without replenishing the additives from time to time.
randywebb
PostPosted: Mon Jun 18, 2012 1:35 pm    Post subject: Reply with quote
Understood - my question is about a longer than 2 year change interval with testing (using test strips) & periodic replenishment of the additive package.
Merian
Merian is offline
PostPosted: Sun May 31, 2015 4:25 pm    Post subject: Reply with quote
anybody use BMW coolant?
is it just a re-branded German coolant? or does BMW require a certain spec. ...??
tjet
tjet is offline
PostPosted: Sun May 31, 2015 5:15 pm    Post subject: Reply with quote
Why not VW G13?
I use it in all my VW's
Support the "Right To Repair" bill
https://repair.org/policy
Worth a listen...
https://www.wbur.org/onpoint/2018/11/01/right-to-repair-digital-locks-technology-smartphones-cars
0to60in6min
0to60in6min is offline
PostPosted: Sun May 31, 2015 6:09 pm    Post subject: Reply with quote
I use Pentosin NF - flush and replace every 1.5 to 2 years....
http://www.pentosin.net/f_antifreeze.asp
hans j
hans j is offline
PostPosted: Sun May 31, 2015 6:25 pm    Post subject: Reply with quote
Yes, we use the blue bmw coolant to replace g11
1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181
tjet
tjet is offline
PostPosted: Sun May 31, 2015 7:05 pm    Post subject: Reply with quote
So what is best for a WBX, nitrate-free or silicate-free? (or... what's best to avoid head gasket leaks)?
Worth a listen...
IdahoDoug
IdahoDoug is offline
PostPosted: Sun May 31, 2015 8:49 pm    Post subject: Reply with quote
I use the cheapest green undiluted coolant I can get at NAPA. It's their $12.49/gallon house brand. Works great. I save the exotic $30/gallon Euro brand for my Audi. Mainly because I like having a bottle of that stuff on the shelf next to the other exotic oils and lotions and potions - heh.
The Vanagon WBX is a pretty low stressed, low tech engine and I'm not sure it needs to be fed pricey coolants. If I ever switch, it will be to a nontoxic simply because of how much these girls leak onto the street!!
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces.
JudoJeff
JudoJeff is offline
PostPosted: Mon Jun 01, 2015 5:47 am    Post subject: Reply with quote
My understanding of why you should change your antifreeze every two years is because it becomes an electrolyte, like in a battery. Your test strips are most likely just checking to see how acidic it is. As it becomes acidic, the Noble metals start shedding themselves, moving to the next lower metal on the range.
(zinc and aluminum are the sissies....)
Boats parked next to each other at an ocean dock, with an electrical leak into the water by one, can dissolve the entire motor in a short period of time. (Swimmers can also get lethally shocked!) The same thing happens inside your VW engine.
The azeotrope mixture of EG/H2O has poor rust inhibiting qualities, and additives help. But after even one year it's common to see a rust colored antifreeze. You're smart to change to a fresh mixture.
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig.
0to60in6min
PostPosted: Mon Jun 01, 2015 8:29 am    Post subject: Reply with quote
if you look at the upper right corner - Pentofrost NF (with silicate) - at the list of vehicle - it's for Volkswagen (up to 06/1996)
kamzcab86
kamzcab86 is offline
PostPosted: Mon Jun 01, 2015 12:00 pm    Post subject: Reply with quote
if you look at the upper right corner - Pentofrost NF (with silicate) - at the list of vehicle - it's for Volskawagen (up to 06/1966)
^Typo. Wink Pentofrost NF, which is G11, is for Volkswagens up to 6/1996.
Here's a breakdown of VW's coolants over the production years:
Up to 1996: G11 (Ethylene Glycol-based with silicates, phosphate-free)
1996-2003: G12 (Ethylene Glycol-based, phosphate- & silicate-free)
2003-2008: G12+ (Ethylene Glycol-based with special additives; phosphate- & silicate-free)
2008-2010: G12++ (Ethylene Glycol-based with silicates; phosphate- & nitrite-free)
2010-present: G13 (Ethylene Glycol-based with silicates; phosphate- & nitrite-free)
~Kamz Anxious
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein
0to60in6min
PostPosted: Mon Jun 01, 2015 12:53 pm    Post subject: Reply with quote
thanks Kam...
there's not enough coffee when I typed it..
Very Happy
tjet
tjet is offline
PostPosted: Mon Jun 01, 2015 5:00 pm    Post subject: Reply with quote
Ok then, I will use that Pentofrost NF. I just replaced the WP (87 2.1) & I currently have straight water in it (for leak checks). Thanks
Worth a listen...
0to60in6min
PostPosted: Mon Jun 01, 2015 5:07 pm    Post subject: Reply with quote
mix it 50/50 with distilled water... please...
tjet
tjet is offline
PostPosted: Mon Jun 01, 2015 7:14 pm    Post subject: Reply with quote
Will do.
I have one of these 5 gallon jugs. I mix it 50/50 with distilled water (2 gallon coolant & 2 gal wtr) & lay it down on the roof with a 8' clear hose pressed tightly (no leaks) into the surge tank (pressure res).
Remove the radiator bleeder & let it flush. Install the bleeder when the water coolant mix color matches the premix (It will be 2/3's empty) Works good. Make sure you get a square jug.
http://www.ebay.com/itm/VP-Racing-White-5-Gallon-S...mp;vxp=mtr
Worth a listen...
Page: Previous  1, 2
Page 2 of 2
