SHOCKS SHOCKS SHOCKS
Page: Previous  1, 2, 3 ... 10, 11, 12
dirtkeeper
dirtkeeper is offline
PostPosted: Sun Nov 03, 2019 2:10 pm    Post subject: Re: SHOCKS SHOCKS SHOCKS Reply with quote
Double-Double wrote:
Is there a correlation between lift amount in the back and additional shock length needed or does it not work that way? I.e. 2” lift via preload and need 2” longer shocks?
I would suggest that there is a correlation but not direct.
One Is the shock is not at the wheel location and because the wheel is farther out and there are angles involved the wheel travel is greater than the shock travel.
Two Until you start to notch the spring plates you do not need a longer than stock shock
Thanks! I figured there is probably some Pythagorean theorem for figuring it out. I have the Atomwerk 2” raise plates so I will have to play it by ear and measure when I get them on and do the cycle up and down thing.
Well I think with the raised plates , that Will extend the downward travel and lowest location of your shock mounts / trailing arms similar to notching the spring plates. You will have to check you final travel to see what will fit . Both compressed and extended. To be honest I think this is a little different on every individual vehicle. Mine is different even side to side, I think because of twisted tranny forks, and other bent or worn parts . I found , after only testing one side to find shock travel needed that when put the same shock on both sides that the one side had the extra 1/2 travel, beyond the stop limit that I intended. That the other side only had about a 1/8” extra travel . Both sides had exactly the same spring plate notch.
Double-Double
Double-Double is offline
PostPosted: Sun Nov 03, 2019 3:59 pm    Post subject: Re: SHOCKS SHOCKS SHOCKS Reply with quote
Yeah I figured I would just treat the raise plates as a factory notched plate with a little extra mass and strength. I don’t know if anyone else on here has even run them. I will definitely not throw away my factory plates haha. Just trying to get a smooth ride in the rear to match my thing front.
Page 12 of 12
