SHOCKS SHOCKS SHOCKS
Page: Previous  1, 2, 3, 4 ... 10, 11, 12  Next
bajabug420
bajabug420 is offline
PostPosted: Tue Dec 06, 2011 12:23 pm    Post subject: Reply with quote
The Phil wrote:
skeleton0131 wrote:
ya im just gonna let my dad decide on that one..and 25mph on 2 foot whoops kinda kills haha but i do haul ass in the washes Smile
I made a goof for you. I didn't mean the torsion bar, I meant the sway bar. I'm an idiot at times. Confused
Remove the sway bar and see if that helps your off roading any. It's a free, limited time ordeal. It won't hurt anything.
What all does the sway bar do to affect offroading? I have mine on and haven't had anything STOP me yet BUT if I take that off then it would be even better? What would it do for stability, safety or weaking of other parts?
Just want to know before I yank mine off.
Ron Paul 4 President
68 Baja Bug
1600 SP
Pertronix Ignition ii
Pertronic Ignition ii Coil
Crash First/Reverse Bus Swing Axle
Mal evolent
Mal evolent is offline
PostPosted: Sat Dec 17, 2011 7:45 am    Post subject: Reply with quote
it limits the ability of the front wheels to act independently. If one tire climbs a rock and the other tire dips into a hole simultaneously the sway bar will lift the dropped tire off the ground. the ability to have both wheels go opposite ways is "Articulation"
If I take that off then it would be even better? What would it do for stability, safety or weaking of other parts?
Sway bars resist rolling to the outside in high speed turns. If you slalom through traffic 30 miles an hour faster than traffic, leave it on. If you live in a little desert town and can get to off road areas without your tires tasting freeway, yank it.
youtubes of jeeps without sway bars:
http://www.youtube.com/watch?v=q70i5uRB5IU
http://www.youtube.com/watch?v=-LaOb2yvTXo
http://www.youtube.com/watch?v=pqoBWgXEAk8&feature=related
http://www.youtube.com/watch?v=umoNU0YZBdg&feature=related
http://www.youtube.com/watch?v=6HuYoFfvl2s
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 1776, Solex 34 Pict-3, Bosch SVDA, '97 Mustang seats
[77 Westy M plate decoded]
Baja Bugs for Volkswagen Virgins: Index
luisbaja
luisbaja is offline
PostPosted: Sat Dec 17, 2011 11:05 pm    Post subject: Reply with quote
ok so i have a stock irs suspension and when i bought the car she came with some cheap coilover shocks that hit my bottom spring plate stop everytime i go over a speedbump. what is the stock extended lenght and stock travel, in other words what measurement shocks should i be looking for?
thanks,
luis
if it doesn't break, you're doing something wrong
1970 Turbo Baja buggy (o\!/o)
KrAzY-BaJa
KrAzY-BaJa is offline
PostPosted: Sun Dec 18, 2011 1:21 am    Post subject: Reply with quote
vw's arnt jeeps Laughing I never ran a sway bar on any of mine, making a off road baja isnt going to be a street racer so your not going to be needing it anyways (at least mine and a few of my buddies dont) Confused
thanks,
luis
if the stock shock mounts are still there then search for shocks for your year and type of car.
70% of what you buy is something to start with.
ForYotaWagen: A Ford/Toyota/Volkswagen http://www.thesamba.com/vw/forum/viewtopic.php?p=4871576&highlight=#4871576
luisbaja
luisbaja is offline
PostPosted: Thu Dec 22, 2011 11:24 am    Post subject: Reply with quote
ok so i got another quick question. as my car sits now i have about less then 1 inch of down travel before my spring plates bottom out , could it be that the previous owner lifted the rear end of my car but just never got around to putting the type 2 cv joints and cutting the bottom limiter? here are some pictures, it might look a little higher because i just recently cut the rear fenders.
KrAzY-BaJa
PostPosted: Thu Dec 22, 2011 12:15 pm    Post subject: Reply with quote
its sitting high because you have coilovers & torsion bars on it...
luisbaja
luisbaja is offline
PostPosted: Thu Dec 22, 2011 9:25 pm    Post subject: Reply with quote
so whats the next step to get rid of this problem? the coils are already set to the lowest possible.
The Phil
The Phil is offline
PostPosted: Fri Dec 23, 2011 3:57 am    Post subject: Reply with quote
The purpose of having coil overs is to be able to eliminate the torsion entirely.
"In case I don't see you, good afternoon , good evening, and goodnight."
My '66 Baja Build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=456365
Free from the evils of facebook.
JonF
JonF is offline
PostPosted: Fri Dec 23, 2011 4:00 am    Post subject: Reply with quote
but not those coil overs.
68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix
dirtkeeper
dirtkeeper is offline
PostPosted: Fri Dec 23, 2011 8:09 am    Post subject: Reply with quote
if the spring plate is hitting the stop,which is often the case when the torsion bars have been adjusted, you can notch the spring plates or cut the stop.... but then you need to install type 2 cv's (or others) that can handle the increased axle angle ..AND you need to confirm that your shocks will be long enough...AND you will still want to put a strap or stop to limit your axle travel to the limits of your chosen cv joint. It looks like to me that the stop HAS been cut in that picture where your finger is
luisbaja
luisbaja is offline
PostPosted: Fri Dec 23, 2011 9:57 am    Post subject: Reply with quote
well actually the thing to the right of my finger is what the spring plate is hitting,also putting type 2 cv joints is it just buying type 2 cv's and putting them in or is there more to it?
Dave24
Samba Hack Purist
Dave24 is offline
PostPosted: Fri Dec 23, 2011 11:44 am    Post subject: Reply with quote
You would also need bus or thing stub axles, adn depending on the trans you're running, you may also need flanges for the trans and different axles.
Kbar
Kbar is offline
PostPosted: Wed Jan 04, 2012 10:41 am    Post subject: Reply with quote
I got kyb all around, its getting time to replace them. I have 8 shocks though so its probably going to be expensive. I can gladly use your input, before I spend a fortune.
[email protected]
vw@cfrscca.org is offline
PostPosted: Wed Jan 04, 2012 3:10 pm    Post subject: Reply with quote
I'd suggest luisbaja disconnects his rear shocks to tell if it is the torsion bars that are lifting it.
Is it really worth T2 CV's with stock trailing arms?
1974 Standard Beetle to Baja Bug
http://picasaweb.google.com/fvee1234/BajaBug02#
darkflaw
darkflaw is offline
PostPosted: Wed Jan 04, 2012 5:57 pm    Post subject: Reply with quote
Has anyone hear any news on F-O-A, I see they are slowly adding items back. Can't wait till they are full swing, I really want to order some shocks Very Happy
Berrien 295 Build Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=482673
KrAzY-BaJa
PostPosted: Thu Jan 05, 2012 10:51 am    Post subject: Reply with quote
Foa is What I run on the back of mine, holding up better than my 2.0 foxs in front
2.5 res 14" travel
2.0 4" travel bumpstops
qwerty8669
qwerty8669 is offline
PostPosted: Wed Jan 11, 2012 1:43 pm    Post subject: Reply with quote
set can be had for $160.....Pro Comp ES9000 Shocks all the way around....???
stock 68 swing axle.....factory all the way. just want to get rid of the crappy coil overs.
ryno496
ryno496 is offline
PostPosted: Sun Jan 15, 2012 11:28 pm    Post subject: Reply with quote
qwerty, NO!!!! haha we thought that was a good idea for our baja bug, but the first trip with them, very mild driving bent them both in one trip and thn had to pay for overpriced replacements. spend the extra $ and get KYB gas adjusts if you dont want to go to expensive cause its well worth the diff
qwerty8669
PostPosted: Mon Jan 16, 2012 7:02 am    Post subject: Reply with quote
Can get a set of 5520 and 4529 for less than the es9000
So the kyb's hold up pretty good...I don't plan on jumping the car or anything but would like to buy a shock that will hold up. Not looking to spend 200 per shock either ( would love a set of foxes but not in the budget)
68 swing axle baja ( making 4x4s look stupid )
67 F100 Big Block ( loud gas eater )
97 civic hatch ( grocery getter )
90 t-top 300zx 5speed ( ticket monster )
looking for swap meets and places to ride in ky and tn
my build ( gonna be slow ) can anyone tell me what my seats came out of....???
http://www.thesamba.com/vw/forum/viewtopic.php?t=495087&postdays=0&postorder=asc&start=0
car's facebook page ... like it !!
http://www.facebook.com/68bajabug?ref=hl
qwerty8669
Page 3 of 12
