locky Samba Member
Joined: May 08, 2008 Posts: 573 Location: Nelson, British Columbia
Posted: Mon Nov 21, 2011 9:02 am Post subject: Winterizing |
Snow is here, so that's it for the Thing. I will be storing it in my heated shop for the winter and doing some work to her over the cold months. No engine work, some electrical and a roll bar. I am wondering if there is anything I should do for her while she sits. With my snowmobile, I give it a yearly fogging for summer storage, anything similar I should do for the thing?
Thanks |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
FV195 Samba Member
Joined: February 19, 2005 Posts: 480 Location: carlisile, pa
Posted: Mon Nov 21, 2011 11:11 am Post subject: |
move to florida, or another warm place and drive year round. 79 and sunny today.
I know that is something not everyone can do.
I would also pump the tires up hard, all tires lose air, if they sit a few pounds down can cause flat spots. I myself, when I lived in a cold place would do a fresh oil change. old oil holds bad stuff in it, and when a nice day hits in the spring, she is ready to go, get yourself a "battery tender" the brand name one, not a cheap trickle charger. put on the battery, in summer you can use on snowmobile . stable in the gas is a must do. be sure to run to to get it to the carb. store with top up, windows in to keep rodents out, last thing, I would clean it good too.
THOR
hope this helps |
Posted: Mon Nov 21, 2011 12:37 pm Post subject: |
Always best to just remove the battery. That way if you don't fire her up next spring, but let her sit for a year or two you will not find the battery hanging out the bottom of the car when you do want to drive her again. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Mon Nov 21, 2011 4:22 pm Post subject: |
This will help http://www.thesamba.com/vw/forum/viewtopic.php?t=159834
Some folks go a little overboard in my opinion. I just do fresh oil, grease, fuel stabilizer in a full tank of gas, plug the exhaust and disconnect the battery. _________________ D-Dubya Manx clone - 63 Short pan,1914.
lukesky Samba Member
Joined: July 12, 2006 Posts: 246 Location: See The Rabbits, IA
Posted: Mon Nov 21, 2011 6:38 pm Post subject: |
I also heard that Bounce dryer sheets help keep the rodents away as good as mothballs, so I put 5 or so around inside the cabin. That could be totally wrong, but they sure do make it smell better in the spring. I hook up the battery to a trickle charger, then plug it in every month for a day or two to keep it topped up. When my dad had it, he'd take the battery out, but didn't keep a charge in it and a cell would go bad. He bought a lot of batteries in springtime. _________________ You get what you get, and you don't throw a fit.
-Gabi |
FV195 Samba Member
Posted: Mon Nov 21, 2011 6:50 pm Post subject: |
a trickle chager is fine for short charges, but if left on will cook the battery. spend the money, buy a "battery tender" they have a smart chip, that won't over charge it, can be left plugged in all winter with out thinking about it, ready to go in spring, when thing comes out, move it to snowmobile.
just don't start car with tender plugged in, that can fry them, my brother did it to 3 of them, I unplug from wall before a start. I leave mine, waterproof one in the car all the time. plug in when near an outlet. my ex father in law, used a trickle charger on his wave runners every winter. had to buy new batteries every spring. best of luck to you there is a lot more you could do but it is over kill |
Semper_Dad Samba Member
Posted: Mon Nov 21, 2011 7:04 pm Post subject: |
hahaha, "winterizing" for me means adding another towel to help the defroster to clear the inside of the windshield. That and more blankets . I drive year around _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Mon Nov 21, 2011 9:17 pm Post subject: |
Sadly for us winterizing looks like we are selling. Moving up to 4000 feet this month. No heater or windows. _________________ 74 181 Thing
2008 Ford Sport Trac V8 4x4
2008 Ford Escape V6 |
livy Samba Member
Joined: September 30, 2011 Posts: 127 Location: Bloomington In
Posted: Mon Nov 21, 2011 9:20 pm Post subject: |
I'm driving mine all winter. I heard VW are great on the snow??? |
Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
Posted: Tue Nov 22, 2011 7:42 pm Post subject: |
winterizing...i put the top up. clean towel (defroster) for the season too. _________________ "I haven't seen one of those since I was shootin' at 'em!" |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Tue Nov 22, 2011 7:50 pm Post subject: |
Semper_Dad wrote: |
hahaha, "winterizing" for me means adding another towel to help the defroster to clear the inside of the windshield. That and more blankets . I drive year around |
Lol, same here! _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw |
Posted: Tue Nov 22, 2011 8:06 pm Post subject: |
FV195 wrote: |
spend the money, buy a "battery tender" they have a smart chip, that won't over charge it. |
I wonder about this advice. I pulled the (older, fairly cheap) battery from my car when I did a bunch of work on it for over 10 months back in '07. I set the battery on concrete thinking I'd replace it soon anyway and have to charge it up before use.
10 months later, I was excited about getting back on the road, so I reinstalled the battery and just for kicks tried to start the new-to-me engine - without recharging the battery. I figured it'd light up the gauges and maybe crank for a moment or two. It held out for over 5 minutes of cranking to get the engine to kick over (priming new systems). That old, fairly cheap, now abused battery rose to the occasion and just kept chugging. I ran it for another 4 months before replacing it with an Optima Red Top - but only because I wanted a sealed cell.
So I do know that batteries will self-discharge - I've seen it first hand. But I'm not so sure you'll notice that much of a difference over a couple of months so long as the battery is truly disconnected and has a decent charge. I don't believe the myth that setting a battery on concrete will discharge it.
However, it may be that freezing the battery could shorten its life. I wouldn't be surprised if the trickle chargers provide enough heat to keep the electrolyte from crystalizing. Internally, the expanding ice crystals can push around the components and muck it up. Seen that too. _________________ VW-181 shirts and stickers.
Posted: Tue Nov 22, 2011 8:36 pm Post subject: |
A badly discharged battery can freeze which will cause mechanical damage to the plates and maybe even split the case. Pulling the negative cable off will prevent the battery from running down as fast and using a trickle charger occasionally will replace whatever charge is lost. Setting a battery on concrete will not cause it to run down, this is little more than an old mechanics' tale left over from the 1950's.
I try not to leave a battery sitting on concrete or metal though, not because it will cause the battery to run down, but because the battery can damage the concrete or metal if and when it leaks acid. |
FV195 Samba Member
Posted: Wed Nov 23, 2011 9:23 am Post subject: |
this is for the hardcore that drive all winter long. when I liver in cold climate, I added a 12 volt booster fan to the defroster on my 74. could stand streamers up, and it helped pull the heat in, can get them at west marine or something like that |
Posted: Wed Nov 23, 2011 9:32 am Post subject: |
FV195 wrote: |
I'd like to see pictures of your setup. I've been looking for an in-line fan that I can hook up to the existing defrost hose. Unfortunately, the only one I can find involves international transactions. I'm not fond of using plastic bilge motors _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
FV195 Samba Member
Posted: Wed Nov 23, 2011 9:35 am Post subject: |
don't have it set up anymore, changed things, sold one, bought one, moved to florida, so never set it up, still have the blower, will try to post photo, in the boating world they call them bildge fans
got pictures but, can't figure out how to post them and it is a plastic fan, with rubber reducers to fit the hoses, had a 4 position switch off, low, med, hi. plastic, but worked real well. might hook my heat up again, GF gets cold at night, have a roof, but never put it up. |
locky Samba Member
Posted: Thu Nov 24, 2011 8:52 am Post subject: |
Thanks for all the info fellas, and the advice. I think I will stick to BC though, I like our snow much better then Floridas. Better for snowboarding. |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Sat Nov 26, 2011 4:13 pm Post subject: |
It's better to put a tarp underneath the car rather then on top of it _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
Posted: Sat Nov 26, 2011 6:25 pm Post subject: |
[email protected] wrote: |
It's better to put a tarp underneath the car rather then on top of it |
It is better to park it on well drained soil than to park it on the shallow swimming pool a tarp will cause.
I just cover the top of mine down to the window sill level and that keeps any wind driven rain out while still allowing some ventilation. |
