Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Sun Oct 16, 2016 2:28 pm Post subject: Re: A new split sheet metal part |
Thank you Mika! Seeing the channel with the tube attached finally makes more sense as to how vw originally made these _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Tempie Samba Member
Posted: Tue Dec 06, 2016 3:18 am Post subject: Re: A new split sheet metal part |
Any progress on the quarter panels Mika? _________________ When a deluxe is not enough.... you go standard
Early 55 standard sunroof
Visit the Standard Split and Oval Beetle group!!
VW Standard Split and Oval Beetle |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
dlx63bus Samba Member
Joined: November 18, 2005 Posts: 46 Location: Monterrey, MX
Posted: Tue Dec 06, 2016 10:38 am Post subject: Re: A new split sheet metal part |
Mika, this will be the part the designers are working on it?
If so, I will need both sides for my 52 from the gas tank towards the front apron. When do you think they will be available and how much ?
50Splitman wrote: |
And this would be an area I need...both sides. What is on the market now is junk. I would imagine that many early beetles from rust-prone areas of the Earth need help in this area of the vehicle.
Posted: Tue Dec 06, 2016 10:53 am Post subject: Re: A new split sheet metal part |
Yes, those are the panels. The right side will be made first, then left side later. Hopely will get the first parts in January, then left side February. The price depends if the bumper / horn brackets are there or not. _________________ Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1771 Location: Finland, Jakobstad
Posted: Fri Dec 30, 2016 6:03 pm Post subject: Re: A new split sheet metal part |
Mika,
Are the 50-52 front shock towers will available as a welded option?
Thanks
Rudy |
Grant Reiling Samba Slow-Change Artist
Joined: November 28, 2003 Posts: 491 Location: behind the wheel
Posted: Sun Mar 12, 2017 1:20 pm Post subject: Re: A new split sheet metal part |
Hebster52 wrote: |
Wow!! I need these for both sides! |
...As do I; so happy you're producing these! _________________ 1952 Azure Blue 12G (LHD Deluxe 3-fold sunroof Sedan).
"What you really know is possible in your heart is possible.
We make it possible by our will.
What we imagine in our minds becomes our world. That’s just one of many things I have learned from water."
Misaru Emoto
The Hidden Messages in Water |
Rhysos Samba Member
Joined: March 17, 2010 Posts: 26 Location: Bristol, UK
Posted: Mon Mar 13, 2017 2:47 am Post subject: Re: A new split sheet metal part |
Mika is a sheet metal genius! Wonderful stuff as ever _________________ www.vwbeetlerestoration.blogspot.com |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Mon Mar 13, 2017 10:22 am Post subject: Re: A new split sheet metal part |
_________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
50Splitman Samba Member
Posted: Tue Mar 14, 2017 11:44 am Post subject: Re: A new split sheet metal part |
Great job Mika!
Do you expect to make fender bolt holes and add the weld nuts?
Will you drill the holes for the headlight tube and bolts?
Will you offer with the bumper bracket welded on?
Thanks again for all your hard work!!! |
low_and_slow Samba Member
Joined: February 03, 2009 Posts: 26 Location: Peterborough, United Kingdom
Posted: Tue Mar 21, 2017 4:06 pm Post subject: Re: A new split sheet metal part |
Crazy question but how far from a late 50's equivalent would this be? I'm so limited for good quality repair panels here so I'd much prefer these if they'd be close. Sorry for newbie question! |
Posted: Tue Mar 21, 2017 10:30 pm Post subject: Re: A new split sheet metal part |
low_and_slow wrote: |
They are very close, the front beam recess is smaller for split than later. But maybe you don't need to go so far. _________________ Mika
New projects |
