A new split sheet metal part
Page: Previous  1, 2, 3 ... 11, 12, 13, 14, 15  Next
virtanen
virtanen is offline
PostPosted: Tue Mar 20, 2018 9:35 am    Post subject: Re: A new split sheet metal part Reply with quote
Convertible reinforcements, Z-form inside heater channels, V-form inside vert lower channels.
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
peter schepens
peter schepens is offline
PostPosted: Tue Mar 20, 2018 12:03 pm    Post subject: Re: A new split sheet metal part Reply with quote
Nice one Mika.. is that 1 mm thick ?
I made them for my Schepmuller in 2mm metal. The v rail and the Z rail that is actualy a C rail.
Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html
virtanen
virtanen is offline
PostPosted: Tue Mar 20, 2018 10:53 pm    Post subject: Re: A new split sheet metal part Reply with quote
Yes 1 mm, I make them as originals are. Hebmüller has different rails than convertible beetle.
Next the lower channels...
Mika
New projects
beetlekey
beetlekey is offline
PostPosted: Wed Mar 21, 2018 10:52 pm    Post subject: Re: A new split sheet metal part Reply with quote
Make them stronger!
Hebmüller 581
1953 oval Typ 11G metalblue
1966 1300
If you are searching for vintage keys, look here:
https://www.facebook.com/WagenmanufakturHO
peter schepens
PostPosted: Thu Mar 22, 2018 4:43 am    Post subject: Re: A new split sheet metal part Reply with quote
Make them stronger!
said the man with the most experience in making convertible tops on Split Karmann , Hebmullers and other coachbuilts. That is why I made them in 2 mm. Wink Reinforcement rails under the heater channel in 2 mm with V rail in 2 mm and Z rail inside heater channel 2 mm... It is good for the doorgaps Smile
BjornTore
BjornTore is offline
PostPosted: Tue Jul 31, 2018 1:34 pm    Post subject: Re: A new split sheet metal part Reply with quote
virtanen wrote:
Hello. Anyone know what type of U channel rubber for post 4-50 Window channels? I am only known to pre 4-50 U channels. Tried with pre 4-50 U cgannel rubber, but have problems on the open part on the channel. Anyone have a tip?
Splitdog
Samba Split Personality
Splitdog is offline
PostPosted: Tue Jul 31, 2018 5:26 pm    Post subject: Re: A new split sheet metal part Reply with quote
Remove the rubber in the open area. I used a razor knife.
CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker
BjornTore
PostPosted: Tue Jul 31, 2018 11:10 pm    Post subject: Re: A new split sheet metal part Reply with quote
Hellas. Good idea. Thx.
virtanen
virtanen is offline
PostPosted: Fri Aug 10, 2018 1:10 am    Post subject: Re: A new split sheet metal part Reply with quote
The first complete lower rail for early convertible. Next I will make these couple of pieces for left side, and then start to build the tool for right side.
There will be sprayed zinc paint under the V-support rail.
Mika
New projects
BryanNunes
BryanNunes is offline
PostPosted: Fri Aug 10, 2018 6:44 am    Post subject: Re: A new split sheet metal part Reply with quote
Very nice if there like your other parts its top quality
https://www.facebook.com/BNRestoration
http://www.thesamba.com/vw/classifieds/detail.php?id=1723384
virtanen
virtanen is offline
PostPosted: Fri Sep 28, 2018 9:22 am    Post subject: Re: A new split sheet metal part Reply with quote
The first test sample for the early panel between tank and dash.
Mika
New projects
WrennMetallWerks
WrennMetallWerks is offline
PostPosted: Mon Oct 01, 2018 7:00 pm    Post subject: Re: A new split sheet metal part Reply with quote
Dude. I’m stoked. All the support rails I have used in the past have been a pain. These look awesome. Well done
The tank support and lower luggage panel look fantastic. As you know we had to make the lower luggage section for the 47 by hand here in the shop. It was very time consuming and tricky. I’m looking forward to being able to get them from you. Thanks so much for your dedication to your craft. Very inspirational
⚒ Believe In The Power Of Positive Thinking ⚒
Purpose Over Pleasure 🕊
“Hard Werk ⚒ God First “
https://music.youtube.com/watch?v=0-PSeV52tZ4&si=wpcuRnQyvIFo2nCJ
https://music.youtube.com/watch?v=PaCorLXzC5w&si=cbzT8fjlzVlIWfSV
https://music.youtube.com/watch?v=_aoE5aYSutY&si=mkZKPxd_41QA1kfs
https://music.youtube.com/watch?v=_NzUyyVexAE&feature=share
https://music.youtube.com/watch?v=UI8yUrIWS7E&feature=share
beetlekey
PostPosted: Wed Oct 03, 2018 4:43 am    Post subject: Re: A new split sheet metal part Reply with quote
NEED IT, WELD FASTER Laughing Wink
Hebmüller 581
1966 1300
virtanen
virtanen is offline
PostPosted: Sat Mar 02, 2019 9:00 am    Post subject: Re: A new split sheet metal part Reply with quote
The first oil filler cap / breather tube for 1948/1949 beetle, it's cleary shorter than later tube, also the curve radius is different.
Mika
New projects
virtanen
virtanen is offline
PostPosted: Fri Mar 08, 2019 6:13 am    Post subject: Re: A new split sheet metal part Reply with quote
I need your help!
I'm making these outriggers for floorpan, but don't have a good pattern on the outer area, also want to verify the first hole location.
What are the original dimensions of A and B?
Mika
New projects
robbiecanter
robbiecanter is offline
PostPosted: Mon Mar 11, 2019 11:12 pm    Post subject: Re: A new split sheet metal part Reply with quote
virtanen wrote:
I need your help!
A= 47mm to mid bend
B=170~mm
52' Split
64' Bug-turbo
68' Notch
84' westfalia 1.8t
87' 4runner
91' 2.9 vr6 coupe
virtanen
virtanen is offline
PostPosted: Tue Mar 12, 2019 7:39 am    Post subject: Re: A new split sheet metal part Reply with quote
Thank you Robbie!
Mika
New projects
virtanen
virtanen is offline
PostPosted: Thu Apr 11, 2019 1:56 am    Post subject: Re: A new split sheet metal part Reply with quote
Looks better now:
Mika
New projects
sled
sled is offline
PostPosted: Thu Apr 11, 2019 8:00 am    Post subject: Re: A new split sheet metal part Reply with quote
wonderful Mika! Thank you for all your hard work.
I'll be placing a big order some day when my '51 gets redone Very Happy
drive your split.
vwfanatic67
vwfanatic67 is offline
PostPosted: Mon Oct 28, 2019 5:52 am    Post subject: Re: A new split sheet metal part Reply with quote
Any plans on making that gas tank surround piece for a 52 split.
"white trash but worth every cent"
SBS #74
52 Split Beetle
60 Panel
65 Notchback
More if my wife would let me!
Page 12 of 15
