breadloafdeluxe Samba Member
Joined: February 12, 2002 Posts: 418 Location: Birthplace o Tx. Brazoria Co.
Posted: Thu Nov 24, 2011 10:17 am Post subject: Leaky Oil Pump cover? |
So somethings is leaking in that area, pump cover or rear main. Can I get the fan shroud off w/o pulling the motor? Also thinking of replacing the pump w a unit a bit stronger than stock as I do a lot of fwy driving The motor is a low mi. 1776.
Thanks,Happy Thanksgiving!
David K.
Saving up for a Fwy Flyer Tranny _________________ Give a man a fish and he knows where to get fish.Teach a man to fish and you loose a customer. |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Thu Nov 24, 2011 10:24 am Post subject: Re: Leaky Oil Pump cover? |
breadloafdeluxe wrote: |
David K.
Saving up for a Fwy Flyer Tranny |
pulling the fans & shrouds without pulling the engine is possible, but not suggested..... it soooooo much easier to just pull the engine to do the fan/shroud r & r...
plus, if it isn't the pump cover, you get to track it down, then clean up the engine with it OUTSIDE the car....
much easier.... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu Nov 24, 2011 10:41 am Post subject: |
Bigger oil pumps can cause problems and aren't really needed. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Houstonr Samba Member
Joined: February 01, 2009 Posts: 399 Location: Frisco Texas
Posted: Thu Nov 24, 2011 8:52 pm Post subject: |
W1K1 wrote: |
Follow the "how to hot rod a VW engine" tutorial on blueprinting oil pumps and the stock pump will put out more than enough pressure. |
I have reread that section of the book 100 times and still don't get it.. wish they had higher Def pics way back when.
As for leaky pump covers, I still haven't defeated mine after two attempts. |
Willo357 Samba Member
Joined: August 05, 2010 Posts: 483 Location: Melbourne
Posted: Thu Nov 24, 2011 11:43 pm Post subject: |
Yeh i have never seen one that doesnt leak (in that general area), dont worry about it too much.
i have never tried sanding the steel cover plate with glass but all advice ive used from the "how to hot rod" book has been gold so get on it.
Also if your case dosent have the second plunger (to relieve excess oil pressure) it will leak (somewhere) if you rev it hard.
I rekon that the leek they all seem to get in that area is from the crankshaft seal (or lack of) there is a reverse thread cut into the fan and if it gets crusted up the oil just blows straight past. Thats why Type 4 engines went for a rear seal aswell.
There is more than enough oil pressure from the stock system (prob too much with multigrade oil) plus you will never get the pump out without splitting the case, i know peeps say you can but wait until u try PITA!!!!
Like the how to hot rod book sais save your pennies for parts that actually do something. |
Posted: Fri Nov 25, 2011 4:25 pm Post subject: |
I have the How to Hot Rod book I'll look in to it as I havnt cracked it in a decade! The car has a fresh rebuilt 1776 then sat for a long while so its leaking front, rear and pushrod tubes not much but enough to piss off the wife and I'm getting tired of the occasional wiff of burnt oil the oil pump area seems to be the worst offender. Thanks for the input!
David K. _________________ Give a man a fish and he knows where to get fish.Teach a man to fish and you loose a customer. |
