joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Fri Nov 25, 2011 9:06 am Post subject: Clutch Slave Cylinder Failure |
Happy Black Friday.
I awoke this morning to find this rather impressive puddle of brake fluid under my Vanagon:
So, if anybody's wondering what it looks like when your clutch slave cylinder completely fails, there ya go.
Van-Cafe has been contacted, a new clutch master cylinder and slave cylinder (always replace them together!) will be en route soon, and I will be mighty chilly riding my bicycle in to work next week...
EDIT: I meant to write "clutch" master cylinder, not "brake." _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com
teej Samba Member
Joined: November 26, 2010 Posts: 897 Location: Seattle
Posted: Fri Nov 25, 2011 10:24 am Post subject: Re: Clutch Slave Cylinder Failure |
joetiger wrote: |
Happy Black Friday.
Van-Cafe has been contacted, a new brake master cylinder and slave cylinder (always replace them together!) will be en route soon, and I will be mighty chilly riding my bicycle in to work next week... |
Bummer, good luck with the repair, and Geaux Tigers!!! _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
Posted: Fri Nov 25, 2011 11:19 am Post subject: Re: Clutch Slave Cylinder Failure |
teej wrote: |
Geaux Tigers!!! |
Let me know if you ever need any parts. If I have them in my stash, you'll be getting them at a deeply discounted price! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
www.josephtrussell.com |
teej Samba Member
Posted: Fri Nov 25, 2011 12:10 pm Post subject: Re: Clutch Slave Cylinder Failure |
joetiger wrote: |
teej wrote: |
Geaux Tigers!!! |
Let me know if you ever need any parts. If I have them in my stash, you'll be getting them at a deeply discounted price! |
My LSU gal is suggesting a "test drive" to our local purple and gold pub to watch the game in moments. Good times! and Thanks for the offer! _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Fri Nov 25, 2011 12:56 pm Post subject: Re: Clutch Slave Cylinder Failure |
joetiger wrote: |
... a new brake master cylinder and slave cylinder (always replace them together!).... |
Can you elaborate why? I know they are using the same fluid, but I don't understand
why they should be replaced at the same time. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
?Waldo? Samba Member
Posted: Fri Nov 25, 2011 1:37 pm Post subject: |
I think he meant clutch master and slave, but it makes just as much sense to replace all the brake parts at the same time. The service life of the master and slave are completely unrelated and one cannot in any way cause the other to fail. Don't forget to replace the front calipers at the same time also. |
mtwrench540 Samba Member
Joined: October 25, 2009 Posts: 351 Location: monterey,va
Posted: Fri Nov 25, 2011 4:11 pm Post subject: parts replacement |
shotgun approach,what to do when not sure of what your doing!! _________________ 87 wolfsberg,74 181w/1915 and lots of patina! learned to fix vw's from hot vw mag in 1964,VWOA instructor,DSM,69 to73,service mgr at different porsche-audi dealers etc,etc,now retired!!! first vw new 64,transplanted 356 eng in 65,400characters are not enough space!! |
Posted: Fri Nov 25, 2011 5:53 pm Post subject: |
I did my slave a couple of years ago - I recommend bleeding the old slave first if it has not been done in a while.
I cringed after installing my shiny new slave cylinder and then bled old black, and I do mean black, fluid through it.
Perhaps it does not really matter if you are bleeding the entire system anyways - brakes and all, which I did, but it does not give you a warm fuzzy feeling. _________________ John - 86 Wolfsburg Westfalia "Weekender"
Thor-bob Samba Member
Posted: Fri Nov 25, 2011 7:11 pm Post subject: Re: Clutch Slave Cylinder Failure |
joetiger wrote: |
Happy Black Friday.
I just replaced my slave last week - the failed part was supplied and installed by the mechanic just a few years ago ...... it was CRAPPY! The piston was retained by a wire instead of a circlip. The replacement was German and had the circlip and everything.
The lesson here? Do it yourself and do it right the first time.
Thor-bob
1990 Carat |
Posted: Fri Nov 25, 2011 7:19 pm Post subject: |
In my experience if you change your fluid occasionally a master cylinder is probably good for better than 20 years. Slave cylinders live in a much harsher environment and will need renewing several times over the life of a master cylinder. |
windnsea Samba Member
Joined: May 07, 2008 Posts: 424 Location: Pasadena, CA
Posted: Fri Nov 25, 2011 7:52 pm Post subject: |
I bleed the brakes and clutch system every fall. This year I finally decided to put in a new clutch master and slave cylinder when putting in the BMW Brake Booster.
Bled the brakes, then put in the new slave cylinder and bled the clutch system. Then, put in the new clutch master cylinder and reverse bled the clutch system by affixing a one way valve from the left rear brake bleed valve to the clutch slave cylinder bleed valve. Slowly pumped the brakes until no air came up through the clutch system takeoff port in the fluid reservoir and all was done!!
I got 28 years out of my clutch system hydraulics!! I also use a braided ss/teflon line to the trans solid line from the chassis.
windnsea |
SteelB12 Samba Member
Joined: December 21, 2010 Posts: 591 Location: Central Virginia
Posted: Fri Nov 25, 2011 9:11 pm Post subject: |
So is this a tough job?? I need to replace the master, so I figured I would do the slave as well as some of the lines while I was at it. _________________ 1987 Westy |
BCWesty Samba Member
Joined: September 06, 2008 Posts: 165 Location: victoria
Posted: Sat Nov 26, 2011 12:36 pm Post subject: |
It's not a hard job, a bit messy. I was able to do mine from the engine compartment, way better than lying on your back. |
chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Sat Nov 26, 2011 3:51 pm Post subject: |
Flushed the system with new juice last April (looked worse than overused motor oil), then last month the clutch master cylinder went, so it got new juice again. Then last week the brake master cylinder was leaking internally, so it got new juice again.
Flushed the system in the S420 last week as well.
Flaps must think I am using brake fluid for personal lubricant, snorting it or something equally f'd up. Bet the brake fluid was never this clean since it rolled of the assembly line. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
Posted: Mon Nov 28, 2011 1:47 pm Post subject: |
Thanks Andrew, I edited my original post to say "clutch master cylinder." Always proof read!
It's not really a shotgun approach. On my first Vanagon, I replaced the clutch master and the slave failed a few months later, so from my experience it makes sense to replace them both. It's also been discussed here many times that when a failed part in a hydraulic system is replaced, the possibility of failure for other old parts in the system increases. I'm not an engineer and this is purely anecdotal, but it makes sense to me.
I could feel the shifting getting weird last spring. I rebuilt my rear brakes at that time and decided to flush and bleed everything. It worked fine up until this leak sprung.
So on the bright side, at least that puddle on my driveway is composed of clean, new brake fluid.
My parts should arrive today, so barring the usual unforeseen circumstances, I'll do the job this evening. I'll report back with any fun surprises that come up. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Posted: Mon Nov 28, 2011 5:32 pm Post subject: |
joetiger wrote: |
It's also been discussed here many times that when a failed part in a hydraulic system is replaced, the possibility of failure for other old parts in the system increases. |
It doesn't work that way. Purely a marketing gimmic reinforced by mechanics who benefit from additional work and don't want to get blamed if another part coincidentally fails any time in the near future. The only thing you are saving is the possibility of the added labor of bleeding the system again. At the same time, there's nothing wrong with preemptively swapping parts. |
Posted: Mon Nov 28, 2011 6:45 pm Post subject: |
[quote="Andrew A. Libby"]
It doesn't work that way. Purely a marketing gimmic reinforced by mechanics who benefit from additional work and don't want to get blamed if another part coincidentally fails any time in the near future. quote]
Good thing I do my own work. In any case, I'd rather change both and get it over with than have to deal with it again in the concidental near future. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Posted: Mon Nov 28, 2011 6:49 pm Post subject: |
[quote="joetiger"]
Andrew A. Libby wrote: |
Good thing I do my own work. In any case, I'd rather change both and get it over with than have to deal with it again in the concidental near future. |
That's what I am doing as well. All the parts are old and something is leaking, so I am putting in new master and slave as well. Hope it won't be too hard to get at the master _________________ 1987 Westy |
Posted: Mon Nov 28, 2011 6:53 pm Post subject: |
Nothing wrong with that. I've rebuilt engines preemptively. |
Posted: Mon Nov 28, 2011 7:08 pm Post subject: |
[quote="SteelB12"]
joetiger wrote: |
That's what I am doing as well. All the parts are old and something is leaking, so I am putting in new master and slave as well. Hope it won't be too hard to get at the master |
Getting this job done is relatively easy - for a 22 year old Asian contortionist.
Actually it took me more time to bleed the system than it did to replace the clutch master cylinder. Pretty straight forward.
Referenced the Bentley and this internet article: http://www.vanagonauts.com/30.2-Clutch-Master161.htm _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
