kingsfanrob Samba Member
Joined: December 24, 2007 Posts: 126 Location: San Dimas
Posted: Fri Nov 25, 2011 3:37 pm Post subject: Carbs started popping all of a sudden |
Was driving my car yesterday and all of a sudden I lost power and the rt side carb started to pop like a firecracker. I lost some power and the popping was continuous as I limped home. The popping is in the barrel that is over the #2 cylinder and gets worse with acceleration. The popping causes a poof or mist of gas, even through the air cleaners. I have a 1968cc stroker motor with dual Weber 40 IDF's, electric fuel pump set at just less than 3lbs. Car was working fine before this happened. I did check the jets for debris and found nothing, the #2 cylinder plug was grossly black and dry. I posted this in the 58-64 forum, but this is the correct forum, sorry for the duplicate post. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Fri Nov 25, 2011 4:14 pm Post subject: |
If its not some thing stuck in the jets or carb it could be a intake valve hanging open, have you pulled the valve cover off ? Did you check all the jets? [idle, air, main, E-tube]
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Fri Nov 25, 2011 4:15 pm Post subject: |
Its the dizzy..... _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
baked beetle Samba Member
Joined: September 23, 2006 Posts: 1162 Location: Alberta, Canada
Posted: Fri Nov 25, 2011 6:57 pm Post subject: |
fivelugshortaxle wrote: |
Its the dizzy..... |
you blow me away sometimes
change the plug out and drive it, see how she runs. _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE) |
volkyoo Samba Member
Joined: July 26, 2010 Posts: 417 Location: dominican republic.
Posted: Fri Nov 25, 2011 7:10 pm Post subject: |
did you pulled out the idle jet in that barrel? |
Posted: Fri Nov 25, 2011 7:37 pm Post subject: |
baked beetle wrote: |
change the plug out and drive it, see how she runs. |
Lighten up Frances
You really think that I think its the distributor? If you'll look of at the persons post above mine .......in his signature...........he says " I refuse to call a distributor a dizzy..."......it was a joke.....
Personally I think the popping is one of two things...1- he "looked" at the jets and decided they're clean when they're not.......2- its a valve which could either be sticking or there's a problem with a rocker arm........other than that I wouldn't know..... _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Fri Nov 25, 2011 8:05 pm Post subject: |
I only blew out the main and idle jets. Changed the plug but still no change. I will check all of the things mentioned above tomorrow. |
Posted: Fri Nov 25, 2011 8:08 pm Post subject: |
kingsfanrob wrote: |
I wouldn't check them........I would pull them out.....put them in a can of carb cleaner .......let them really soak.......and then blow them dry with compressed air........also do what someone else mentioned and pull the plug on that cylinder for that barrell......may have fouled the plug and if the jets were the problem you'll put them in and still have a problem because the plug is fouled... _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
jsturtlebuggy Samba Member
Posted: Fri Nov 25, 2011 8:21 pm Post subject: |
My WAG is that #2 exhaust rocker has come off shaft or the push rod has popped out of rocker arm.
If it and AutoCraft hi-ratio rocker shaft or cheap imitation shaft could have broken off. They do that. Even the guys at AutoCraft will tell you the shafts need changing every so often. They break right at hole for rocker stud.
If you can't get it out, you can get it in. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
manxmark Samba Member
Joined: February 24, 2007 Posts: 224 Location: Western Australia
Posted: Fri Nov 25, 2011 9:32 pm Post subject: |
I had the same thing on a different engine (Ford Escort) and it ended up being a broken lifter that ended up chewing a lobe off the cam on one of the intake valves. _________________ Manx Clone Buggy
1960 Beetle RHD |
Posted: Sat Nov 26, 2011 7:11 am Post subject: |
.. _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
66' His
57' Theirs
63' Hers
Posted: Sun Nov 27, 2011 2:19 pm Post subject: |
Of course I got a cold over the weekend. I did manage to get into the garage and puled off the valve cover. The pushrod on the #2 cylinder is disengaged from the rocker arm, I will repair tomorrow if I am up to it. What causes this to happen? |
Posted: Sun Nov 27, 2011 6:28 pm Post subject: |
It is actually a broken rocker. |
Posted: Tue Jan 17, 2012 7:12 pm Post subject: |
Changed rockers, adjusted valves and all worked well for one trip. Came home from the show and had fouled the number 2 plug. Car has been running great for the last year......clogged jet? |
