My H6 Install (EZ30)
purplepeopleeater
purplepeopleeater is offline
PostPosted: Sun Dec 04, 2011 8:17 am    Post subject: Reply with quote
I just saw this, sorry I didn't answer the question, the spacer only moves the hot/cold fittings towards the rear of the engine, rather then having the one line run around the front right next to the muffler and also in a very bad area for a van, its moved all the adapter does is move it to the rear its still getting water before the thermostat.
I need to work on moving the water ports to the rear on the oil cooler adapter too, but its made with a material that I hate working with and seem to never get leak free.
I also made new hard lines that connect to it, one leading back to the top like the factory one and one that snakes behind the oil pan and between the flywheel/engine mount, it worked out perfect.
syncrogreg wrote:
Hi,
Good job! it's not easy to deal with all the mess the factory engine has.
Why do you relocate the water fittings? they are located before the thermostat to give you hot air in cold morning within a minute. The spacer that has the new fitting is located in the cold water side or the warm water erea? I don't get the point yet.
Thanks
GSB
derekdrew
derekdrew is offline
PostPosted: Sun Dec 04, 2011 11:49 am    Post subject: Reply with quote
I need help determining how to install a VDO oil pressure sender and VDO oil temperature sender onto my 2004 EZ30D H6 3.0L engine from a Subaru Outback Legacy and I need to determine what my options are for install location of the sender.... what sender locations would be more desirable, and which would be less desirable for best accuracy. I am happy to drill and tap holes, or change hole sizes. Also, I need to hear a little about whether to tie in to the existing subaru sender(s) that may exist already installed for the engine. I can't mount the senders on the oil pan because they would get scraped off with the sort of driving I do, so I am wondering if I should just drill sideways into the engine just above the oil pan for the temperature sender. The "warning contact point" for VDO senders is about 7 to 8psi, which is much higher than the 3ish PSI I heard subaru uses in their own senders. I am wondering if this would be fine for me to have the VDO take over the job of the warning contact sender, or whether with 7 or 8psi I would be subject to too many false alarms. My options for thread size for the sender are:
My options for thread size for the oil pressure sender are:
1/8-27NPT (most common)
1/4-18 NPT
M10x1
M12x1.5
M14x1.5
3/8-18NPT (via adapter)
1/4-14NPT (via adapter)
The gauge I have goes to 80psi. Would this be OK for this engine, or might I need something higher, like 100psi, or 150psi.
My options for thread size for the oil temperature sender are:
1/2-14NPT
M10x1.5
1/4-18NPT (via adapter)
I can have a warning buzzer or light at 250F if I want too.
xoo00oox
xoo00oox is offline
PostPosted: Fri Feb 17, 2012 4:27 am    Post subject: Reply with quote
Purple-
Do you feel that Link ECU is smooth at all driving conditions as the original Subaru one would be? Does it run perfect in all temps and loads?
Andrew-
purplepeopleeater
PostPosted: Fri Feb 17, 2012 7:52 am    Post subject: Reply with quote
I think it is, I am having some high idle issues when the engine gets really warm (fully loaded, pushing it up a pass)...it will go from 800 rpms to 1500
But I'm not entirely sure thats related to the link ECU, I haven't had the chance yet to hook the laptop up and see whats going on...Could be something in the ECU settings that I monkied with.
IdahoDoug
IdahoDoug is offline
PostPosted: Tue Mar 27, 2012 9:47 pm    Post subject: Reply with quote
Updates? I'm going through withdrawals...
DougM
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces.
purplepeopleeater
PostPosted: Wed Mar 28, 2012 5:55 am    Post subject: Reply with quote
On the RPM issue? Ohhh...that.
the needle on my tach keeps getting knocked loose, I have my gauges set to sweep when you turn the key on (yep super cool ricey feature of the link ecu) I'm going to put a dab of paint on the end of the needle maybe that will keep it from coming loose.
other then that, its been worry free...i'm switching to synthetic oil here in another 500 miles so I can skip a few more miles between oil changes.
we have put about 3200 miles on it since install, love it.
I'd probably love a TDI more, who wants to trade engine swaps?
insyncro
Banned
insyncro is offline
PostPosted: Wed Mar 28, 2012 6:25 am    Post subject: Reply with quote
I have the DisplayLINK module, digital is the way to go Exclamation
purplepeopleeater
PostPosted: Wed Mar 28, 2012 6:31 am    Post subject: Reply with quote
Yes that is my next mod, that ECU has alot of good info that would be nice to see up front all the time.
insyncro
Banned
insyncro is offline
PostPosted: Wed Mar 28, 2012 7:25 am    Post subject: Reply with quote
Yes Sir,
Very valuable information at a glance and warnings can be set to any parameter you wish.
Not many truely understand the advantages and customization possible vs using the stock ECU and wiring.
The G4 Extreme can be set up to monitor and display so many inputs other than engine management.
The DisplayLINK is so much smaller than a laptop, with all of the same info at your finger tips while driving.
I'm sold.
purplepeopleeater
PostPosted: Wed Mar 28, 2012 8:44 am    Post subject: Reply with quote
insyncro wrote:
Yes Sir,
I'm sold.
what else are you monitoring?
insyncro
Banned
insyncro is offline
PostPosted: Wed Mar 28, 2012 9:05 am    Post subject: Reply with quote
Transmission and front diff fluid temps.
Fuel temp.
Exhaust temp. for starters
The newest conversion I am working on will have all of these.
My extensive experience with the setup is in a SCCA Pro race car.
All of that tech will be wired into this new Syncro project.
With all of this and more info logged I will be experimenting with what efficency I will be able to attain and making sure I don't roast Syncro transmissions and VCs.
NZer
NZer is offline
PostPosted: Wed Apr 11, 2012 2:06 pm    Post subject: Reply with quote
Hey Purple, is there another site for h6t3.com?
Whats the MPG like over the 2.1, and 2.5?
Do you mind telling us what sort of cost there is in this swap for every thing?
A sad looking 88 Westfalia, MT 2.1 with 150k on the clock and several issues!
insyncro
Banned
insyncro is offline
PostPosted: Wed Apr 11, 2012 3:40 pm    Post subject: Reply with quote
H6T3.com is no longer.
All conversions have been sold. Crying or Very sad
NZer
NZer is offline
PostPosted: Wed Apr 11, 2012 3:45 pm    Post subject: Reply with quote
Stink, what were they charging?? It is a long off dream to give the Managon a good dose of BHP!
Nothing lotto wont fix of coarse!
insyncro
Banned
insyncro is offline
PostPosted: Wed Apr 11, 2012 3:47 pm    Post subject: Reply with quote
I don't know what the retail pricing was, other than worth every penny Wink
purplepeopleeater
PostPosted: Sat Jun 30, 2012 2:35 pm    Post subject: Reply with quote
Well, I think my ADD has kicked in and i'm going to be messing with another engine swap...people keep trying to get me to put a 1.8t in but I have diesel roots and have longed for one in my westy, just haven't due to the complex nature of the TDI conversion.
H6 has been great by the way, even with a stock tranny! this thing would be a dream with the suby 5 speed, but i've decided to sell the swap and if I can get the $ outta the H6 swap i'll use that to fund the TDI.
insyncro
Banned
insyncro is offline
PostPosted: Sat Jun 30, 2012 3:14 pm    Post subject: Reply with quote
Crying or Very sad Crying or Very sad Crying or Very sad
purplepeopleeater
PostPosted: Sat Jun 30, 2012 3:37 pm    Post subject: Reply with quote
I know.... Maybe I'll change my mind.
purplepeopleeater
PostPosted: Sat Jun 30, 2012 3:45 pm    Post subject: Reply with quote
insyncro
Banned
insyncro is offline
PostPosted: Sat Jun 30, 2012 5:19 pm    Post subject: Reply with quote
I can install and regularly service this conversion for any interested East Coasters.
Page 2 of 4
