My H6 Install (EZ30)
Page: Previous  1, 2, 3, 4
xmass
xmass is offline
PostPosted: Thu Mar 30, 2017 7:13 am    Post subject: Re: Ez30d harness Reply with quote
Hi i'm in the process of swapping my 2.1wasserboxer for a subaru ez30D 2001 and i can't seem to find info on how to adapt the harness for the vanagon.
Ive seen for all the other subaru engine exept for H6.
Even if a will figure it by my self ( as an aicraft mechanic for 23 yrs i'm very resourceful ) it woud be nice to have couple hits and a pin out chart for the ecu.
I want to also install the subaru cruise control onto my westy at the same time.
If you guys have info on this please feel free to comment.
Thanks
levi
levi is offline
PostPosted: Thu Mar 30, 2017 12:27 pm    Post subject: Re: My H6 Install (EZ30) Reply with quote
I don't have the pinout info, but your fellow Canadian Tom shiels does.
Just Google tom shiels Subaru wiring harness.
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
xmass
xmass is offline
PostPosted: Thu Mar 30, 2017 5:30 pm    Post subject: Re: My H6 Install (EZ30) Reply with quote
Than'k levi, lot's of info on tom sheild'd site 😁😁
Merci!😉
wesitarz
wesitarz is offline
PostPosted: Thu Mar 30, 2017 9:45 pm    Post subject: Re: My H6 Install (EZ30) Reply with quote
Found this manual for 01 H6.See page 407 I think for the pin out.
http://jdmfsm.info/Auto/Japan/Subaru/Legacy%20Outback/2001/2001MY(H6).pdf
http://www.submariner.org/thepno95/Documents/2001_EZ30D_USDM_ECU_IO_SIGNAL.pdf
kpsamba
kpsamba is offline
PostPosted: Wed Jan 31, 2018 5:24 pm    Post subject: Re: My H6 Install (EZ30) Reply with quote
Help! Need info as to how to connect Vanagon front and rear heater hoses and coolant fill tank to Subaru H6 3.0L engine heater hose connectors.!
Presently I have the coolant fill reservoir in parallel with the heater hoses and the flow of hot coolant to the front heater is extremely marginal/slow!
wesitarz
wesitarz is offline
PostPosted: Wed Jan 31, 2018 7:32 pm    Post subject: Re: My H6 Install (EZ30) Reply with quote
Do you have a diagram of your cooling system?
Page 4 of 4
