mxracer Samba Member
Posted: Tue Nov 29, 2011 5:02 pm Post subject: Need a favor from a late model Ghia owner... |
Hi, I have a favor to ask of someone here.
I recently installed Australian gauges in my 73 Type 3. The Aussie speedometer has a smaller diameter nut where the speedo cable connects.
I've been told by someone from Australia that a late model Ghia has the same diameter shaft where the cable connects.
So... if someone that has a late Ghia and either a spare speedo to check or if someone doesn't mind popping one out to measure with a vernier caliper...I'd be very appreciative.
I measured the back of the Aussie speedo where the nut screws on and it's 15.73mm (15mm) where the U.S. speedo is 17.55mm (17mm) and they are both 1.5 pitch.
Thanks in advance... I hope. |
ghia4mea Samba Member
Joined: July 23, 2007 Posts: 478 Location: Largo Florida
Posted: Tue Nov 29, 2011 5:39 pm Post subject: |
I just measured my Ghia Speedo and it is 17mm. I am in Largo Florida USA.
I have a 1970 Ghia. |
Posted: Tue Nov 29, 2011 6:43 pm Post subject: |
Thanks for the reply. I don't think a 70 is "late enough".
I probably should have been a little more specific. I was told that the 73-74 Ghia had the smaller speedo cable nut. |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Tue Nov 29, 2011 8:01 pm Post subject: |
72-74 - the cable changed when the gauges changed. |
Posted: Wed Nov 30, 2011 10:52 am Post subject: |
by "cable changed" do you mean changed to the 15mm shaft of the speedo cable or just changed in general?
still looking for a confirmation of the 15mm shaft before I order parts. |
bobkat80 Samba Member
Joined: April 15, 2010 Posts: 5 Location: Placerville, CA.
Posted: Sat Dec 03, 2011 9:40 am Post subject: Speedo cable connection |
I have a late '74, just measured it. It is 17 mm. The retainer on the end of the cable that holds it to the speedo is a plastic half- turn thing, not a threaded one.
Good luck.
Bob Young
Sacramento, CA. |
Posted: Sat Dec 03, 2011 9:45 am Post subject: |
Thanks Bob.
That's what I was afraid of and why I wanted to check before ordering.
On a positive note I found someone in Australia who is going to send me the right one. |
