VIN Samba Member
mark tucker Samba Member
Posted: Thu Dec 15, 2011 9:34 pm Post subject: |
the last in & out pump I used I had to aligine the holes and enlarge them,along with aligining&"porting " the hole to the case feed hole,it was way off.not impressed with them. not sure if it was a cb pump.but I have seen them also & the holes/gallys still need attn. (for my liking) |
modok Samba Member
Posted: Thu Dec 15, 2011 10:33 pm Post subject: |
yeah, like all cb parts the basics is good but some finishing is required.
My angle is; if it does not work out, you are still ok.
If the full-flow tapping goes bad and you crack the case................ ouch |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Thu Dec 15, 2011 11:27 pm Post subject: |
modok wrote: |
Drop 2 Advil down the oil fill and that will fix all your oil pump and crank headaches!
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly.
blue77bay Samba Member
Joined: February 11, 2006 Posts: 631 Location: Brisvegas Australia
Posted: Fri Dec 16, 2011 1:12 am Post subject: |
RockCrusher wrote: |
modok wrote: |
Drop 2 Advil down the oil fill and that will fix all your oil pumpand crank headaches!
RC |
_________________ I like hammers. Lots of hammers. Hammers and me go way back.
A large hammer collection is like an instant problem solver
Mark tucker wrote:,wack off as needed |
Posted: Fri Dec 16, 2011 9:52 am Post subject: |
modok wrote: |
mill it down & re tap, you dont need that old oil gally anyway anymore,thats what I did,and it gets the an fitting away from the pully
congratis or you headache&boodyache remadee, will we be seeing it on the superbowell sunday??? |
Posted: Fri Dec 16, 2011 10:54 am Post subject: |
mark tucker wrote: |
That would be AWESOME! _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
modok Samba Member
Posted: Fri Dec 16, 2011 5:30 pm Post subject: |
I guess I'll find out, I imagine I'll have to sign a stack of pages of fine print before they give me a check for the prize money. |
mxracer Samba Member
Posted: Fri Dec 16, 2011 6:24 pm Post subject: |
So I'm kicking around the idea of a cam change. I originally planned on either an Engle 100 or 110. Ended up with a Scat c25. don't ask
So with stock heads with P&P, 1.25:1 rockers and an 1 3/8 exhaust would it be a good move to get a 110?
Also I have CB bigfoot lifters with 2K miles on them, can I just use those lifters? |
modok Samba Member
Posted: Fri Dec 16, 2011 6:32 pm Post subject: |
I forgot the rest of your combo, but I remember stock valves
i don't think the 1.25 rockers help very much. The intake maybe, but the exhaust does not flow much more with over .400 lift, so it's kind of a waste. |
Posted: Fri Dec 16, 2011 6:46 pm Post subject: |
So how far would I have to go to make it worth it. Something like Tim's L3 heads and an 1 1/2 exhaust?
Upgrades are not out of the question. Figure I might as well at least ponder the options while I have it apart. |
modok Samba Member
Posted: Fri Dec 16, 2011 8:07 pm Post subject: |
Really depends on what you want
Even with the stock valves, you can up the duration and CR somewhat if more mid-top end is something you could use.
Some headwork is good if you have the budget, stainless aftermarket ex valves and a 3 angle job does make an improvement
The advantage you DO have, is you have driven it around some already, so you know how it runs as is. you can trade torque at one rpm for torque at another
what do you have to trade? |
Altema Samba Member
Joined: June 20, 2010 Posts: 2904 Location: Lower Michigan
Posted: Fri Dec 16, 2011 11:56 pm Post subject: |
mill it down & re tap, you dont need that old oil gally anyway anymore,thats what I did,and it gets the an fitting away from the pully |
Oh, so NOW you tell us! After I spend all that time getting mine just right and purdy, then have to beat my tin with a hammer!
Paul |
