High Beam indicator comes on but no headlights
Oceanpro907
Oceanpro907 is offline
PostPosted: Tue Dec 13, 2011 9:47 am    Post subject: High Beam indicator comes on but no headlights Reply with quote
I have searched and found numerous threads about the problem when the headlights go out but the high beams work...not my prob.
My headlights went out, last night, on an unlight road, in a blizzard, luckily it was a few miles from my house and I got home by brail.....the rumble strips.
So my headlights and highbeams do not work. Turn signals, orange lights, dash lights, wipers all work.
Any suggestions
Thanks for any help in advance
Oh yea 87 syncro tin top.
HeftySmurf
HeftySmurf is offline
PostPosted: Tue Dec 13, 2011 9:58 am    Post subject: Reply with quote
Check your ignition switch
-Mike
90 GL ZETEC
pioneer1
pioneer1 is offline
PostPosted: Tue Dec 13, 2011 10:07 am    Post subject: Reply with quote
Hi: Take out the headlight and use your meter to check for voltage (key on/switch on) trace back from there.
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
danfromsyr
danfromsyr is offline
PostPosted: Tue Dec 13, 2011 10:12 am    Post subject: Reply with quote
so they don't illuminate at all when you 'flash' by pulling back on the stalk?
this happens every year when the weather gets cold out.
your headlights ALL ground at the grounding star under the dash above the fuse box.
age and temperature increase the resistance to the point where they don't get enough conductivity.
sometimes just pulling the wire off & back on will get them to light, but agood cleaning or an additional ground wire from the headlight wire to a chassis ground screw into a clean piece of metal (painted afterwards to coat/protect).
Altoona
Altoona is offline
PostPosted: Tue Dec 13, 2011 10:27 am    Post subject: Reply with quote
...and your headlight switch and your high beam selector switch.
