What's this Ghia part and Where does it go?
Page: Previous  1, 2, 3, ... 29, 30, 31  Next
vwcomet
vwcomet is offline
PostPosted: Fri Nov 23, 2012 9:55 am    Post subject: Reply with quote
They look like the fasteners for the wood rear base bow for the convertible top. I had similar ones on my 1967 convertible.
sputnick60
sputnick60 is offline
PostPosted: Sat Nov 24, 2012 6:29 am    Post subject: Reply with quote
Thanks for your comment which gives me a place to look though I'm not sure how they go on. I assumed the rear bows mount on with some large coutersunk screws that I have in a labelled bag. If you (or anyone else) happen to have photos it would be great to see.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
2014 Passat B7 130TDI wagon (cheats in tests)
"Have no fear of perfection - you'll never reach it."(Salvador Dali)
Aussie59Cab
Aussie59Cab is offline
PostPosted: Mon Dec 10, 2012 4:23 pm    Post subject: Reply with quote
I have these pieces from my 59 Lowlight Ghia Convertible restoration that I don't know where they go and what they are. Please help.
59 Karmann Ghia Cabriolet
56 RHD Oval
dcrawford3
dcrawford3 is offline
PostPosted: Sun Feb 17, 2013 5:13 am    Post subject: Steering wheel Reply with quote
So I was going through some of the parts that I received from the PO of my Ghia and found this steering wheel.
The markings on the front are partially obscured.
On the back side it says "Made in Italy"
Can anyone identify this wheel, will it fit a Ghia, is it worth refurbishing?
Thanks,
David
'63 Ghia Coupe......
In the battle between a hammer and your skin....
The hammer always wins !
Measure Twice---Cut Once !
John Moxon Premium Member
John Moxon is offline
PostPosted: Sun Feb 17, 2013 6:09 am    Post subject: Re: Steering wheel Reply with quote
Thanks,
David
You might try sending a PM or Email to the original poster in this old topic to see if he found out the ID: http://www.thesamba.com/vw/forum/viewtopic.php?p=556734
None of the links provided work any more.
John.
My 1958 Karmann Ghia
dcrawford3
PostPosted: Sun Feb 17, 2013 6:28 am    Post subject: Reply with quote
Thanks John,
I think the comment "generic aftermarket wheel" just answered my question.
David
ghiarossa
ghiarossa is offline
PostPosted: Fri Mar 01, 2013 5:18 pm    Post subject: Guide tube? Reply with quote
This was amidst the assorted parts in a box I got back with my 71 Ghia cabriolet. Some kind of guide tube?
David Odenwald
1958 VW Karmann Ghia coupe
1971 VW Karmann Ghia cabriolet
hazetguy
hazetguy is offline
PostPosted: Fri Mar 01, 2013 5:50 pm    Post subject: Reply with quote
^^ Clutch cable bowden tube. the bracket attaches to the left side of the transmission.
hazetguy
hazetguy is offline
PostPosted: Fri Mar 01, 2013 5:52 pm    Post subject: Reply with quote
the top pieces look like worn out brake shoe retaining cups.
the next pieces down are thrust washers for setting up type 1 spindles (king and link pin spindles)
ghiarossa
PostPosted: Sat Mar 02, 2013 9:35 am    Post subject: Reply with quote
Thanks for identifying it.
David Odenwald
Altema
Altema is offline
PostPosted: Thu Apr 11, 2013 9:09 pm    Post subject: Reply with quote
Friend who's an ACVW mechanic comes across these installed on the fuel lines of stock VW's at times, but does not know what they are. The bottom tube has a hole that opens to the cavity above, but is straight though otherwise. The top tube seems to be valved or restricted, but he is does not recall if the top tube was connected to a fuel or vacuum line. It does have the VW emblem cast into the body.
Paul
PostPosted: Thu Apr 11, 2013 10:49 pm    Post subject: Reply with quote
It's a fuel shut-off valve to prevent run-on.
Typically seen on 1965 models.
Found this in the gallery:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=610371
Altema
Altema is offline
PostPosted: Fri Apr 12, 2013 7:50 am    Post subject: Reply with quote
No kidding, a factory shut off valve! Examining it, it looks like suction from the inlet side pulls down a diaphragm to open the valve for the discharge side of the pump to feed the carb. Doesn't seem very useful for run-on though since the valve would remain open as long as the engine is physically turning over...
Thanks for the info Everett, this is hugely helpful!
Paul
3foldfolly
3foldfolly is offline
PostPosted: Sun May 05, 2013 10:00 am    Post subject: Reply with quote
Altema wrote:
ghia-13 wrote:
thanks altema!! so on the cam where you have the gear aswlel it goes on opposite side of the cam where the opening is, to just cap off?
That is correct. The raised edge of the plug fits in the groove of the case with the flat side facing out.
Paul
Or flat side in for autostick.
scotty timmerman
scotty timmerman is offline
PostPosted: Tue Jul 09, 2013 3:17 pm    Post subject: Reply with quote
i had this marked to go some where near the glove box but i cant remember where it goes. i have a 1971 ghia
71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
aero3113
aero3113 is offline
PostPosted: Wed Jul 10, 2013 10:08 am    Post subject: Reply with quote
Is it a rubber bumper for when you shut the glove box?
Brassneck
Brassneck is offline
PostPosted: Wed Jul 10, 2013 11:05 am    Post subject: Reply with quote
I was thinking the same thing, except the ones I've seen are solid rubber all the way around.
djway3474
djway3474 is offline
PostPosted: Wed Jul 10, 2013 11:17 am    Post subject: Reply with quote
does not look like a bumper to me. looks like a hole plug. bumpers are usually taller. the flat side goes out. the pointed side has the recess areas so it can squeeze through the hole. probably covers a hole to access a screw or bolt
scotty timmerman
PostPosted: Wed Jul 10, 2013 11:52 am    Post subject: Reply with quote
its not a rubber bumper for the glove box. its plastic and the top is flat. i think it goes some where under neath the dash, i just dont know witch hole.
73 super beetle
danielsan
danielsan is offline
PostPosted: Wed Aug 07, 2013 10:57 am    Post subject: Reply with quote
It holds the faux wood facia in place, preventing lift and fills the mystery holes under the dash. There is one hole near each a pillar and one near the ash tray.
Page 2 of 31
