What's this Ghia part and Where does it go?
Page: Previous  1, 2, 3, 4 ... 29, 30, 31  Next
FoggyDesigns
FoggyDesigns is offline
PostPosted: Wed Aug 21, 2013 4:56 pm    Post subject: Reply with quote
So I was fiddling with my steering wheel today, and these things fell out of the steering column Shocked If anyone could tell me what they are and where they go that would be great, as they are currently in a bag labeled mystery parts.
The bolt as a section cut out of the end of the treads like a self tapping screw.
70coupyel
70coupyel is offline
PostPosted: Wed Aug 21, 2013 8:14 pm    Post subject: Reply with quote
Spring for the turn signal switch.
TheAndante wrote:
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc.
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer
scotty timmerman
scotty timmerman is offline
PostPosted: Wed Aug 21, 2013 10:51 pm    Post subject: Reply with quote
bolt might be one that holds column up.
71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
FoggyDesigns
PostPosted: Thu Aug 22, 2013 8:48 pm    Post subject: Reply with quote
Shocked
that bolt might be important! and thanks for the info!
sellinmyG
sellinmyG is offline
PostPosted: Mon Nov 25, 2013 4:06 pm    Post subject: Reply with quote
Calling in the experts!
I believe this is the last part I have from an old project car I bought, that I haven't already listed or sold. I want to say this is from the convertible top (it was a 1969), any ideas and how much it could potentially be worth would be great!
Loren Premium Member
Loren is offline
PostPosted: Tue Nov 26, 2013 9:58 pm    Post subject: Reply with quote
Yes, those are convertible parts. I would think they would be worth $50-$75, maybe a little more to the righ buyer.
sellinmyG
PostPosted: Wed Nov 27, 2013 9:16 am    Post subject: Reply with quote
Thank you for the clarification, Loren! Cool
oxsign
oxsign is offline
PostPosted: Wed Dec 04, 2013 11:51 am    Post subject: Reply with quote
I've got a new one. Being in a rush I didn't see how this was wired up. Now I can't figure it out and i've fried 2 sets of points. Can anyone help out with a simple wire diagram maybe? The factory ones i've found don't include this piece.
It also comes with 2 barrel fuse holders as well. I'm just lost here and need help, thx.
1971 Squareback, dropped, 1776.
Build thread here.....
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Dec 04, 2013 12:42 pm    Post subject: Reply with quote
It's a rear defroster relay.
Certainly nothing to do with the engine.
If you're burning points, you have them connected to the wrong side of the coil. The points should be to the negative (1) side. The positive (15) side goes to the ignition key.
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
oxsign
oxsign is offline
PostPosted: Wed Dec 04, 2013 12:49 pm    Post subject: Reply with quote
I'll double check that. I was thinking it was something else because of how & where it was mounted on the engine itself, lol. Thanks again.
Mark33563
Mark33563 is offline
PostPosted: Sat Dec 07, 2013 8:59 pm    Post subject: Reply with quote
You should not have a fuel filter there. Place it on the line between the tank and the pump...preferably not near the hot and sparking parts of the car. Between the tank and tunnel up front seems to be a good place.
Where you have it puts additional strain on an inherently weak part: carb intake pipe.
On a beetle the relay resides under the read seat. Not sure the correct location on a ghia. None of mine have had them.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Gallery Classifieds Feedback
Mark33563
PostPosted: Mon Dec 16, 2013 7:07 pm    Post subject: Reply with quote
The relay, at least on a '71 sedan, mounts to the engine bay firewall between the hinge and driver side fender. At least that is where it is located on the sedan I recently purchased.....
Altema
Altema is offline
PostPosted: Tue Dec 17, 2013 7:55 pm    Post subject: Reply with quote
My '70 coupe has a mounting point there too, but I'm using for my bus blower control relays. The defroster is defunct and the wires were burnt, so I do without.
sellinmyG
PostPosted: Sun Dec 22, 2013 11:19 am    Post subject: Reply with quote
I return to this thread in hopes of figuring out another part!
I believe that this part has something to do with air/heat. It looks like this is the metal tube that runs right where the interior bodywork begins to bend to accommodate for the wheel well (it stands vertical.)
I have no clue what it is or what it is called. Any guesses would be appreciated. Very Happy
djway3474
djway3474 is offline
PostPosted: Sun Dec 22, 2013 12:23 pm    Post subject: Reply with quote
Looks like the steering column tube in the picture
sellinmyG
PostPosted: Sun Dec 22, 2013 12:37 pm    Post subject: Reply with quote
edit: I found a picture of my exact part (steering column related) on TheSamba. Thanks for the clarification! Very Happy
FAS
FAS is offline
PostPosted: Thu Dec 26, 2013 7:47 pm    Post subject: back to OXSIGNS question Reply with quote
THIS IS FOR OXSIGNS...that is the defroster relay and mine is mounted exactly the same as yours is. one fuse holder is for that; and the other one is for the backup lights.If you like I could send off a pict or a diagram of the wiring.mine's a 73.
sputnick60
sputnick60 is offline
PostPosted: Tue Jan 07, 2014 5:16 pm    Post subject: Reply with quote
I actually know what this part is and I know where it goes. It off my '66 cabrio. It is located on the side of the Cabrio frame just above the windows and behind the front bow. But where does one buy a replacement?
I've searched KGPR and the Euro Sites but nothing so far. Even asking Kevin Fergusson and Lars Neufer draws a blank so it's something not on the early cabrios.
Anybody?
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
2014 Passat B7 130TDI wagon (cheats in tests)
"Have no fear of perfection - you'll never reach it."(Salvador Dali)
Mark33563
PostPosted: Thu Jan 09, 2014 12:38 pm    Post subject: Reply with quote
Nicholas,
that might be one of 'those' parts you have to fabricate because nobody repops them yet.
hey, you might have a niche market there... Smile
jwold
jwold is offline
PostPosted: Thu Jan 09, 2014 12:43 pm    Post subject: Reply with quote
Tried HOG?
Page 3 of 31
