Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Wed May 01, 2019 10:45 pm Post subject: Re: What's this Ghia part and Where does it go? |
I believe that's the chrome trim of the B-Pillar. I think it screws (2 screws) to the side rear window. (which has a post with 2 "inserts" for accepting the screws).
Or at least that's how I remember the late coupe's being, I last saw mine 3 years ago |
Redlabel6 Samba Member
Joined: October 17, 2016 Posts: 383 Location: Minnesota
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Fri Jun 07, 2019 7:19 pm Post subject: Re: What's this Ghia part and Where does it go? |
I came across this part in my many boxes, and have since identified it as a Fuel Gauge Stabilizer
As I am wiring my Ghia, I don't see this on any of the schematics. Looking at the attachment piece, I believe it mounts on one of the dash stabilizer posts, perhaps alongside the Flasher Relay?
But how or where do I wire it inline? Does the wire from the fuel gauge plug into this, and then I connect another wire to the point on the gas gauge where the sending unit wire goes? Do I need this or not?
If anyone has a pic or schematic showing how it wires inline, please post.
Thanks, Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
NoDents Samba Member
Posted: Fri Jun 07, 2019 7:24 pm Post subject: Re: What's this Ghia part and Where does it go? |
I have no picture, but the mounting screw "slot" is mounted to the screw on the back side of the speedo, and the female spade terminal slides onto the fuel gauge male terminal.
Make visual sense?
Found a YouTube Video: https://www.youtube.com/watch?v=F5LuIpnF_AQ _________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
Posted: Fri Jun 07, 2019 8:15 pm Post subject: Re: What's this Ghia part and Where does it go? |
Thank you Sir, Visually, Yes I understand. I just don't see how it will reach from the speedo to the gauge. I'm away from home for the weekend, but will check the fit when I get home. Thanks again.
2012 Passat-Sold
neon_guru Samba Member
Joined: June 22, 2019 Posts: 23 Location: Birmingham England
Posted: Sat Jun 22, 2019 10:10 am Post subject: Re: What's this Ghia part and Where does it go? |
Hi all I’ve just purchased my first KG and are spending some time getting to know it. It’s a 71 year and I need to know what this part is please. Top left of engine bay
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
Posted: Sat Jun 22, 2019 12:47 pm Post subject: Re: What's this Ghia part and Where does it go? |
Many thanks for you reply. So this can be stripped out if wanted. |
Tomiko Samba Member
Posted: Tue Aug 27, 2019 10:26 am Post subject: Re: What's this Ghia part and Where does it go? |
Been looking around for function , name, and how to connect thus mystery.
It is above the transmission and similar on both sides. I keep suspecting it has to do with heat.
Can anyone enlighten me?
Thank you. |
smuenchrath Samba Member
Joined: February 20, 2005 Posts: 371 Location: Calgary, Alberta
Tomiko Samba Member
Posted: Tue Aug 27, 2019 10:06 pm Post subject: Re: What's this Ghia part and Where does it go? |
Ok, thanks for the info and saving me some time investigating. |
bruehoyt Samba Member
Joined: April 08, 2008 Posts: 180 Location: Columbus, OH
Posted: Tue Oct 01, 2019 7:52 pm Post subject: Re: What's this Ghia part and Where does it go? |
I think this is an aftermarket starter solenoid relay maybe from a mustang. Do I need it in my 71 ghia coupe auto stick? If not, how do I eliminate or better -go back to what should be there. I think it is supposed to have a neutral cut off switch. PS this car won't start.
Posted: Wed Oct 02, 2019 7:46 am Post subject: Re: What's this Ghia part and Where does it go? |
Didn't want to start another thread so checking here. I pulled out my door glass from the boxes and noticed the lift channels (?) had these little wheels attached to them. First time I have seen these, I thought it was just the channel, as I have another cleaned plated set.
I don't see the purpose of these wheels as they don't appear to roll against anything inside the doors. Should I just go ahead and swap these out for the other lift channels I have?
Does this glass look correct for a Ghia convertible? They seemed a bit wonky when I did a pre-fit in the door.
2012 Passat-Sold
Posted: Wed Oct 02, 2019 10:09 am Post subject: Re: What's this Ghia part and Where does it go? |
Convertible glass is different than coupe (rear upper part curved).
But that one has a different shape lower front. I have no idea wha the roller thing is.
Unless it is for an early ghia that I am not familiar with, I would say it is the wrong glass. I know that from 67 to 74 the front of the glass is different. I have not torn apart earlier Ghias
Here is someones classified for teh right glass.
https://www.thesamba.com/vw/classifieds/detail.php?id=1995798
rbsurfguy wrote: |
Jeff |
Posted: Wed Oct 02, 2019 11:10 am Post subject: Re: What's this Ghia part and Where does it go? |
Thank you Sir. Looking at the pic you linked to, it does appear I have the wrong glass for a 71 convertible. It's definitely missing that angled lower section at the bottom front. Maybe for a type 3? Now it makes sense why it didn't fit that well when I mocked it up. Looks like I need to go back to the restoration shop and have them give me the right pieces. They better have my original glass or a decent replacement or someone's going to have problems.
2012 Passat-Sold
aerosilver Samba Member
Posted: Wed Oct 02, 2019 11:12 am Post subject: Re: What's this Ghia part and Where does it go? |
58-59 cabrio door glass, rare glass! |
Posted: Wed Oct 02, 2019 12:07 pm Post subject: Re: What's this Ghia part and Where does it go? |
aerosilver wrote: |
Can you be sure about that? If so, then I should save them for a buyer that may need for a restoration, as opposed to trading them back for my proper year. _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Loren Samba Member
Posted: Wed Oct 02, 2019 12:30 pm Post subject: Re: What's this Ghia part and Where does it go? |
That is early Ghia cabriolet door glass Very hard to find! The roller was discontinued some time in 59? (I believe) though I don't know the exact cut off. Low light door glass is flat at the bottom (like the ones you have) and the later glass is cut upward at the bottom (I will post some images of later glass tonight so you can see the difference). You can sell those, buy the correct glass and still have money left over for other parts. |
