What's this Ghia part and Where does it go?
Page: Previous  1, 2, 3 ... 27, 28, 29, 30, 31  Next
kent70ghia
kent70ghia is offline
PostPosted: Thu Jul 02, 2020 4:09 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Hi I have a 70 Ghia that was an auto stick and converted to a 4 speed. There is a flat wire with a clear plastic cover by the fuse box that I cant figure out where it goes. See the green arrow in the picture. Yea I am going to work on cleaning up the wiring. Thanks
jeffrey8164 Premium Member
jeffrey8164 is offline
PostPosted: Thu Jul 02, 2020 4:14 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
It almost looks like antenna wire. Maybe a previous owners attempt without drilling a hole?
(Compression 8.7:1)
https://www.thesamba.com/vw/forum/viewtopic.php?t=696460&highlight=rose
kent70ghia
PostPosted: Thu Jul 02, 2020 4:30 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
not an antenna wire, it goes into the wiring harness. I am the second owner and have had my car since 1981 or 82. It had the stock AM Sapphire when I bought it.
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Thu Jul 02, 2020 6:00 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
IIRC that is for the key buzzer. Does it go into/from the ignition switch wiring harness?
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
sb001 wrote:
maybe he just snapped cause his car sucked Wink
smuenchrath
smuenchrath is offline
PostPosted: Fri Jul 03, 2020 12:53 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I have had these plugs in my parts stash for quite a few years, but i have no idea where exactly they go and what purpose they serve?
68 Ghia Vert
kent70ghia
PostPosted: Fri Jul 03, 2020 2:35 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
60 ragtop, there was a white wire to the ignition buzzer, swapping it with the foil wire made no difference however, since the buzzer is 50 years old would not surprise me if it is bad.
60ragtop
60ragtop is offline
PostPosted: Fri Jul 03, 2020 3:06 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
The clear wire goes to a single connector via the white wire which goes to the left door switch and then a white? wire goes back to the relay. The other side of the relay should have a red power wire from the fuse box. Looked for a pic but couldn't' find one for you.
Rick
Viktor Cz.
Viktor Cz. is offline
PostPosted: Sat Jul 04, 2020 9:25 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
This is the rocker placement:
// Viktor
Karmann Ghia coupe -66
Passat GTE 2020
kent70ghia
PostPosted: Sun Jul 05, 2020 8:50 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thanks 60ragtop, so what I think you are saying is on the buzzer, there should be a double connector for the white and foil wire. I looked and it does not have one so it is either white or foil. The red power wire is connected correctly. Thanks again for the help.
smuenchrath
PostPosted: Tue Jul 07, 2020 7:27 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thanks for the photo - but i am still confused as to the purpose of these plugs. Is there a hole between the front inner quarter panel that the heater channel/rocker attaches to? The reproduction piece that i have doesn't have anything for the plugs to attach to.
68 Ghia Vert
kman
kman is offline
PostPosted: Tue Jul 14, 2020 5:09 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I believe they are just access holes to inspect or spray in rust preventitive. when i rebuilt mine I drilled those hole and did just that with a long wand.
71 vert build. http://www.thesamba.com/vw/forum/viewtopic.php?t=572951&highlight=dead
Vladiiiii
Vladiiiii is offline
PostPosted: Tue Jul 14, 2020 10:07 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I can confirm that. I also drilles a couple of holes on each side. One goes to the outer rocker (pump that full of wax, and make sure it has drain holes!), and the other to the heater channel (never use wax, only high/er temperature rust protective coating/paint for this one)
Vlad
Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746
smuenchrath
PostPosted: Tue Jul 14, 2020 12:53 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thanks all - very helpful.
68 Ghia Vert
688GUY
688GUY is offline
PostPosted: Sun Aug 02, 2020 3:35 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
This fell out when I was installing my new steering column bearing and blinker switch. I'm assuming it came off when I disconnected the steering box donut and banged the column up to get the old bushing out. WTF is it?
60ragtop
60ragtop is offline
PostPosted: Sun Aug 02, 2020 4:01 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
see # 1
installed at the top of the collapsible cage
Rick
688GUY
688GUY is offline
PostPosted: Sun Aug 02, 2020 4:44 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Cool, I knew it had to come from around there someplace! It looks like I could slide it back on and bend the tabs over to hold it and not have to take it all apart again, yes?
688GUY
688GUY is offline
PostPosted: Mon Aug 03, 2020 5:48 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Got it, thanks 60ragtop!
Torbjorn
Torbjorn is offline
PostPosted: Mon Aug 17, 2020 1:24 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Any idea where this part would go on a -68 cabriolet?
Regards
Torbjorn
udo dreisoerner
udo dreisoerner is offline
PostPosted: Tue Aug 18, 2020 12:22 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Regards
Torbjorn
my 69 ghia coupe have this item at one of my pedals. saw it somewhere in part-list. make you a pic next days
Searching for a 1956 lowlight karmann ghia with a VIN number between1273054 and 1273440, and the matching engine with an Engine Number between
1525510 and 1525519 PLEASE OFFER ME ONLY THE CARS THAT I'M LOOKING FOR, THANKS!!
udo dreisoerner
PostPosted: Tue Aug 18, 2020 3:40 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Regards
Torbjorn
find it at partlist "beetle 1972"
"Anschlag für Kupplungsfußhebel" means "Stop for clutch lever" (google translations)
Page 28 of 31
