What's this Ghia part and Where does it go?
Page: Previous  1, 2, 3 ... , 29, 30, 31  Next
69 GVert
69 GVert is offline
PostPosted: Sat Aug 22, 2020 1:03 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
[quote="crocteau"]
69 GVert wrote:
This photo may help...
Great, now that part is on order, all I need is the rivet. And of course the rubber tube for the fresh air valves. Used ones don't even survive an install attempt unless they are vinyl. I only found 2 vinyl ones in my parts bin, so drivers side I guess is good to go, passenger side will have some Gorilla Tape in there at first.
Aircooled? Drive one a day, that's all I ask!
crocteau
crocteau is offline
PostPosted: Sat Aug 22, 2020 7:06 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
69 GVert wrote:
... all I need is the rivet.
You're in luck; there's a sticky for that! Wink
NoDents
NoDents is offline
PostPosted: Sat Aug 22, 2020 7:24 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
sputnick60 wrote:
69 GVert wrote:
...... all I need is the rivet.
Have a look through this thread for information about the rivet
https://www.thesamba.com/vw/forum/viewtopic.php?p=3338846&highlight=#3338846
Nicholas
I ordered the rivets for my restore. Unfortunately I could only buy in a set of 100, when I only needed 2. My loss is your gain. If they can survive a trip though the us mail in a letter envelope, I can send some out to you guys. PM me your snail mail addresses. Don't want to get in the business of having to package these things up and spend $8+ on shipping.
No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020
69 GVert
69 GVert is offline
PostPosted: Mon Aug 24, 2020 8:17 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I found these in a pile of carpet bits under my rear glass, not sure whether they are Ghia parts or not...
Two large pieces:
And two smaller ones:
Confused
xzener
xzener is offline
PostPosted: Tue Aug 25, 2020 6:55 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Can you guys recommend where to buy these floating nuts? It's the anchor point for the heat riser tin coupling.
My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>!
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Tue Aug 25, 2020 7:31 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
One place with a quick search of 6 mm cage nuts
https://www.mcmaster.com/cage-nuts/
https://www.amazon.com/Cage-Stainless-Steel-30-piece-Captive/dp/B01KJJTLO2
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
sb001 wrote:
maybe he just snapped cause his car sucked Wink
xzener
xzener is offline
PostPosted: Tue Aug 25, 2020 7:47 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thanks Rick. Wasn't sure of the name. $15!?!? I think I will come up with something else. I'm thinking, replace the nut in a PC rack cage nut... Plenty of those kicking around work.
60ragtop
60ragtop is offline
PostPosted: Tue Aug 25, 2020 7:51 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Cheap ass VW owners Wink
https://www.newark.com/tr-fastenings/m6-cnstnz25/c...Mechanical
Rick
xzener
xzener is offline
PostPosted: Tue Aug 25, 2020 7:53 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I resemble that. 😆
I was able to drill/tap one of these PC rack anchor nuts for M6X1. This should work nicely. Thanks again Rick.
69 GVert
69 GVert is offline
PostPosted: Sun Aug 30, 2020 4:54 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Two large pieces:
Well, not sure where they came from, but I noticed I'm missing the tarboards on the wheel arches back of the top frame covers, and these might be just enough to fit once I cut them down...
kman
kman is offline
PostPosted: Mon Aug 31, 2020 5:24 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
69 GVert wrote:
Two large pieces:
This one is definitely the padding for the wheel arch.
71 vert build. http://www.thesamba.com/vw/forum/viewtopic.php?t=572951&highlight=dead
Viktor Cz.
Viktor Cz. is offline
PostPosted: Mon Aug 31, 2020 10:09 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Yes, definitely
// Viktor
Karmann Ghia coupe -66
Passat GTE 2020
69 GVert
69 GVert is offline
PostPosted: Mon Aug 31, 2020 9:01 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Viktor Cz. wrote:
Yes, definitely
That's the part alright.Thanks to you guys for confirming that I have coupe pieces. I think I can trim them to fit into the smaller space in the convertible.
And wouldn't you know it, while I was in the back I happened to open the seat bottom to see if there was any more pieces hiding under there...
Once I got the light in there I saw that the vertical bit that comes up from the heater pipe was smushed in on the driver's side. I have a vague memory of trying to use a hydraulic press to push out the passenger side quarter panel back in the '90's, before I found a straight fender and cut the whole damaged part off and replaced it. Must have repressed the memory of doing that. Embarassed
Now to figure how to unpress it... Evil or Very Mad
Marcdeb
Marcdeb is online now
PostPosted: Tue Sep 01, 2020 3:59 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Viktor Cz. wrote:
Yes, definitely
Does anyone have information as to how Karmann mounted this padding?
Were they just held in place with metal tabs? Were they glued down as well? If so, any suggestions on type of glue?
And then was the carpet then glued to these?
I have the adhesive backed rubber sheet type sound proofing but it seems so permanent? If moisture gets under the new style rubber sheets, I don't see that it could breath and dry out.
I'd like to have someway to be able to still get to the metal to check for rust in the future if needed.
Marc
1971 Karmann Ghia Cabriolet
Restoration thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc
rich caramadre
rich caramadre is offline
PostPosted: Tue Sep 01, 2020 6:28 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
This came with a Ghia a recently picked up. I don't know what it's for. it does have a VW logo on the back.
NoDents
NoDents is offline
PostPosted: Tue Sep 01, 2020 6:30 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
On my Ghia it was used for the rear window defroster. Located under dash on the left side of the steering wheel. I have seen the same switch referenced as a done light switch too.
No Dents
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Tue Sep 01, 2020 7:10 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Agreed, my switch like that connects to rear window defroster. You can also try checking the wiring schematic and it may match the colors of the wires.
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
PostPosted: Tue Sep 01, 2020 9:38 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
It's also a Bus rear dome light switch that goes on the left side of the speedo pod to turn the rear dome light on/off
rich caramadre
PostPosted: Wed Sep 02, 2020 7:19 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thanks for the info guys. My Ghia is a 58' so I think it will go in the parts bin. Smile
Propdriver
Propdriver is offline
PostPosted: Thu Sep 03, 2020 3:00 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Looking for help with identifying this part and where the hose connects to. Off a 70 autostick, drivers side... pic taken from under vehicle looking up.
Right now the hose is just loose resting above the transmission.
Also, almost looks like the open port should have a hose connected to it as well.
Any thoughts on that?
Thanks
Page 30 of 31
