What's this Ghia part and Where does it go?
Page: Previous  1, 2, 3 ... 29, 30, 31
Redlabel6
Redlabel6 is offline
PostPosted: Fri Sep 04, 2020 5:03 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Nothing like that under my '73 AutoStick...
No idea.
David
1973 Karmann Ghia Coupe
2005 Passat TDI
2005 Jetta
canadianeh
canadianeh is offline
PostPosted: Thu Sep 10, 2020 9:46 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I have that same assembly under my 70 Ghia, 4 speed.
Were there gas heaters that came tunnel mounted? This device hooks up to a "box" that intercepts the hot air from the heater pipes before heading into the cabin. My car does have a heater light on the dash but no switch to activate the heater.
Propdriver
Propdriver is offline
PostPosted: Thu Sep 10, 2020 4:05 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thanks canadianeh for the insight,
I do believe I have the same heater as the pic on pg 24 on this thread.
The hose going into the engine bay has been cut so Iím not sure where it is supposed to connect up on the engine side but at least I have an idea on narrowing the search.
I also have a light on the dash that I have no idea what itís function is so Iíll assume itís heater related.
Thanks again eh,
canadianeh
PostPosted: Fri Sep 11, 2020 6:57 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
No problem eh.
I will likely remove the heater from the car. The "exhaust" pipe is missing and it looks pretty rough overall.
69 GVert
69 GVert is offline
PostPosted: Fri Sep 11, 2020 9:25 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
xzener wrote:
I resemble that. 😆
I was able to drill/tap one of these PC rack anchor nuts for M6X1. This should work nicely. Thanks again Rick.
I just found a bag of 5 of these in my 6mm hardware drawer. Came with some rack mount something or other years back. Yep 6X1.0 metric... Have several drawers dedicated to the 10-32 ones as well.
Aircooled? Drive one a day, that's all I ask!
pkbghia
pkbghia is offline
PostPosted: Sat Oct 10, 2020 10:16 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Any idea what the silver button is to right of steering column.
69 GVert
69 GVert is offline
PostPosted: Sat Oct 10, 2020 10:58 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Dunno, but I've seen both horn buttons and cigar lighters that look like that.
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Sat Oct 10, 2020 11:07 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Did you look under the dash to see if it is connected to anything? That might give you some indication what it's connected to. I have the same empty slot on mine, just deciding what I want to place there.
Jeff
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
pkbghia
pkbghia is offline
PostPosted: Sat Oct 10, 2020 12:59 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
The picture is some thing I saw online. I had found one of those buttons loose in the glove box of my 1970 ghia, wasnít sure what it was or where it went. Saw it in this picture and wondered if someone knew.
Page 31 of 31
