KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Mon Jan 30, 2017 8:10 pm Post subject: Re: What's this Ghia part and Where does it go? |
c21darrel wrote: |
me too.
You know, Darrel ... you could have really saved yourself a lot of time and effort if you had just bought the 1967 model year Karmann Ghia that you obviously wanted in the first place.
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2876 Location: Auckland, New Zealand
Posted: Mon Jan 30, 2017 9:15 pm Post subject: Re: What's this Ghia part and Where does it go? |
KGCoupe wrote: |
c21darrel wrote: |
me too. :wink:
:wink: |
I second that. I thought I was buying a '67 but it was a '68. Now I have a smell of petrol (gasoline for those in the New World) in the car every time I do a right turn. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
c21darrel Samba Member
1967Ghia Samba Member
Joined: September 29, 2015 Posts: 126 Location: Toronto, Canada
Posted: Sun Feb 19, 2017 6:18 pm Post subject: Re: What's this Ghia part and Where does it go? |
ok... here's some parts... what are they and where do they go???
(took the car apart in 2010... then it sat... started putting it together a couple weeks ago and I'm having some trouble remembering everything... probably many more questions to post...)
thanks!
mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2649 Location: Gullane, Scotland
Posted: Mon Feb 20, 2017 7:21 am Post subject: Re: What's this Ghia part and Where does it go? |
mcdonaldneal wrote: |
I'll give it a go...
1. Preheat tube. Part of the engine tin, right side. Connects to a corrugated hose that leads to the oil bath air filter.
2. Metal collars for inside the 'accordion tubes' that connect the heat exchangers to the cabin heat ducts. Two per tube. That whitish stuff is asbestos, so handle with care.
3, 4. Not sure!
5. Look familiar, plugs for somewhere on the brakes!
6. Clips to hold brake lines to the body.
Good luck! |
Thanks! I used an EMPI air cleaner for the time being so I'll put #1 in the bin with the oil bath filter thing
Does #2 go under the car? (you can reply in the other thread I posted about how to hook up the fresh air hose) I looked below and it looks like I just need two black plastic accordian hoses with hose clamps at either end... do I need those? where would they go exactly? still a little confused
Thanks! |
jwold Samba Member
Joined: September 30, 2008 Posts: 2088 Location: Portland, OR
Posted: Mon Feb 20, 2017 12:14 pm Post subject: Re: What's this Ghia part and Where does it go? |
Just my .02 but I'd ditch the empi cleaner and run with the stock.
That pre-heat was there for a reason.
Yes, those #2 go on those accordion tubes that connect the heater box to the car so you have heat. Look under the rear passenger seats for where the heat comes in. On the outside of the cabin is where those accordion tubes go. They are threaded so you can turn and shorten/lengthen as needed. IIRC. |
olspeed Samba Member
Joined: May 01, 2008 Posts: 489 Location: In the shadow of Denali, I still don't give a damn how they do it outside
Posted: Mon Feb 20, 2017 1:45 pm Post subject: Re: What's this Ghia part and Where does it go? |
#3 should be the seal for where the fuel filler tube goes into the body, it looks just like the one I just replaced on my Bug _________________ 66- Ghia
76-Beetle |
Posted: Mon Feb 20, 2017 7:35 pm Post subject: Re: What's this Ghia part and Where does it go? |
ok thanks! |
Posted: Mon Feb 20, 2017 10:51 pm Post subject: Re: What's this Ghia part and Where does it go? |
Got another one... This one worries me... As I feel it should have been put somewhere and looks important
Sudar Samba Member
Joined: May 18, 2015 Posts: 33 Location: Stewartstown, PA
Posted: Tue Feb 21, 2017 6:46 am Post subject: Re: What's this Ghia part and Where does it go? |
1967Ghia wrote: |
Here's a link to a cable I made and how it installs
http://www.thesamba.com/vw/forum/viewtopic.php?p=7698780&highlight=#7698780 _________________ 1968 Ghia Coupe AKA "Harley"
1969 Beetle Standard AKA "Angus" |
Posted: Tue Feb 21, 2017 7:30 am Post subject: Re: What's this Ghia part and Where does it go? |
thanks! i'm going to have to look into this more... i'm not sure if i have all the parts... that spring thing that goes under the engine... not sure if it's there? ill have to investigate
thx! |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Tue Mar 14, 2017 4:24 pm Post subject: Unidentified Hazet tool |
Although not technically a Ghia part, this tool came from the man who introduced me to VWs and he owned 2 Ghias. I have had this tool for over 30 years and only today did I notice it said Hazet on it.
Can anyone tell me what it is and if it has any value? The 6-point box end is 13 mm and the hex drive side is 14 mm. Given it's shape I imagine it was a purpose built tool.
Thanks,
Emil
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Tue Mar 14, 2017 4:35 pm Post subject: Re: What's this Ghia part and Where does it go? |
mercedes oil drain/service wrench. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Tue Mar 14, 2017 5:23 pm Post subject: Re: What's this Ghia part and Where does it go? |
Thanks for the info guys.
Oddly enough the man, my neighbor growing up, never owned a Benz nor did I ever see him working on one.
The tool is NoVAs if he wants it, I will probably never own a MB. _________________
kiwighia68
smuenchrath Samba Member
Joined: February 20, 2005 Posts: 371 Location: Calgary, Alberta
Posted: Thu Apr 13, 2017 9:39 am Post subject: Re: What's this Ghia part and Where does it go? |
Hi,
Any idea what these washers are for?
They were in a box of parts from my 68 Ghia vert which was partially disassembled when i purchased it. I have four of them in total. _________________ 68 Ghia Regatta Blue Convertible
69 Ghia Toga White Coupe
74 Westfalia |
trelms Samba Member
Posted: Fri Apr 14, 2017 10:19 am Post subject: Re: What's this Ghia part and Where does it go? |
They look like seatbelt mounting washers....the floor ones.
_________________ '74 Ghia Vert SOLD |
