Jtjimmie Samba Member
Posted: Wed Jul 05, 2017 11:41 am Post subject: Re: What's this Ghia part and Where does it go? |
4965 Ghia Coupe - This part is between the rear wheel well and fender panel (on the inside, accessible from the engine compartment), one on each side.
It is sewn cheesecloth-like material stuffed with wool, or similar material.
What is its purpose?
c21darrel Samba Member
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Thu Jul 06, 2017 9:24 am Post subject: Re: What's this Ghia part and Where does it go? |
Thank you! |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Mon Oct 30, 2017 9:24 am Post subject: Re: What's this Ghia part and Where does it go? |
OK, as I get ready to reassemble my Ghia, in the coming months, I'm trying to get clarity on a few things. In the below pic, I found this hole coming into the area on the right side where the tail light housing is located. Is this for the wiring to that tail light? Or is it for some kind of drain tube?
I am then confused about this hole. Could it be where the old air breather tubes ran, or is it where the battery and other cables route to the starter?
And this pic, on the left side. One hole is obviously for the wiring harness, not sure which. The other I would refer to my first question, and the small hole I assume is for the cable to pop the trunk. Can I get a confirmation please?
And finally a question re the wiring harness, when I run from the front, I see where it drops down from under the dash, near where the fresh air tube is located. Does it then run to the back under the door sill and then through the hole at the back, or do I somehow run it inside the area where the heat runs? and if so, suggestions on how to guide it? Run some kind of wire to hook it and pull through? Very confused on this point.
Thanks! _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Mon Oct 30, 2017 10:36 am Post subject: Re: What's this Ghia part and Where does it go? |
rbsurfguy wrote: |
That's the pass through for your rear window drain tube. The second larger hole on the driver's side is for the harness.
rbsurfguy wrote: |
And finally a question re the wiring harness, when I run from the front, I see where it drops down from under the dash, near where the fresh air tube is located. Does it then run to the back under the door sill and then through the hole at the back, or do I somehow run it inside the area where the heat runs... |
For the '71 the harness runs along the floor beside the channel, not through it. (see pics from Nicholas at https://www.thesamba.com/vw/forum/viewtopic.php?t=314838)
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2876 Location: Auckland, New Zealand
Posted: Mon Oct 30, 2017 10:41 am Post subject: Re: What's this Ghia part and Where does it go? |
rbsurfguy wrote: |
Thanks! |
Having been where you are now, here are my suggestions:
1. The hole above the R side rear wheel arch is not for the taillights wiring. Those wires run from left to right inside the engine compartment (from the main wiring loom). I used that hole above the R rear wheel arch for a second wiring loom (5 wires) running from the engine in front of the dash so that I can fit additional gauges later. Maybe tach, oil pressure and engine temp.
2. The hole lower down in the R rear wheel arch area may be for the vent you mention - if you have the US system. We don't have that elsewhere in our Ghias, as far as I know.
3. The large hole in the L side (third photo) is for the main wiring loom. I threaded my old wiring loom from the back towards the front. It's easier that way to get it through that hole. It runs from there to the area in front of the firewall (R wheel arch area behind the R quarter panel) and then through a hole to UNDER the L door sillplate; then up behind the panel in front of the door. From there it goes into a hole into the area behind the dash.
The holes are small and the edges sharp. I would suggest that you make sure you have the right protective grommets in place at every hole. Coated with dishwashing liquid/water mix to facilitate the progress through the holes. It will also help if you have heatshrink over the front of the wiring loom to keep all the loose wires secure during their progress from the engine compartment to in front of the dash.
Good luck. You're at an exciting (and challenging) part of your restoration. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
Posted: Mon Oct 30, 2017 1:42 pm Post subject: Re: What's this Ghia part and Where does it go? |
rbsurfguy wrote: |
Is this for the wiring to that tail light? |
I forget to mention that if you look up under the overhang just above the deck lid hinges you should see some openings and short squared-off metal tabs that are supposed to help hold the wiring in place as it crosses from the driver's side to the passenger side of the engine compartment where the wire to the tail light passes by the tar board should you choose to install it. The wire to the license plate light splits off just before that point and can be held out of the way by the rain tray. |
Posted: Mon Oct 30, 2017 6:23 pm Post subject: Re: What's this Ghia part and Where does it go? |
Thanks as always Crocteau and Kiwi. I knew someone would have an answer. I'll have to locate those drain holes on the inside, so I can attach the tubes properly. Crocteau, I will have to look for those little tabs to run the wires to the right side and LP light. I had a bunch of those tar board tabs removed so I can put sound mat and chrome sheet metal or some kind of cover. Will figure out if the wire tabs were removed. Thanks fellas! _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Posted: Mon Nov 06, 2017 1:26 pm Post subject: Re: What's this Ghia part and Where does it go? |
Can someone remind me what connects to this relay? Emergency Flashers?
I seem to remember it was mounted on one of the little support posts near the wiring/fuse panel, and the were a couple grounding plugs hooked to that same post. Clarification please????? _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Nov 06, 2017 2:54 pm Post subject: Re: What's this Ghia part and Where does it go? |
turn signal relay _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Mon Nov 06, 2017 7:35 pm Post subject: Re: What's this Ghia part and Where does it go? |
Thank you Sir. _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
alansvwTwinCab Samba Member
Joined: December 28, 2005 Posts: 164 Location: Sydney, Australia
Posted: Wed Nov 29, 2017 8:54 am Post subject: Re: What's this Ghia part and Where does it go? |
I have some rubbers i didnt label and need help working out where they go.
this thick rubber around 4ft
and this rubber, its which is about 6ft long
Posted: Wed Nov 29, 2017 9:43 pm Post subject: Re: What's this Ghia part and Where does it go? |
I thought that too but no its not the engine seal. Part #2 is close to the rubber that goes under the aluminium strip but no its not.
I'm thinking have I got some old rubbers from my Lbug mixed in with the ghia rubbers? |
Posted: Thu Dec 07, 2017 1:36 pm Post subject: Re: What's this Ghia part and Where does it go? |
Ok, digging through my boxes of parts to clean, I came across the below items. The first two look like some type of cable brace. The third one I thought was part of the license plate mounting bracket but the holes don't match, then I thought it must hold something under the dash. I defer to the experts!
2012 Passat-Sold
Posted: Thu Dec 07, 2017 4:09 pm Post subject: Re: What's this Ghia part and Where does it go? |
rbsurfguy wrote: |
This piece goes under the dash, between the steering column assembly and the metal of the dash. There should be matching bolt holes. _________________ Festina lente - hasten slowly
Resto completed Dec 2015 |
Posted: Thu Dec 07, 2017 8:37 pm Post subject: Re: What's this Ghia part and Where does it go? |
Noted, thanks Kiwi! _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4573 Location: St Charles, MO
Posted: Thu Dec 21, 2017 4:34 pm Post subject: Re: What's this Ghia part and Where does it go? |
Is this a Ghia knob of some sort? Where does it go, and to what years, Yeah, I know this knob is missing a domed cap. part number on the base of the knob is 131 255 569. Thanks for any help!
Bill
_________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
