rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Tue Feb 06, 2018 12:57 pm Post subject: Re: What's this Ghia part and Where does it go? |
Yes, the little back tube.
The L-shaped tube is for overspill when filling the tank at the gas station and for water that might otherwise collect during washing or when driving in rain.
PS I'm a teacher and I should be clearer in my explanations. Imagine a fist to the forehead here.[/quote]
Got it Kiwi, figured that was the case. And just to add a pic to your request:
_________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Posted: Mon Mar 26, 2018 12:43 pm Post subject: Re: What's this Ghia part and Where does it go? |
Continued to clean old parts in preparation for reassembly. While doing so, I came across these little plastic items. Now I know they go on the rail just behind the doors between the convertible hinges and the top, protection cover? That said, does anyone know what they are called and if anyone sells them?
I seem to recall they were held in place with a bit of contact cement and then I believe the front outer screw down for the top, or a snap for the tonneau cover. it looks like the ends are gone where they were held in place. Any idea where I can purchase replacements? Thanks.
2012 Passat-Sold
smuenchrath Samba Member
Joined: February 20, 2005 Posts: 371 Location: Calgary, Alberta
Posted: Mon Mar 26, 2018 2:53 pm Post subject: Re: What's this Ghia part and Where does it go? |
I do know that Karmann Ghia Parts & Restoration sells this trim part. Their website is currently down, but i believe it is called 'CV Side Panel Cover Strip'
Here is a post which references the part number shows how it fits together:
https://www.thesamba.com/vw/forum/viewtopic.php?t=153088&highlight=convertible+trim _________________ 68 Ghia Regatta Blue Convertible
69 Ghia Toga White Coupe
74 Westfalia |
Posted: Mon Mar 26, 2018 7:10 pm Post subject: Re: What's this Ghia part and Where does it go? |
Thank you Sir, I looked through my KGPR catalog and found the part you mentioned. Also checked out the link. Appreciate that! _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
JayFab Samba Member
Joined: April 29, 2012 Posts: 31 Location: Franklin, TN
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Wed Apr 04, 2018 1:53 am Post subject: Re: What's this Ghia part and Where does it go? |
JayFab wrote: |
I thought I labeled everything!!
Two clips w/screws
(upfront for the air vent cables, maybe?)
1970 Coupe
Nope. These go in the doors to assist keeping the door seal in place. The edge of the seal is held in by the clip. The idea is to stop the seal curling in the crease behind the accent lines. one per door... i think.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Posted: Fri Apr 06, 2018 9:24 am Post subject: Re: What's this Ghia part and Where does it go? |
In reference to the pic below of positive battery cable, is the small wire used to attach to any specific additional components, or can this be used to power the relay #30 for a hard start relay set up? I plan to mount the battery under the seat, and the relay would be mounted there as well close to the battery and starter.
Thanks,
Jeff
2012 Passat-Sold
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Apr 06, 2018 9:36 am Post subject: Re: What's this Ghia part and Where does it go? |
yes it can be used on anything with direct unfused battery voltage. Make sure you use an inline fuse. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Fri Apr 06, 2018 9:46 am Post subject: Re: What's this Ghia part and Where does it go? |
Thanks Rick, yes an inline fuse would be part of the wiring in-line, or a relay with the built in fuse, modern style. _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Redlabel6 Samba Member
Joined: October 17, 2016 Posts: 382 Location: Minnesota
Posted: Fri Apr 06, 2018 10:01 am Post subject: Re: What's this Ghia part and Where does it go? |
sputnick60 wrote: |
JayFab wrote: |
Two clips w/screws
1970 Coupe
Nicholas |
Hmm, I think maybe it is the vent cables based on the little twist on one side. I know they are a pain to get to!
d _________________ 1957 Oval Window Beetle
1973 Karmann Ghia Coupe
https://www.thesamba.com/vw/forum/viewtopic.php?t=666792&highlight=73+coupe |
NoDents Samba Member
Posted: Wed Apr 18, 2018 8:36 pm Post subject: Re: What's this Ghia part and Where does it go? |
Redlabel6 wrote: |
sputnick60 wrote: |
JayFab wrote: |
Two clips w/screws
1970 Coupe
Nicholas |
d |
If the metal under the paint is brass, then they are for the door weather strip.
I knew where they came from, just not their purpose. |
Posted: Thu Apr 26, 2018 8:51 am Post subject: Re: What's this Ghia part and Where does it go? |
Just wanted to confirm this bracket/relay/fuse holder is for the back up lights, or for another item??
It looks like a bracket that would mount on one of the posts under the dash, so wanted to clarify. Should it be mounted there or somewhere closer to the tailights?
Also, I assume I can use this type of bracket set up for installing a headlight relay system as sketched below? Thoughts?
Thanks,
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Posted: Thu Apr 26, 2018 8:57 am Post subject: Re: What's this Ghia part and Where does it go? |
Not to try to throw you completely off but I do recall a similar bracket and relay hanging off the coil mount on the engine. Relay was for rear window defroster and 2 fuse holders for other items.
See below "low quality" picture
_________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
Posted: Thu Apr 26, 2018 9:02 am Post subject: Re: What's this Ghia part and Where does it go? |
Thank you Sir, I believe you are correct. Looking at your pic I remember that placement on my stock engine. I think one fuse may have been for back ups or something else. but don't recall. Thanks. _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Posted: Thu Apr 26, 2018 9:04 am Post subject: Re: What's this Ghia part and Where does it go? |
Was just checking a wiring diagram. One fuse was probably FOR the defroster relay, other for backup lights. _________________ No Dents
Posted: Thu Apr 26, 2018 9:39 am Post subject: Re: What's this Ghia part and Where does it go? |
Yeah, I was thinking the same thing. Thanks
2012 Passat-Sold
Posted: Wed May 09, 2018 10:09 am Post subject: Re: What's this Ghia part and Where does it go? |
Any idea what this is? I don't recognize this as a Ghia part.
https://www.thesamba.com/vw/classifieds/detail.php?id=2166725 _________________ 68 Ghia Regatta Blue Convertible
74 Westfalia |
Posted: Wed May 09, 2018 12:33 pm Post subject: Re: What's this Ghia part and Where does it go? |
looks like a folding ragtop front header bow. _________________ Rick
tasb wrote: |
sb001 wrote: |
