rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Mon Aug 06, 2018 11:14 am Post subject: Re: What's this Ghia part and Where does it go? |
Exploring around, reintroducing myself to my Ghia, I noticed these bolts attached to the beam. If you look closely, they are on the drivers side, just left and below the steering coupler, see arrows:
Can someone tell me what attaches here? Is it the ground wire/cable on the steering coupler I have seen in other pics? I can't remember what exactly attaches here..As always, help is appreciated.
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2867 Location: Auckland, New Zealand
Posted: Mon Aug 06, 2018 11:22 am Post subject: Re: What's this Ghia part and Where does it go? |
rbsurfguy wrote: |
Jeff |
They look like the adjustment bolts for the turning circle. The Pitman arm should connect with the inner parts of those bolts to stop the wheels turning further left or right, as the case may be. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Hokie87 Samba Member
Joined: May 27, 2010 Posts: 280 Location: Richmond, VA
Posted: Mon Aug 06, 2018 3:56 pm Post subject: Re: What's this Ghia part and Where does it go? |
TieDyedHippie wrote: |
New member here and I'm happy I just spent the time looking through this whole thread before posting myself. My gf just got a 69, and it runs fine, but I noticed this cable not attached to anything other than a lever.
My issue though is that my engine is different. Still trying to figure out where the loose end attaches.
*** Update. A car friend texted me that we have an aftermarket air cleaner, so there is no oil bath air cleaner to attach it to. I guess it was left on there anyway by a previous mechanic. I hate loose cables. |
When you get the correct air cleaner, it goes here ('68 but same idea):
Viktor Cz. Samba Member
Joined: July 08, 2009 Posts: 68 Location: Sweden / Jönköping
Posted: Mon Aug 06, 2018 11:33 pm Post subject: Re: What's this Ghia part and Where does it go? |
Found these in one of my KG boxes but can't remember where it belongs!
Are they KG-parts?
_________________ // Viktor
Karmann Ghia coupe 1966
VW ID.4 2023 |
Posted: Tue Aug 07, 2018 9:23 am Post subject: Re: What's this Ghia part and Where does it go? |
kiwighia68 wrote: |
rbsurfguy wrote: |
Jeff |
They look like the adjustment bolts for the turning circle. The Pitman arm should connect with the inner parts of those bolts to stop the wheels turning further left or right, as the case may be. |
So you are saying this is the stopping points for the Pitman arm, ok that makes sense, thanks Kiwi _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
bnam Samba Member
Joined: July 02, 2006 Posts: 2931 Location: El Dorado Hills CA/ Bangalore, India
Posted: Fri Aug 24, 2018 3:39 am Post subject: Re: What's this Ghia part and Where does it go? |
Any idea what this yellow bracket in the top middle(ish) is for on my 65KG? _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
advCo Samba Member
Joined: May 27, 2017 Posts: 373 Location: Houston, TX
Posted: Fri Aug 24, 2018 6:57 am Post subject: Re: What's this Ghia part and Where does it go? |
bnam wrote: |
Any idea what this yellow bracket in the top middle(ish) is for on my 65KG? |
One or both of my cars had a ground strap attached to the bolt on the backside. Can't remember for which component.
Also I think it would hold in place the piece that is meant to cover up the back side of the dash, but I may be wrong... _________________ "He pulled the mirrors off his Cadillac ‘cause he doesn’t like it looking like he looks back"
'68/'70 Ghia Coupe Project
'70 Westy Project - Champagne I Wannabe
A bunch of vintage Japanese motorcycles
"Much ingenuity with a little money is vastly more profitable and amusing than much money without ingenuity." -A. Bennett |
NoDents Samba Member
Posted: Fri Aug 24, 2018 7:07 am Post subject: Re: What's this Ghia part and Where does it go? |
Viktor Cz. wrote: |
Are they KG-parts?
I believe these are for the brake pedal to retain the plunger arm (wrong name?) on the pedal.
I recently purchased a new one for my car. _________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3804 Location: Georgia
Posted: Fri Aug 24, 2018 11:38 am Post subject: Re: What's this Ghia part and Where does it go? |
NoDents wrote: |
Viktor Cz. wrote: |
Are they KG-parts?
I recently purchased a new one for my car. |
No it isn't. I wish I knew what they are but they obviously support a cable or wire harness. As I work on my Ghia this weekend I'll look for them. The one for the brake pedal is C-clip but has the same raised surround to help keep the return spring from popping out.
Unfortunately, this is the only photo I have of my disassembled pedal assembly. The clip is in the bag. |
Posted: Fri Aug 24, 2018 11:49 am Post subject: Re: What's this Ghia part and Where does it go? |
You're right... a "C" clip.
Us old pharts have bad memories sometimes. _________________ No Dents
Posted: Mon Sep 03, 2018 10:39 am Post subject: Re: What's this Ghia part and Where does it go? |
If you look closely, there are similar pieces on the steering coupler but unfortunately not what we’re looking for.
I’ll keep looking. |
Posted: Sat Sep 15, 2018 7:55 pm Post subject: Re: What's this Ghia part and Where does it go? |
Questions on a few items. as I am crawling under the hood, I am trying to ID some things. First, what connects to these brackets? they sit behind the glove box. See arrows
Can anyone confirm if the top hole, coming from the fuel filler area, is part of the overflow, and connects to the lower hole, where I can run the drain pipe? See arrows
And lastly, I know these are grounding points, have to sand the paint off, are they for specific wires/relays? And the hole below, is this for a specific relay such as the flasher relay?
Thanks for the help, Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
crocteau Samba Member
Joined: March 31, 2005 Posts: 1203 Location: Philaburbia
Posted: Sun Sep 16, 2018 3:07 pm Post subject: Re: What's this Ghia part and Where does it go? |
rbsurfguy wrote: |
Thanks for the help, Jeff |
The short one anchors a fresh air control cable, and the long one helps hold the duct to the dash outlets. This picture may not be worth a thousand words, but it should help... |
Posted: Sun Sep 16, 2018 6:23 pm Post subject: Re: What's this Ghia part and Where does it go? |
That's perfect, thank you Sir, I see it now. _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Buggy Brian Samba Member
Joined: October 26, 2006 Posts: 308 Location: Yulee, FL
Posted: Sat Nov 10, 2018 7:26 pm Post subject: Re: What's this Ghia part and Where does it go? |
So, first Ghia, and curious to this contraption under the rear decklid. 1972 with factory AC. Is this part of the AC system? Sorry, but this picture is all I have.
Thanks in advance!
_________________ -(Loretta) Manx # M2940D910E on customized 1970 chassis by Joescoolcustoms
-(Scarlett) Manx Resorter #12 (R0012B931S) on 1969 chassis.
-Original Home built buggy that started all. I learned to drive in it back in 1985.
Manx Club Member # 4436
Check out my Loretta here: http://www.manxclub.com/forum/viewtopic.php?f=65&t=3365Manx
Scarlett is getting a Makeover! http://manxclub.com/forum/viewtopic.php?f=82&t=3745&p=24983#p24983 |
xzener Samba Member
Posted: Sat Nov 10, 2018 8:45 pm Post subject: Re: What's this Ghia part and Where does it go? |
That catches water and directs it down the tube away from your engine... Don't want that getting wet. At least, I think that is what it is. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Sun Nov 11, 2018 8:04 am Post subject: Re: What's this Ghia part and Where does it go? |
x2
Yes, it's a rain catcher. _________________ No Dents
xzener Samba Member
Posted: Sun Nov 11, 2018 3:47 pm Post subject: Re: What's this Ghia part and Where does it go? |
Anyone have a clue what these are? Do they go above the rear wheel wells under the carpet? If anyone has pictures if them installed that would be great.
Posted: Sun Nov 11, 2018 4:28 pm Post subject: Re: What's this Ghia part and Where does it go? |
xzener wrote: |
They fit under the carpet behind the wheel arches with the one on the left on the RH side of the car. The indentation is there to accomodate the tube that takes warm air to the parcel shelf (to demist the rear windscreen). The curve fits over the wheel arch with the narrow end towards the rear. They sit at an angle against the bulkhead - angling inwards. _________________ Festina lente - hasten slowly
xzener Samba Member
Posted: Sun Nov 11, 2018 5:24 pm Post subject: Re: What's this Ghia part and Where does it go? |
Ah... I see. Painted flat black and installed. Thanks Kiwighia68! Now, for the front ones... Can they be dampened and pressed back to flat? They are a but warped. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
