Marcdeb Samba Member
Posted: Wed Dec 16, 2020 3:12 pm Post subject: Re: What's this Ghia part and Where does it go? |
This head light ring came with a bunch of Ghia parts. Doesn't fit my 71 for sure. Anyone know what this might go to? Appears to be stainless. There is no mounting holes or clamps.
_________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Sat Mar 27, 2021 6:34 pm Post subject: Re: What's this Ghia part and Where does it go? |
I was crawling under the rear of my Ghia, and I noticed these bolts sticking out of the body. They are located above the shock towers near those body cut outs. I can't remember what these are used for, can anyone identify?
Are they for some kind of cross supports? Located on both sides.
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
c21darrel Samba Member
Posted: Sat Mar 27, 2021 6:45 pm Post subject: Re: What's this Ghia part and Where does it go? |
Awesome, thanks Darrel, I thought those were only on early models, not later like mine.
2012 Passat-Sold
JonoGA Samba Member
Joined: March 05, 2016 Posts: 8 Location: Johns Creek, GA
Posted: Sun Mar 28, 2021 3:14 pm Post subject: Re: What's this Ghia part and Where does it go? |
Years ago this ignition cover was pried off in a effort to unlock the steering wheel and I am looking for a replacement. Any idea if there are reproductions out there or am I just going to have to find a used one?
1974 Ghia....
Karmann Gheezer Samba Member
Posted: Sun May 30, 2021 9:50 am Post subject: Re: What's this Ghia part and Where does it go? |
Have a few of these amongst my VW bolts. Any clue what they might go to?
Thanks _________________
Redlabel6 Samba Member
Joined: October 17, 2016 Posts: 383 Location: Minnesota
Posted: Tue Jun 01, 2021 6:29 am Post subject: Re: What's this Ghia part and Where does it go? |
The black nut is 1.1" (27.9mm) in length with a 13mm head bolt. _________________
tims57LL Samba Member
Posted: Mon Jun 28, 2021 2:44 pm Post subject: Re: What's this Ghia part and Where does it go? |
Where does this go? I found it under the passenger seat frame, but can’t see where it might live.
NoDents Samba Member
Posted: Mon Jun 28, 2021 3:39 pm Post subject: Re: What's this Ghia part and Where does it go? |
tims57LL wrote: |
Hinge bolt for the front hood. _________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
astreib Samba Member
Posted: Sun Aug 15, 2021 8:24 pm Post subject: Re: What's this Ghia part and Where does it go? |
Under the hood (front) of my '69 Ghia there is a cloth covered rubber tube that emerges from the right fender near the hood hinge, near but about an inch or two rearward of the fuel filler door. This runs around to the left side of the car and connects to ... nothing. Nearby, there is a little nipple at the top of the left side of the fuel tank that also is open to the air. Sizes match, I'm assuming this is a tank vent and they should be connected? |
Posted: Sat Aug 28, 2021 12:17 pm Post subject: Re: What's this Ghia part and Where does it go? |
Marcdeb wrote: |
I have accumulated quite a bit of hardware that should all be VW related. I have several of these. What are they used for?
Valve adjustment screws. _________________ No Dents
cwmcclelland Samba Member
Posted: Mon Aug 30, 2021 3:23 am Post subject: Re: What's this Ghia part and Where does it go? |
I don't know what this part is. It either came off my '69 or '72 Ghia vert. Thanks. |
Capslock Samba Member
Posted: Sat Sep 04, 2021 6:12 pm Post subject: Re: What's this Ghia part and Where does it go? |
What is this lever? It doesn’t seem to be hooked up to anything.
_________________ 1970 Ghia Coupe |
Posted: Sat Sep 04, 2021 7:22 pm Post subject: Re: What's this Ghia part and Where does it go? |
That opens up your heater vent along the floor rails next to the seat.
2012 Passat-Sold
Posted: Sat Sep 04, 2021 7:57 pm Post subject: Re: What's this Ghia part and Where does it go? |
Ah, thanks! In this case the best you could say is it used to do that. _________________ 1970 Ghia Coupe |
