Marcdeb Samba Member
Posted: Sun Sep 05, 2021 3:24 am Post subject: Re: What's this Ghia part and Where does it go? |
Capslock wrote: |
Ah, thanks! In this case the best you could say is it used to do that. |
This location for the levers to open and close the floor vents were a 1969 and 1970 only feature. The kick panels with the levers are very hard to find. Nice that they are still with the car. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Murcio Samba Member
Posted: Wed Sep 15, 2021 6:58 am Post subject: Re: What's this Ghia part and Where does it go? |
Hello,
I have an empty bracket in my KG trunk, can somebody tell me what is the black box on the left?
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Wed Sep 15, 2021 7:16 am Post subject: Re: What's this Ghia part and Where does it go? |
That is a vapor canister, it helps to vent the petrol fumes from the tank and part of your emission system. If you have a stock motor, you will have a line running back to the motor, normally under the right side and going back to another box in the engine compartment. This box in the front is good to have to keep the gas smell from not coming inside the passenger area.
Show some more pics of your Ghia and tell us what year!
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
HBGhia Samba Member
Joined: June 17, 2021 Posts: 42 Location: Westminster Ca.
Posted: Fri Oct 15, 2021 7:48 am Post subject: Re: What's this Ghia part and Where does it go? |
I found these in my box of parts. I think the round rubber pieces are for an emblem or script but they don't really fit any emblems I have. Are they even for a VW? The other square part with the hole seems like it's for the door pull rod? It feels like cork but it could be old dried up felt. Did they even have felt back then?
_________________ Can't have everything.....where would you put it? |
Posted: Fri Oct 15, 2021 8:16 am Post subject: Re: What's this Ghia part and Where does it go? |
HBGhia wrote: |
I think you are correct, the small rubber parts are "nuts", or fasteners to hold your "Karmann Ghia" scripts onto the engine lid. They screw onto the posts on the underside of the lid. They should help seal water from coming through the holes. The smaller one looks like it is for the same small script that goes on the dash for the later Ghias. They don't all have the same size posts, try different scripts and your "VOLKSWAGEN" emblem on the engine lid to find which one they fit.
I have no idea what the other part is. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
HBGhia Samba Member
Posted: Fri Oct 15, 2021 8:28 am Post subject: Re: What's this Ghia part and Where does it go? |
Thanks Marcdeb. That makes sense. They are all 4 the same size, just that one is turned over. My "Karmann Ghia" script does have 4 posts. I know about the different sizes of posts. I have 2 "Volkswagen" emblems and they have different size posts. Thanks again. _________________ Can't have everything.....where would you put it? |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
HBGhia Samba Member
Posted: Fri Oct 15, 2021 4:25 pm Post subject: Re: What's this Ghia part and Where does it go? |
Ah Ha! They do fit on the few pieces of trim I still have, although the trims aren't very usable. They are very brittle and they have chipped edges. Thanks for the replies!
I knew I saw those somewhere. Now I remember reading that thread. _________________ Can't have everything.....where would you put it? |
Exnermobiles Samba Member
Joined: September 14, 2010 Posts: 64 Location: Finland
Posted: Sun Oct 17, 2021 10:18 am Post subject: Re: What's this Ghia part and Where does it go? |
That square spongy rubber is from under the brake fluid reservoir. _________________ 1962 Karmann Ghia Coupe
1958 Plymouth Belvedere Sport Coupe
1959 Dodge Sierra STW |
HBGhia Samba Member
Posted: Tue Oct 19, 2021 4:27 pm Post subject: Re: What's this Ghia part and Where does it go? |
Thanks Exnermobiles. Another part that just fell off! _________________ Can't have everything.....where would you put it? |
Peter D. Samba Member
Joined: February 25, 2004 Posts: 718 Location: Stamford, CT
Posted: Sun Dec 05, 2021 9:52 pm Post subject: Re: What's this Ghia part and Where does it go? |
I'm 90% sure these carpet pieces go in the rear corners in the luggage area behind the back seat in a coupe. What I don't get is why they don't match.
The edges with the vinyl trim are supposed to be the exposed part after the carpet is installed. So why are they asymmetrical? One is curved and the other is straight. Either I don't know how they're installed or the trim was sewed on wrong. Thoughts?
EDIT: It's for a Ghia Coupe _________________ 2019 Golf Alltrack, '65 Ghia Coupe Restoration in Progress
Posted: Thu Dec 09, 2021 12:00 pm Post subject: Re: What's this Ghia part and Where does it go? |
Marcdeb, you were right! They emailed me back and are sending the correct piece. It's a very minor thing considering how far tucked back these carpet pieces are. But you can't be too be picky when restoring a Ghia. _________________ 2019 Golf Alltrack, '65 Ghia Coupe Restoration in Progress |
Posted: Wed May 04, 2022 7:50 am Post subject: Re: What's this Ghia part and Where does it go? |
This is a picture of a 1968 Karmann Ghia Cabriolet with an Auto Stick.
What kind of voltage regulator is this???
It's mounted in the left upper corner of the engine compartment, in the usual area but I've never seen one like this?
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Wed May 04, 2022 8:43 am Post subject: Re: What's this Ghia part and Where does it go? |
that is the current solid state style.. the old style with points are no longer made. haven't for some time now.
Steve _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Wed May 04, 2022 8:56 am Post subject: Re: What's this Ghia part and Where does it go? |
sgmalt46 wrote: |
Steve |
Thank you. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Tue May 24, 2022 4:23 pm Post subject: Re: What's this Ghia part and Where does it go? |
Wasn't sure where to post this and I can't find the part I am looking for. I need that thin nut that fits on the defrost contact switch which is under the dash of a 71. If anyone knows where I can get one or what size it is, I can try to source it.
I must keep missing it in the parts book, still looking. Thanks.
2012 Passat-Sold
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Wed May 25, 2022 9:31 am Post subject: Re: What's this Ghia part and Where does it go? |
rbsurfguy wrote: |
I need that thin nut that fits on the defrost contact switch which is under the dash of a 71. If anyone knows where I can get one or what size it is, I can try to source it. |
Look for 113 959 621 B. Page 79 of the old KGPR catalog or mid-page illustration 46 page 9-73 Parts List VW Karmann Ghia here on theSamba https://www.thesamba.com/vw/archives/manuals/1972_...201972.pdf
The Airheads say they have a used switch FWIW. If you don't have any luck or if you want I'll send you a nut gratis that will work, see fuzzy photos below. PM me. By my old eyes the threads are indistinguishable from the original nut, but it's a tight fit so you'll need to hold the switch while you fasten it through the dash, maybe put one hand through the hole for the speedometer with pliers on the switch body and a wrench on the nut. |
Posted: Wed May 25, 2022 12:37 pm Post subject: Re: What's this Ghia part and Where does it go? |
Thank you Charley, will search the KGPR/Airhead catalog and see what they have, otherwise I'll reach out. Appreciated!
2012 Passat-Sold
Steelz21 Samba Member
Joined: January 09, 2017 Posts: 130 Location: Ontario canada
Posted: Mon Jul 25, 2022 5:09 pm Post subject: Re: What's this Ghia part and Where does it go? |
I’m pretty sure I have one I can stick in the post if you need it.
Let me know if the one above falls through.
Andy. |
