rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Mon Jul 25, 2022 7:16 pm Post subject: Re: What's this Ghia part and Where does it go? |
Thank you Andy, it's not a priority, just looking to mount the switch if just to not lose the part and have the original switch in place. I may actually use the spot for another switch I'm thinking of connecting to something. Appreciate the offer of course!
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Viktor Cz. Samba Member
Joined: July 08, 2009 Posts: 68 Location: Sweden / Jönköping
Posted: Sat Jul 30, 2022 12:38 pm Post subject: Re: What's this Ghia part and Where does it go? |
Kamax bolts!
Anyone knows where these bolts are supposed to sit?
The bolts are M10 threaded and have a relative small head (14mm).
Normally M10 bolts have a 17mm head.
Length 35mm (in total)
_________________ // Viktor
Karmann Ghia coupe 1966
VW ID.4 2023 |
NoDents Samba Member
Posted: Sat Jul 30, 2022 4:23 pm Post subject: Re: What's this Ghia part and Where does it go? |
I believe they are the real axle seal cover bolts for a swing axle. _________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
Posted: Sun Aug 14, 2022 5:12 pm Post subject: Re: What's this Ghia part and Where does it go? |
Can someone tell me what this connector is called? I can't remember and need to look for a similar model for larger gauge wire connections.
Also, I found these springs amongst my many parts. I am thinking they connect to and go under the front seats, but have no idea where exactly they hook up. Can someone confirm if these are seat springs, connecting to the rails, or something else?
Thanks
2012 Passat-Sold
Marcdeb Samba Member
Posted: Sun Aug 14, 2022 5:43 pm Post subject: Re: What's this Ghia part and Where does it go? |
Those large springs do appear to be the springs that go under the front seats. I recently read somewhere that they only go on certain years. Not sure if that's true or not but hopefully someone will give more information about them.
I think your connector part is called a Terminal block. ?? _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Posted: Mon Aug 15, 2022 10:54 am Post subject: Re: What's this Ghia part and Where does it go? |
Awesome, thank you Marc
2012 Passat-Sold
Biouno Samba Member
Joined: March 27, 2021 Posts: 3 Location: CUNDINAMARCA
Posted: Fri Oct 21, 2022 6:04 pm Post subject: Re: What's this Ghia part and Where does it go? |
Hello, I have this speedometer, I think it is from Ghia, but I would like you to confirm what year it is or better to know if it is from Ghia or what car it could be. Thanks.
_________________ Maybe your car cannot be liked by everyone, but the important thing is that you like it. After all, it was your money that managed to finish it.
Tal vez tu carro no pueda gustarle a todo el mundo, pero lo importante es que te guste a ti. Al fin y al cabo fue tu dinero el que logro terminarlo.
VW Escarabajo 1955
VW Combi 1967
VW Jetta GLI 2011 |
Posted: Tue Oct 25, 2022 10:47 am Post subject: Re: What's this Ghia part and Where does it go? |
While searching through a rotted out 71 Ghia Vert yesterday I found some pieces that I'm no familiar with. Does anyone recognise these? They were both found in the back seat area along with ripped up carpet, hub caps, and lots of stuff that had nothing to do with Ghias.
The first part is a long piece of Masonite type board. It's 42 inches long by 3 inches wide. It looks like it might have been mounted with glue but there is one short bracket nail in the center. I'm thinking maybe it goes at the back under the rear window. If so I'd like to use it as a pattern to make one for my 71 when I put the interior together.
this piece is made of felt like material. Also found in the in the pile of trash in the back seat area. It's a bit over 1/8 inch thick. Not sure if the imprint of the circle in the middle is a clue or if that circle was caused by something laying on top of it?
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
mouse action Samba Member
Posted: Tue Oct 25, 2022 11:05 am Post subject: Re: What's this Ghia part and Where does it go? |
Marc,where are you finding all these Ghias ?
Is Vermont where they all went to die ? |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2875 Location: Auckland, New Zealand
Posted: Tue Oct 25, 2022 11:20 am Post subject: Re: What's this Ghia part and Where does it go? |
Marcdeb wrote: |
Marc, the first item fits immediately behind the back seat, from one wheel arch to the other. There should be a "pillar" in the middle where you can either nail it to keep it in place, or slip it in behind to hold it fast. Chris M _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Tue Oct 25, 2022 11:22 am Post subject: Re: What's this Ghia part and Where does it go? |
mouse action wrote: |
I wish. there's not a lot of Ghias in Vermont, I only know of 3 Ghias that are rotted beyond repair and being parted out. They are all at John's Car Corner in Westminster Vermont. His business has been around since the 70's I think. He's a legend in the VW business. I love going down there and chatting with him and looking through parts. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 846 Location: Fort Wayne, IN
Posted: Sun Oct 30, 2022 9:09 am Post subject: Re: What's this Ghia part and Where does it go? |
What is this hole that the shop light is hanging from?
_________________ -Andy-
-1970 Ghia-
-1971 Bus 1776 Microsquirt EFI- |
Posted: Sun Oct 30, 2022 2:42 pm Post subject: Re: What's this Ghia part and Where does it go? |
blue72beetle wrote: |
The Sway Bar (Z-bar) fits there.
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Wed Feb 15, 2023 7:45 am Post subject: Re: What's this Ghia part and Where does it go? |
That’s for a swing axle though so not for your IRS _________________ Volkswagen!
(Compression 8.7:1) |
JoeyBagaDonutz Samba Member
Posted: Sun Feb 19, 2023 12:09 pm Post subject: Re: What's this Ghia part and Where does it go? |
71 vert...The indicated parts on both my hinge covers are broken in the middle. Can't tell if they are stops or clips from this pic. I'd appreciate a closeup pic from a different angle so I can re-create the broken middle part using the ol' superglue/baking soda method....or maybe just a description of what they do or are called. Thanks!
Joey _________________ 1967 Beetle Sedan
1971 Super Beetle Vert
1971 Karmann Ghia Vert |
SundayKaye Samba Member
Posted: Mon Feb 20, 2023 1:03 pm Post subject: Re: What's this Ghia part and Where does it go? |
Hello, everyone! I haven’t been here in 15 yrs! I was restoring a 68 Ghia but my marriage ended and she ended up parked for 15yrs. Well, I’ve taken her back because circumstances have changed a bit and I’d like to start working on the body. I live in Maryland and I had no choice but to park it where I could (my grandparent’s house) because I had nowhere else I could put it. Maryland is not kind to old cars. The body was in pretty good shape when that happened but now…eh, not so much. The bottom front rusted. I’m trying to order a replacement part but I want to be sure it’s the right one and the labels on different sites are confusing. Can someone tell me if this is correct? Thank you so much! I really don’t want to get the wrong part. The rust goes from wheel to wheel across the bottom front.
kingkarmann Samba Member
Posted: Wed Feb 22, 2023 9:19 am Post subject: Re: What's this Ghia part and Where does it go? |
SundayKaye wrote: |
Yes, that looks to be the correct panel.
You may have better responses if you start a new thread in the regular Ghia forums. Posts in the Stickies tend to get overlooked.
Welcome back and keep us updated on your progress! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Wed Feb 22, 2023 10:01 am Post subject: Re: What's this Ghia part and Where does it go? |
JoeyBagaDonutz wrote: |
Joey |
It's a hook for hanging your seatbelt clasp on so you don't have to dig beside the seat for it. https://www2.cip1.com/vwc-111-857-723-a2/ _________________ 71 vert build. http://www.thesamba.com/vw/forum/viewtopic.php?t=572951&highlight=dead |
