SL12572 Samba Member
Joined: April 13, 2011 Posts: 270 Location: Washington
Posted: Fri Apr 27, 2012 6:36 pm Post subject: Wanting a Red Backlit Speedometer and Tach. |
The combination of being mildly obsessive compulsive and also being in aviation, I'm really wanting to make red backlit gauges for the van. I've been researching electroluminescence, but it seems that you can only get a blue glow.
Anyone with ideas to get red backlighting? My Audi A4 had all red gauges, which I loved. How do they do it? Is it only done with leds?
Thanks!
Scott |
SCM Samba Member
Joined: January 26, 2011 Posts: 3357 Location: Bozeman MT
Posted: Fri Apr 27, 2012 6:44 pm Post subject: |
you can swap out the dash lights with different colored LEDs. Here's some old crossreference I saved http://cabby-info.com/OldBlue/files/VanagonLEDCrossReference.pdf
somewhere on the samba are some photos of some dashes with different colored lights installed. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
1fin Samba Member
Posted: Fri Apr 27, 2012 10:14 pm Post subject: |
How about this tach upgrade? Looks really cool except the speedo is in Km/H and the needle is not backlit. Although I saw that someone else on the forum here had installed the same and used a UV/Blacklight dash led to accentuate the stock white needle when lights are turned on. It was a recent posting (last 2 weeks probably) you can probably search around and find a picture.
http://www.ebay.de/itm/PLASMA-TACHO-Tachoscheiben-...3311wt_929 |
Posted: Fri Apr 27, 2012 10:28 pm Post subject: |
The post you are referring to is from Syncroincity and his diesel syncro conversion. It's close to what I'm looking for, but would like all red lettering, and they only offer the speedometer in kmhs. It would be great if I can figure out how to get the red backlighting in a DIY project. I may use my spare instrument cluster for experimenting.
Thanks
Scott |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
a914622 Samba Member
Joined: July 29, 2004 Posts: 915 Location: Westend of HWY2 , Wash
Posted: Fri Apr 27, 2012 11:21 pm Post subject: |
how about swapping out the hole cluster and pod for an audi one??
jcl _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
Posted: Sat Apr 28, 2012 7:09 am Post subject: |
Jerry, you are the man....Thanks! I contacted a few el panel stores and they all told me that there is no such thing as a red el panel. I can make the gauge faces.
Can't wait to try this out.
Scott |
James 93SLC Samba Member
Joined: January 21, 2009 Posts: 937 Location: NE Ohio
Posted: Sun Apr 29, 2012 5:51 pm Post subject: |
Oooooo.... keep us posted! I'd totally rock red backlit gauges  _________________ -------------------------
91 Vanagon Carat
93 Corrado SLC
Photos: http://picasaweb.google.com/slc.corrado
tencentlife "Sometimes a pooka is a problem and sometimes it's just a pooka" |
