How much should I budget for head porting
gimmesomeshelter
gimmesomeshelter is online now
PostPosted: Sun Dec 11, 2011 5:36 pm    Post subject: How much should I budget for head porting Reply with quote
Hello-
I have a set of raw ( no valves, springs, guides ) repro Okrasa heads that I needed ported. How much should I budget for a high quality porting job (not counting the cost valves, springs, etc.)?
Cheers,
Paul
My dog's vet has all my car money (http://sagecenters.com/)
Last edited by gimmesomeshelter on Tue Dec 13, 2011 2:56 pm; edited 1 time in total
RockCrusher
RockCrusher is offline
PostPosted: Sun Dec 11, 2011 6:19 pm    Post subject: Reply with quote
Hey Paul,
Depends what you want out of them. 1st you have to ask if you want to mod and original set of castings....yes? Since the engine they would go on is a pretty conservative project (I'm guessing) they should not need much modification. Depends who does them but the actual port work should be $200-250ish plus the guides and all the other doodads and the valve job. Figure $400-500 to put everything into a finished mode and ready to run. Probably closer to 500.
RC
[email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly.
modok
modok is offline
PostPosted: Mon Dec 12, 2011 10:02 pm    Post subject: Reply with quote
That's a loaded question...
You know, it really depends on what application....
The ports on those things already look somewhat LARGE for a small cc engine, so if you plan to build a BIG cc or high rever, you should look at larger valves, larger intakes at least, and some port and chamber work to match them. Also a way to lift the valves high enough, is rather important
Or if building a SMALL engine, with limited valve lift, you might want to use the intended valve size but make the ports smaller or leave them alone, which is another matter
Whatcha plannin boss?
gimmesomeshelter
PostPosted: Mon Dec 12, 2011 10:29 pm    Post subject: Reply with quote
Hello-
My goal is a 356 1600 Super wanna-be using a mish mash of 36hp VW, Porsche 356, repro Okrasa. Here's what I have so far:
NOS 36hp case
Scat superlite 356/912 crank
Carillo 356 rods
Billet aluminum oil cooler
LN aluminum cylinders (82.5mm)
Full weight 180mm flywheel
Dual Zenith 32NDIX carbs
Cam - probably something like a Pre-a super, or a "Maestro Grind" on a Pre-a blank.
WW repro Okrasa heads (the current valve diameters are 33mm intake, 28 exhaust).
1:1 ratio rockers
Full flow Fram canister filter
I want something that is enjoyable to drive (zenith carbs, full weight flywheel, modest cam), and given the money I've sunk into this thing already, I want it to last.
Regards,
Paul
Last edited by gimmesomeshelter on Tue Dec 13, 2011 10:31 am; edited 3 times in total
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Mon Dec 12, 2011 10:57 pm    Post subject: Reply with quote
OLLIES did my WW OKRASSA heads for 1000. That was full port and polish, match port intake manifold with aluminum spacers, make valve guides, valve job and deck to raise the compression, reshape chambers with-out welding. Expensive, cheap I don't know except we made 12 more HP which we contribute at least 8 of it to the heads
Don't know what the next welded up set will cost. Redoing the chambers, valve size, guide size, valve spring pockets, decking and more.
Call Roger at HEADS UP Performance, he has done some WW Okrassa heads also
"no more hacking my sig line"
modok
modok is offline
PostPosted: Mon Dec 12, 2011 11:23 pm    Post subject: Reply with quote
I see
I am no expert on the 36 horse cams, but from what I understand they limit the possible lift. To decide what lift is needed for the valve.......... or conversely, what size valve is needed to match the size of the port considering the lift you can achieve, is the first thing to figure
Something like pipemax could give you a reality check on the valve size, port size, runner size, carb vent size, runner length, and valve lift needed to make the most of it. The results may be surprising.
Once you figure out what directions you need to go in, then you can get some idea of how to go there.
If you could find all the info for me to plug in to the sim, I could give it a go, but as it is I have no idea about the intake diameters and cam specs on these things Confused
mark tucker
mark tucker is offline
PostPosted: Sat Dec 17, 2011 9:32 pm    Post subject: Reply with quote
I see a lot that could be done to the heads chambers.depending on piston type.but modoc is right,the key is to have it all work togeather for the intended app and the way you drive & where. biger isant nessarly better but proper disigine&funksion is.I would love to have the time & $$$ to do one of those old 36's up real nice.I think it would be a nice challange, both single port&o'crazzy style heads.hmm were those irish? good luck and who ever you choose ,choose wizely.and choose a real shop, not bubbajoes in sailem because he spins a wicked yarn of how good he is.Ive seen that tomany times and it,s usualy junk, or will be shortly.you need real time real cust feed back & real ### as in dyno,flow.something to compair it with.might not want to limit it to vw shops.
kmichael
kmichael is offline
PostPosted: Sun Dec 18, 2011 10:21 am    Post subject: Reply with quote
Paul,
You might want to give Dave Bonbright at Engine Masters in Sonoma a call-since I see you're not too far from him. The modifications he's making on our 36HP Challenge engine are really novel, he's certain to have ideas on your build. Dave's phone number is 707-938-8122.
Regards, Kim
"The star of the beetle is still shining with undiminished brightness and you see for yourselves every day what vitality there is hidden in this car..."HeinzNordhoff
Vintage oval
Vintage oval is offline
PostPosted: Tue Dec 20, 2011 8:26 pm    Post subject: Reply with quote
You might want to check the openings between all the fins. I purchased a set of raw heads from Wolfsburwest and had to clean out all the metal flashing that interfered with the cooling passages. It took a lot of time but it is worth it if you are going to get some serious hp and need the cooling.
Howard Sanson
Howard Sanson is offline
PostPosted: Wed Dec 21, 2011 12:47 am    Post subject: Reply with quote
Your heads you have no seat think about larger vales { what is stock}go to the next size up in stainless steel. Wink
splitpile
PostPosted: Wed Dec 21, 2011 4:07 pm    Post subject: Reply with quote
Bigger valves for a 36hp head are not easy to find. I had mine custom made.
35.5 intake and 33 exhaust. Should of made them a little longer for the springs I was going to use, ended up with jaguar duel springs and titainium retainers instead of my ford v6 modular engine springs i was going to use (to much spring pressure.
gimmesomeshelter
PostPosted: Wed Dec 21, 2011 4:12 pm    Post subject: Reply with quote
Hello-
I assumed that I will have to have my valves custom made. I'm also planning on using beehive spring an titanium retainers. That's why I asked how much porting will cost excluding the cost of the valves, etc. Wink
Cheers,
Paul
splitpile
PostPosted: Wed Dec 21, 2011 6:06 pm    Post subject: Reply with quote
gimmesomeshelter wrote:
Hello-
Cheers,
Paul
I'm using behives, but the stock length valves were to short and created to much spring pressure. We are going to cut the spring pockets and then figure out how much longer the valve stem needs to be and/or move the retainer grove up as the behive retainers are half the diameter of stock retainers. Lots of geometry and shit to figure out, but getting close.
The WW Okrassa heads have had the chamber welded up to reshape it and the seat pockets will be cut and installed next. Ray Stephens is letting me use his Super Flow 110 flow bench to help get things flowing right.
I should have the 1.4 ratio rockers here after the new year to figure out how much lift works best so a cam can be ground accordingly. These heads will be totaly different design then my other 2 sets I've had done, just going to the next leval.
earthquake
earthquake is offline
PostPosted: Wed Dec 21, 2011 7:05 pm    Post subject: Reply with quote
Check out Honda GL1100 Goldwing Valves and springs, the stems are just a bit smaller so that may take a little work, they have dual springs and I know for a fact that you can rev a GL motor to 8000 rpm no problem...
Goldwing on the left-----------------------------------------------------------------stock VW 36hp on right
The intake valve is 38mm and the exhaust is 32mm
check out this post...
http://www.thesamba.com/vw/forum/viewtopic.php?t=437391&highlight=goldwing+valve
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
Kelly J. Nolte 3/20/53 - 11/6/08
http://www.rememberingkelly.com/
DEATH TO CHINGERS!
mark tucker
PostPosted: Wed Dec 21, 2011 8:07 pm    Post subject: Reply with quote
I would just find a biger stainless valve that would work,longer isant any big deal and there are someny to choose from, and go from there.
henry roberts
henry roberts is offline
PostPosted: Thu Dec 22, 2011 5:13 pm    Post subject: Reply with quote
has anyone thought about or tried inclining the valves on the ww heads?
to me it seems as though this would allow you to run a more modern chamber design and fit ratio rockers without moving the rocker shafts.
mark tucker
PostPosted: Thu Dec 22, 2011 5:45 pm    Post subject: Reply with quote
sshh !! modern is a bad word in the world of vw's. eveloution has left us behind,and some like it that way.(not me I mod everything)
modok
modok is offline
PostPosted: Fri Dec 23, 2011 12:23 am    Post subject: Reply with quote
Tell me the dimensions of the valves you need, and the springs you need, and chances are I will know of where to get them
This is a side effect of my wasted life Smile
gimmesomeshelter
PostPosted: Sun Jan 01, 2012 2:40 pm    Post subject: Reply with quote
Hello-
Pardon me if this is OT.
I've been reading about the optimization of combustion chambers, it it looks like the Okrasa head could benifit from some. It already has a relatively small volume (45cc), but has a very open shape. It could be closed by welding in the areas marked below, but that would end up raising the compression.
I could lower the compression to an acceptable level by 1) adjusting the deck height, or 2) installing dished pistons.
If I had a choice between a flat piston top and an open combustion chamber, or a dished piston top with a closed combustion chamber, which should I choose?
Cheers,
Paul
grueni
grueni is offline
PostPosted: Sun Jan 01, 2012 5:32 pm    Post subject: Reply with quote
if welding on the combustion chamber you need to put out the seats and get some new. and then go B form.
look at some denzels. that was for it's time the best. modern heads like jpm do the same.
1956 oval 1192cc 36hp Supercharged 70HP at 3900RPM / 150NM at 2000RPM @ 13 psi
1960 1641cc Twin scroll turbocharged, intercooled @17 psi 318nm/3430rpm 160hp/4790rpm
with cb2280 cheater cam 222@ 0.05"
