cmarino929 Samba Member
Joined: August 16, 2009 Posts: 257 Location: Central NJ
Posted: Sun Dec 11, 2011 8:33 pm Post subject: running tach wires/getting the length |
So I did use the search function and found some info about how to wire a tach but didnt see any about running the wires through the car (aka specifically a ghia) and where to get wires that are long enough. The tach will sit on the dash above the speaker holes.
So my 2 questions are for anyone who has done this:
1 - Is there a wiring kit that anyone could recommend that I could run from the front to the back of the car. The tach is a sun super tach 2, it has 4 wires to it.
2- Where is the best place to run the wires (under the carpet, etc).
Thanks in advance, this site has save me many times before. |
gotitforfree70 Samba Member
Joined: July 26, 2008 Posts: 31 Location: Mira Loma CA
Posted: Sun Dec 11, 2011 9:58 pm Post subject: |
just run 1 wire from the coil , to the front with the wiring harness wiring. you'll have to remove the rear interior side panel , the door sills to get to the wiring harness (under the carpet) run it up into the trunk and go from there. All the hot side and lighting part is already right there. |
Posted: Mon Dec 12, 2011 5:21 am Post subject: |
So your saying that i need one long wire from the coil that I run thru the car then in the front of the car in the trunk there is a harness where i connect the coil wire and the other three wires as well? |
donmurray Samba Member
Joined: December 30, 2008 Posts: 841 Location: Frisco Texas
Posted: Mon Dec 12, 2011 6:09 am Post subject: |
1. One long green wire from points side of coil to tach. I use the same wire to trigger a relay that powers my electric fuel pump. so pump can only run if coil is firing.
2 A black ground wire from the tach to any of the body ground posts. Brown might be better since that's the standard color for ground. There's usually a group of male spade connectors welded to a vertical piece that supports the cowl.
3. A red gauge power wire. There's a red switched wire coming out of a harness that goes to the ignition switch. This switched red wire goes to fuse block #11 & 12, and then output to various devices such as the coil, horn relay, wipers, etc. You can tap into one of these wires because they are fuse protected. Anytime you tap into a power source, it should be protected by a fuse.
4. Blue wire to illuminate the gauge at night. This can be connected to the black wire that illuminates the standard gauges like fuel.
One problem may be finding all the wire colors in small lengths. You might try a auto repair place to see if they will sell or give you some short pieces. Electronic supply houses or some hardware stores sell by the foot. _________________ 74 Ghia, with 2110 engine |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32591 Location: Reading Pennsylvania
Posted: Mon Dec 12, 2011 7:15 am Post subject: |
Hi Dave
Its a 74 ghia and no rust on the pans.
Is there a certain type of wire(s) im supposed to use? Im wondering if a regular auto parts store would have them.
Is the harness in the trunk behind the dash that im supposed to hook up these wires to? Sorry im constantly learning and doing this all solo. |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2504 Location: Santa Cruz, CA
Posted: Mon Dec 12, 2011 8:47 am Post subject: |
If you're not sure how you'll run a wire back to the coil, you can use the car's existing wire harness to bring the ignition signal up to the tach. VW gave each tail light it's own separate fuse & wire and you can use one of these for the coil/tach connection. You'll need to remove the tar board panels in the engine compartment to expose the tail light wiring. The idea here is to run a jumper wire connecting the two tail lights together and have them both run off one fuse. This frees up one wire to carry the signal from the coil up to the tach. First, disconnect the grey/black wire from the left tail light and extend it to reach the negative terminal on the coil. Then connect the two tail lights together with a jumper wire which can run behind the engine, preferably under the firewall tarboard. Now, at the back side of the fuse box, disconnect that grey/black wire from it's terminal (it's the 4th from left, looking in from the luggage compartment) and run it to the signal connection on the tach. There...now you're good to go without drilling any new holes in your car.
I've been running this setup for years with no problems. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Mon Dec 12, 2011 9:23 am Post subject: |
You can also try any decent stereo shop. Not only will they have the cable but it will be high quality and whatever length and color you need. Additionally since you are already there you could ask one of the techs to show you how to safely run the length of wire through your car since this is what they do. They can also provide you with all the proper grommets and terminators to get your wire safely through metal so it does not scrape the insulation and short. _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
Bikerchris Samba Member
Posted: Mon Dec 12, 2011 5:42 pm Post subject: |
Autozone sells green colored 16 gauge wire that you can use for your wire from the coil. Run that following the wiring harness as others have said. Piggyback the white wire to one of the dash lights for your clock or speedometer. Run the black wire to a ground such as the tab that the wiper motor assembly uses as a ground. Splice the red wire into the fuse block.
JeffL Samba Member
Posted: Mon Dec 12, 2011 5:51 pm Post subject: |
rcooled wrote: |
I've been running this setup for years with no problems. |
Great, this is the way to do it and use the existing harness. I believe the original VDO instructions indicate to use the one tail light wires. If you have the engine it it is a little harder but can be done. _________________ http://karmannghias.org/
https://karmannghias.org/GAlken/index.html |
Posted: Mon Dec 12, 2011 7:18 pm Post subject: |
Wow i just got home from work and checked this out, thanks everyone! This is a HUGE help, a testament to ACVW people. I will def use the tips and im sure it wont be a problem now. This site is a blessing for someone who never grew up with these cars (im 32). I wish the watercooled people were as nice and helpful, instead they just tell me to "lower it" haha. No thanks i like my oil pan and front spoiler. |
Posted: Tue Dec 13, 2011 5:44 am Post subject: |
Yes i live in new providence but my car is in fanwood, and i cruise through chester area frequently in the nice weather (much better area to drive than here haha). Appreciate it, i will give it a shot and if i fail i will let you know haha. Thanks Dave. |
