awalls Samba Member
Joined: March 21, 2005 Posts: 128 Location: Beaverton, OR
Posted: Mon Dec 12, 2011 8:40 pm Post subject: Rear Hurst Bumper Question? |
I was wondering how a rear hurst bumper is connected to the bus, especially the sides. Looking at photos of real or repo, could not tell how the long bar that wraps around the side of the rear connects. Or does it at all? I tried to search bit didn't come up with an answer. Thanks _________________ '64 Bug
'58 Kombi |
KombiMonster Samba Member
Joined: April 17, 2001 Posts: 2751 Location: Central Cal.
Posted: Mon Dec 12, 2011 8:54 pm Post subject: |
with a bolt like an over rider on a later bumper. _________________ FOOK CANCER
*WANTED* |
awalls Samba Member
Posted: Mon Dec 12, 2011 9:43 pm Post subject: |
My mistake for not having pictures but I mean where it touches the side of the bus by the rear wheel arch. _________________ '64 Bug
'58 Kombi |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Mon Dec 12, 2011 10:35 pm Post subject: |
There are two places on each side panel where you would need to drill a hole for a through-bolt. Yikes! _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Clara Samba Member
Posted: Mon Dec 12, 2011 11:49 pm Post subject: |
cru62 wrote: |
There are two places on each side panel where you would need to drill a hole for a through-bolt. Yikes! |
Three holes per side, which is far fewer holes than you need to drill when you install safaris.
They are nice to stand on when you get things on or off the roof rack.
extra rear bumper brackets:
http://www.thesamba.com/vw/forum/album_search.php?...t_dir=DESC _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Tue Dec 13, 2011 8:01 am Post subject: |
Don't they also have a bolt where the return is at the wheel well splash? |
Clara Samba Member
Posted: Tue Dec 13, 2011 12:03 pm Post subject: |
The lower tube?
The lower tube bolts to the rear bumper at the normal bolt hole where the rear bumper attaches to the splash pan. There is a tab that pokes down from the lower tube.
That bolt is visible in the above pic.
There is not another bolt further forward on the lower tube in the wheel arch. What would it bolt to there?
Next time I have a set of Hursts installed I will take more pics. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
50ate Samba Member
Joined: September 22, 2007 Posts: 1171 Location: Rainier/Olympia Washington
Posted: Tue Dec 13, 2011 4:10 pm Post subject: |
i want that panel clara.. what ever happend to it? |
Clara Samba Member
Posted: Tue Dec 13, 2011 4:24 pm Post subject: |
That bus rocked. Sold it a few years ago, not long after Vintage Meet 2007. The British buyer didn't want to pay for the original (but not to the bus) Hursts, so kept those.
At some point we'll put together another bus that will look awesome with them.
this pic might show the rear tube better:
RHD Notch Samba Member
Joined: April 06, 2007 Posts: 1412 Location: Joshua Tree, CA
Posted: Tue Dec 13, 2011 5:37 pm Post subject: |
Vintage Autohaus panel...Long Beach OCTO 2011. Shows less mounting detail than Clara's pic, but thought I'd add for additional comparison.
Lind wrote: |
I am at the point where I hardly want to own anything that isn't original paint. |
campingbox wrote: |
I have some other projects I'd like to finish first and I want to drive this bus while I'm working on those to help stay motivated. |
Aaron Samba Luddite
Posted: Wed Dec 14, 2011 8:52 am Post subject: |
So there are 2 different styles of original rear Hurst? One that goes into the wheel opening and one that ends at the bumper. |
Clara Samba Member
Posted: Wed Dec 14, 2011 9:14 am Post subject: |
Yes _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
BarryL Samba Member
Posted: Wed Dec 14, 2011 10:58 am Post subject: |
Clara wrote: |
The lower tube?...There is not another bolt further forward on the lower tube in the wheel arch. What would it bolt to there?... |
What about non-pressed bumper; are those attached to the wheel-well splash? |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Wed Dec 14, 2011 10:20 pm Post subject: |
BarryL wrote: |
Clara wrote: |
Did they make them?
I have never seen a set of original non ribbed bumper versions. |
voo Samba Member
Posted: Wed Dec 14, 2011 10:36 pm Post subject: |
From the gallery. Only description is "yup they fit"
Aaron Samba Luddite
Posted: Wed Dec 14, 2011 11:17 pm Post subject: |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Thu Dec 15, 2011 8:02 am Post subject: |
The rears fit a later bumper fine with some modification. You need to cut the angle iron bumper brackets where the J meets the angled piece and extend it about 2 inches. Also need to cut out the bumper brackets on the inside of the bumper and bolt the Hurst bumper brackets directly to the bumper. I did this to mine and the mounting pad on the side of the Bus split the body seam at the corners perfectly. I think I had to slot the bumper brackets a little as well.
_________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Aaron Samba Luddite
Posted: Thu Dec 15, 2011 11:23 am Post subject: |
Just guessing; kinda looks like one to me. Looking at the original pic you can make out a bit more of the shape. |
Posted: Thu Dec 15, 2011 12:21 pm Post subject: |
Having never seen the 'inside' of the body panel where the tube brackets mount, what makes the tube able to be stood on? Is there a larger steel plate that gives the whole mount strength? Thanks... _________________
Lind wrote: |
campingbox wrote: |
