torsionbar Samba Member
Posted: Fri Dec 16, 2011 1:58 pm Post subject: |
SRP1 wrote: |
The soft seals are nothing more than foam weather stripping availble at you local hardware store, home depot, etc... |
no the original ones were formed rubber. not foam, and not generic, they were made in the correct shapes. you can of course replace them with form weather stripping though. _________________
Max Welton wrote: |
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed. |
AlteWagen Troll
Posted: Fri Dec 16, 2011 2:19 pm Post subject: |
Joost wrote: |
Wich is better the late or early FI shroud?
The early shroud looks to be better due to the large slot,
But there must be a reason why they changed right?
I have got two late FI shrouds and one normal doghouse shroud with large negative slot, can i remove the venturi and weld it too the normal shroud as too have better cooling? |
From what Ive read the later FI shroud diverts less air to the cooler in an attempt at lowering head temps due to smog timing.
I have put the venturi rings on my puma and brazilia shrouds and did notice drops in both head and oil temps (average 50 cht and 20 oil temp depending on load and ambient temps). I have found that flaps have more of an affect on head temps compared to a ring alone. |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Sun Jan 08, 2012 8:17 pm Post subject: |
I have a stale air shroud that I think belongs to a '62, but on the front driver's side near the top edge, it has an approximately 1" diameter hole. It appears to have been factory made, as it is very clean and the edges are countersunk. Does anyone know what this hole could have been for? _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
AlteWagen Troll
Posted: Mon Jan 09, 2012 2:37 pm Post subject: |
Post a pic of the shroud |
Posted: Mon Jan 09, 2012 5:33 pm Post subject: |
79SuperVert wrote: |
I have a stale air shroud that I think belongs to a '62, but on the front driver's side near the top edge, it has an approximately 1" diameter hole. It appears to have been factory made, as it is very clean and the edges are countersunk. Does anyone know what this hole could have been for? |
AlteWagen Troll
Posted: Tue Jan 10, 2012 1:02 pm Post subject: |
first for me. |
Posted: Tue Jan 10, 2012 1:30 pm Post subject: |
It's very puzzling because I wouldn't be able to use this shroud with that hole open like that. A lot of air would come out that way. I'd have to plug it up, which isn't a big deal, but I can't think of a reason to have a hole there in the first place. _________________ Central Jersey VW Society
Posted: Wed Jan 11, 2012 11:56 am Post subject: |
So no other ideas? This hole was perhaps just some previous owner's bright idea gone astray?
mark tucker Samba Member
Posted: Wed Jan 11, 2012 4:45 pm Post subject: |
possiably it was on a clown circus car and they used it to plumb air into the car to blow up the clowns baloons to make dogs &other baloon things. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3477 Location: viroqua wi.
Posted: Wed Jan 11, 2012 5:08 pm Post subject: |
mark tucker wrote: |
Tucker wer doo you comm up wit dis s#it |
Posted: Sat Jan 21, 2012 7:36 pm Post subject: |
Bumping to see if anybody has any constructive ideas about what this hole might have been for. 1962 stock 1200 stale air engine.
[/quote] _________________ Central Jersey VW Society
old_guy Samba Member
Posted: Sat May 12, 2012 10:08 am Post subject: '73 T181 vs. Doghouse |
In reviewing the photos and comparing the '73 Type 181 (thing) shroud to the 70's doghouse shroud, am I to assume the only difference between the two is the absence of the fresh air ducts? The stampings & hole placement appear to be identical.
Am I missing something or are there other identifiers that one can use to differentiate the two?
Thanks. |
AlteWagen Troll
Posted: Sat May 12, 2012 11:25 am Post subject: |
Jake Raby cut one open and stated that the directional veins are more "blunt" at the tip on a 181 shroud compared to a regular DH. Assumption is that this is for slow rpm use that a thing would see off road. I am wondering if it is only on the US 73 only shroud as it did not have a reduction box transmission like the rest of the world. |
AlteWagen Troll
WD-40 Samba Member
Posted: Thu Sep 18, 2014 9:27 am Post subject: |
Unfortunately, it looks like we have lost a LOT of pictures from this thread, as they were links to temporary pictures from the Classifieds section and those ads/pictures have since been removed.
Anyone have new/replacement pictures they can contribute to keep this valuable resource alive? _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
AlteWagen Troll
Brian Samba Moderator
Posted: Thu Sep 18, 2014 10:06 pm Post subject: |
Glad this thread came up. I have a late FI shroud and it appears that I do not need a hoover bit. Is it true that all FI shrouds do not need them, or just early or? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
AlteWagen Troll
WD-40 Samba Member
Posted: Fri Sep 19, 2014 9:36 am Post subject: |
EverettB wrote: |
I fixed them all |
Whoa... Thanks! I figured they were gone for good. _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
