whynotvw Samba Member
Posted: Sun Jan 01, 2012 11:35 am Post subject: |
kamzcab86 wrote: |
Done! Can't wait to try it out
I made mine an even 90" long and 45" tall (43" would've been too short for the sides in mine)... still need to cut the front angles and add Velcro. The rear is 11-1/2" x 60" (a bit long, may cut it down to 55"). Mine stands up on its own so no need for snaps, etc. along the roof.
Thanks for the idea and dimensions, everyone! |
Looks awesome. You'll be a warm happy camper.
When I tried mine, doubling up the sides and cab divider really helped. |
focusedcycling Samba Member
Joined: September 10, 2010 Posts: 56 Location: Annapolis, MD
Posted: Sun Jan 01, 2012 11:39 am Post subject: |
I said I would post pics, so here they are. As mentioned earlier, all these minus the front panel that covers the traditional front window stay up even when the top is closed.
In the earlier post I also talked about the different weight or thickness of moving blankets. All the blankets I used are of heavier weight, minus the front panel. Will show the best pics of this I can later.
First couple of pics show the blankets installed but with top down.
Poptop on the way up after being closed(IE, getting to the campsite and setting up:
This next shot shows how the side blankets get tucked over the bar when being brought down to keep out of the way:
Fully popped:
Pic of Snap on front blanket:
Pics of difference i moving blankets weight. Kind of hard to see a difference but the darker blue blanket with dark stuffing is the heavier weight blanket and the one on the right, light blue, is the lighter weight blanket:
To complete the sides and rear you will need three blankets. This next pics show the transition from one blanket to another. Velcro.
Pic of the front blanket snapped up(wow that thing looks dirty... )
So yeah, there they are... Love them! |
Timwhy Samba Member
Posted: Sun Jan 01, 2012 2:09 pm Post subject: |
Timwhy wrote: |
Also I am thinking that I may try to fashion a slider thermal barrier with a zipper, for entry/exit.
I think I'll base it off of my GW slider screen door and put the snaps to the thermal doorway
in the same spots as the screen. |
Short weekend for me and not alot of time to get the sliding door thermal barrier done. I did complete
one side of it though and have some of the other sides pieces ready to be stitched together. Here's a
couple of pics, one of the completed right side and the two Reflectix door pieces.
I'll post some more pics once I complete the job. _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
Timwhy Samba Member
Posted: Mon Jan 02, 2012 3:29 pm Post subject: |
Went to the local canvas shop today to pick up some SS snaps for my new sliding door.
While I was there, I told the gentleman what I was making and he said that they have tons
of the industrial Silver bubble wrap, that is thicker and the silver material is stronger than
Reflectix. He also said that they really don't have a need for remnants of this stuff and will
practicly give the stuff away. A remnant would be a piece that's 6' X 20' for $40.
Just putting it out there, it may be worth your while to check out a local canvas shop before
you make the trip to Lowes or HD. _________________ '15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
Timwhy Samba Member
Posted: Wed Jan 04, 2012 1:44 am Post subject: |
Finished the sliding door radiant barrier, still need to put in a few more snaps. Too cold and too dark
to finish the installation. I did try it out with my 1500 watt heater running, it seems to do what it's intended
to do. Next up will be the pop top and I'm thinking that the rear hatch will also get a radiant barrier.
Also, I stopped by the local canvas shops' other warehouse to get a look at their bubble wrap.
It is quite a bit different, not as rigid as the reflectix and is alot stronger and thicker by a small margin.
Talking with the owner, he said that a piece of material applied to one side of the wrap will give
it a moisture barrier and will increase the R value. I ended up buying a 6' X 20' roll for $40, same as
the reflectix 4' X 25' roll.
'87 VW Westy
'91 Tin Top
'90 Cabby
Timwhy Samba Member
Posted: Mon Jan 09, 2012 4:38 pm Post subject: |
Made the rear hatch radiant barrier, just traced the bug screens' shape and cut it out. Sewed some vinyl
piceces around for the snaps but only put in the top three snaps. I think you'd have to make the pattern
larger for all the snaps too work. With only the top snaps in place, the rest of the barrier has a nice
snug fit around the hatch opening. Seems to radiate the heat back towards the front. Maybe acts
as sort of like a vapor barrier too, without that draft from around the door coming in. My wife is
becoming concerned that I may be contemplating living in the Westy this winter. I did try out the new additions
this weekend, the inside does seem to keep the heat in better and cut down on the drafts around the
doors.
'87 VW Westy
'91 Tin Top
'90 Cabby
Posted: Mon Jan 09, 2012 9:21 pm Post subject: |
Timwhy wrote: |
My wife is
LOL.
Looks good and great idea, I need to make the rear barrier. |
Posted: Mon Jan 09, 2012 9:22 pm Post subject: |
Timwhy wrote: |
My wife is
LOL.
