lifeisgoodin29 Samba Member
Posted: Wed Dec 21, 2011 9:06 pm Post subject: coker 700x15 ND tires |
Has anybody had any experiance putting this tire and a 15 inch bus rim on a reduction gear 181? I have 1970 and am looking for a aggresive tire to use. |
dells68 Samba Member
Joined: January 09, 2008 Posts: 217 Location: Virginia
Posted: Thu Dec 22, 2011 8:31 am Post subject: |
I've thought about those tires before, as they just look bad a--. The only thing with bus rims is the clearance issue with the front spindles. Thing rims have less backspacing as opposed to the bus rims causing them to rub. I actually put 235 75 15 mud and snow tires on beetle rims on my car to give it that agressive look and it's worked out pretty well with no rubbing, but I do have a 2" body lift and slightly lifted suspension. Below is a pic before I got it finished.
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Thu Dec 22, 2011 8:45 am Post subject: |
^^^Nice! |
Posted: Thu Dec 22, 2011 10:22 pm Post subject: |
Thanks |
74 Thing Samba Member
Posted: Fri Dec 23, 2011 8:51 am Post subject: |
That Thing looks great-more photos please! |
Posted: Fri Dec 23, 2011 9:39 am Post subject: |
Hey 74, Thanks, I'm sad to say that I'm horrible at taking pictures I don't really have any pics since I finished it. There are a few in progress pics in my gallery if you'd like to take a peak at those. I've got it put to sleep for the winter right now - just waiting for about March to come along so it can come back to life! |
yellow73kubel Samba Member
Joined: August 17, 2008 Posts: 789 Location: Columbia, SC
Posted: Fri Dec 23, 2011 11:13 am Post subject: |
I'd avoid NDCC and definitely NDTs if this car sees much time on the road. Tire technology is night and day from when either was first produced. Modern AT tires from any reputable manufacturer (General, BFG, Goodyear, etc..) will do better in mud than the ND*s and keep you in control on the road.
In my opinion, 205/75/15 or 27x8.5R14 General Grabber AT2's are the perfect all around tire for a stock Thing. Anything bigger and/or more aggressive is going to require new gearing or more power in addition to a lift. |
sixty9fasty Samba Member
Joined: April 12, 2004 Posts: 1066 Location: crockett, ca
Posted: Fri Dec 23, 2011 12:32 pm Post subject: |
yellow73kubel wrote: |
X2 on the General grabber AT2;s I'm running 215/75/15's front and 235's rear. They look great on the car, and handle WAY better than the NANCo's 700x15's I had on there before. Yes my Thing is lifted to fit the tires...
If your looking for stock fitment and aggressive check out the mudder buckshots that Rev has on his Thing
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...;start=120 |
Posted: Sat Dec 24, 2011 9:01 am Post subject: |
I heard that the military tires do not do well on the hiway too. I am using the stock 15 inck wheels that came with my 70 with reduction tran. And yes
I am trying to find the tallest most agressive tire I can. Does anybody know how the mickey thompson e78x15 tires do on the hiway. the discription says offroad only. |
