birddog1148 Samba Member
Joined: June 03, 2005 Posts: 921 Location: Sandusky Ohio at my Brewery playing with cars.
Posted: Mon Dec 26, 2011 5:10 pm Post subject: |
busdaddy wrote: |
Well from a quick browse through your bug beam fix thread it looks like the torsion tube won't be a big challenge for you, here's how I did one (it looks like you don't have to deal with PO attempts to disguise it so you're already a few steps ahead of me): http://www.thesamba.com/vw/forum/viewtopic.php?t=455598
BTW congratulations on the AA and sober part, keep it up! |
After reading your repair I knew I could do it, it was insperational I tell 'ya _________________ '69 Baja, Crusty 62 bug
I Got Your Jeep Thing! Now It Hurts When I pee.
Cigarettes are like squirrels, they are both harmless until you put one in your mouth and light it on fire. |
Posted: Tue Dec 27, 2011 10:29 am Post subject: |
Found this in a cubby under the sink
Posted: Wed Dec 28, 2011 8:55 pm Post subject: |
Got the plugs changed and a new rotor on it today. Was working on the electric when the neighbor came in and and started BSin' and ended the working. Slower night at work so I got the carb rebuilt and ready to go back in. The used one I put on as a bandaid seems to have developed and accelerator pump circute problem, cuts out whwn I step on the gas but is ok if I ease into it.
Ordered new exhaust gasket to fix the leaks, some spare fuses and a shifter bushing kit this morning. CIP was having a sale.
Need to get the brake lights and rear turn signals working so I can take a spin around town before the first of the year.
Besides the nurse that helped me get it to the shop wants a ride. _________________ '69 Baja, Crusty 62 bug
Posted: Fri Dec 30, 2011 5:06 pm Post subject: |
Well, spent a good 6-7 hours on the old girl today, but no pics. After rebuilding the carb it wouldn't stay running or idle. So I started the day adjusting the valves. Then I took the carb back off and cleaned the main jet passage out again. Then I put a new fuel pump on. This new Airtex fuel pump had the lines mis-labled on the instruction sheet causeing no fuel to flow. Once I figured that out the day got better. The idle seems a little high but it has an 009 and not a vacume advance dist on it, wants to die below 1000rpm. Still cant get the brake lights or headlights to work, but that was late in the afternoon. On a positive note, looks like the PO replaced all the front brakes before it was parked, the flexible lines look brand new, no rust onn the fittings. _________________ '69 Baja, Crusty 62 bug
Posted: Thu Jan 05, 2012 11:34 am Post subject: |
Brake lights are fixed I think. Went and found what I need to make the sheet metal brake for my HF 20 ton press and so I can bend up some 12 ga steel. Gonna try to build the brake this weekend, getting the stuff tomorrow I hope.
A little bling for the dash.
Have these new unused coil overs that came with a bug pan that I will NEVER use on the baja, but I hear they work on the front of a bus?
And can a rear sway bar for a bug be addapted to use on a bus? Just asking cause its another part that I have and didnt think I would use.
Gonna be another VW weekend in the shop, can't wait. _________________ '69 Baja, Crusty 62 bug
Posted: Fri Jan 06, 2012 10:55 am Post subject: |
Picked up most of what I need to build the press brake for my HF 20 ton press.
Also picked up some sheilding gas and a sheet of 12ga to bend up some new floor supports/outriggers. Going to weld up the brake this weekend.
Posted: Sat Jan 07, 2012 2:32 pm Post subject: |
Press brake as it sits today. Ready to start fabbing outriggers.
Posted: Mon Jan 09, 2012 10:30 am Post subject: |
Decoded my M Plate.
Bus was built on tuesday 8 June 1971
imported to Boston or Baltimore
as a 211 delivery van. _________________ '69 Baja, Crusty 62 bug
Posted: Wed Jan 11, 2012 11:28 am Post subject: |
Still waiting on the turn signal switch.
Ordered a bently and it shipped today.
Amazing how a vacume leak affects the way it runs, the vacume port on the left intake that I am guessing was the vacume signal source when it had a vacume advance dist had a crack in the hose and bolt cap, fixed that and it runs good now.
Glad the bus came with a new throttle cable, the one in it broke after being tied with electric wire, so I replaced it with the new one.
Hopefully that turnsignal switch comes in, 3 day weekend in the shop coming up. May even work on the underside repairs since I have new sheilding gas, a sheet of steel and a new brake for the press.
Oh, and the shift rod bushings came in yesterday! _________________ '69 Baja, Crusty 62 bug
Posted: Tue Jan 17, 2012 8:12 am Post subject: |
Good weekend, turn signal switch came in and works good, even got a 3.5 mile drive in yesterday. _________________ '69 Baja, Crusty 62 bug
Posted: Sat Feb 04, 2012 4:47 pm Post subject: |
Been working on her just not posting much. Swapped out the 009 dist for a SVDA albieit a cheap one from CIP1. Got the historical tags, still have to get the year tags I have registered so she can wear them. The rebuilt carb is being obstinate when I try to set the idle with the high idle cam off. Bentley in its description of adjusting the 2 piece throtle valve positioner describes adjusting the altitude corrector but its not hooked up so I brought the book home from the shop to study some more.
I found yesterday that the gas pedal and the linkage under the floor have had their holes elongated over the last 40 years or so causing the rod to get out of position and allow the pedal to get stuck down.
So I fixed it.
Before:
After:
Welded the holes up then re-sized them with the grinder and a dremel type tool.
Put a new front shift rod bushing on and added a quick shift kit (Got one for the Baja too)
And found a cargo net in a Subaru Outback at the pick and pull when I went to see what I could salvage off a 72 Super Beetle I had seen there:
Posted: Sun Feb 05, 2012 5:42 pm Post subject: |
Had good weather, the bus running ok, and valid tags today, first time ever with all 3 at the same time. So I took her out for a bath.
And went and visited the parents today and dad had this old Naugahyde stuff he said I could have:
So I can re-do the seats. _________________ '69 Baja, Crusty 62 bug
Posted: Fri Jun 08, 2012 6:06 am Post subject: |
My bus turned 41 today! I haven't had time to do much with it lately. I move it around the shop from time to time and start it when a friend asks if it runs. Did drive it a Memorial day weekend when the Baja was in the shop getting rear disc upgrade.
Anyway Happy BDay "Freedom Rock" as my brother calls it. _________________ '69 Baja, Crusty 62 bug
Posted: Sat Jul 21, 2012 7:51 pm Post subject: |
Pulled the bumper off to get repainted
Been working on getting a 62 bug running
Posted: Sun Mar 05, 2017 6:41 pm Post subject: Re: Birddog's '71 Sportsmobile |
Got the urge to start working on this again, been awhile. _________________ '69 Baja, Crusty 62 bug
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sun Mar 05, 2017 6:54 pm Post subject: Re: Birddog's '71 Sportsmobile |
birddog1148 wrote: |
Got the urge to start working on this again, been awhile. |
It's been 4 1/2 years since your last post. So it's definitely time to work on it again!
Has it been running well for you?
BTW.... I'm uber-jealous of your shop! I only have a one-car garage to work in. |
Posted: Sun Mar 05, 2017 7:12 pm Post subject: Re: Birddog's '71 Sportsmobile |
KentPS wrote: |
Been parked in the front room. Just put a new carb on it and dug it out so it was in the sun for the first time in many years. After a drop camp elk until this past fall I have had the urge to camp again and after tossing the idea of building a teardrop style camper and then just buying a pop up tent camper I decided I would pull it back out and put the money into the bus since I had it. Kind of walked away from VW's for a while and just picking up where I left off. Picked up a sweet MarkV one piece front end for my Baja this weekend as well.[img][/img] _________________ '69 Baja, Crusty 62 bug
Posted: Mon Mar 06, 2017 12:19 pm Post subject: Re: Birddog's '71 Sportsmobile |
Just realized my dog (a GSD) shares the same Birthday as my bus _________________ '69 Baja, Crusty 62 bug
Posted: Thu Mar 09, 2017 7:27 pm Post subject: Re: Birddog's '71 Sportsmobile |
So I had some time to get re-acquainted with this last night. Laying under it looking up making a mental list of what needs work, the rear jack points have me slightly confused. Does the jack point get welded to an outrigger or is it a separate piece that is attached to the big rail? Just want to make sure I order the right parts. Hopefully I will have some time this weekend to get some work done, especially since I made enough room to work in the shop. _________________ '69 Baja, Crusty 62 bug
Posted: Fri Mar 10, 2017 7:35 pm Post subject: Re: Birddog's '71 Sportsmobile |
Got my question answered by calling Wolfsburg west. Going to need all the jack points, 4 outriggers, front crossmember, inner and middle rockers and a few rubber pieces. Looks like I will be spending more on parts than I spent on the bus It is what it is. I still will have to repair what I am calling the frame around the torsion and repair the rear crossmember.
On the inside the cabinets are not in the greatest shape, thinking about painting them to lightens the interioright up. _________________ '69 Baja, Crusty 62 bug
