vin & engine mysteries
1 THING
1 THING is offline
PostPosted: Tue Dec 27, 2011 6:45 pm    Post subject: vin & engine mysteries Reply with quote
decoding my VIN and engine case numbers are near impossible......ive checked "how to keep your VW alive" and every online resource i can get my hands on......anyone want to take a stab at it Laughing
norcalmike
norcalmike is offline
PostPosted: Tue Dec 27, 2011 9:11 pm    Post subject: Reply with quote
what are you trying to decode? I can tell you that a Thing engine case begins with AM
1 THING
1 THING is offline
PostPosted: Tue Dec 27, 2011 9:42 pm    Post subject: Reply with quote
yeah mine doesnt.....on driver's side 2BR/24 000.101.101 4 VW Brazil
passenger side 2BR/22 000.101.102 2 VW Brazil
cant find those numbers, specifically the "BR" label anywhere Laughing
1 THING
1 THING is offline
PostPosted: Tue Dec 27, 2011 9:44 pm    Post subject: Reply with quote
VIN on door pillar sticker and on chasis under back seat match up, plate under hood is missing (i think it was rivoted)
kubelmann
kubelmann is offline
PostPosted: Tue Dec 27, 2011 10:08 pm    Post subject: Reply with quote
Hello?? The VIN of the air cooled vw has a specific pattern. The numbering system for the air cooled engines have a separate very specific numbering system. The same is true of the transaxle... The VW Thing body also has a stamped serial number that is rarely mentioned. I have lots of data on these options and can expand on any of these topics or not... K-mann
1 THING
1 THING is offline
PostPosted: Tue Dec 27, 2011 10:22 pm    Post subject: Reply with quote
well, have you read exactly what i wrote? i found the stamped chassis number and it matches the pillar sticker.....only thing i left out is the huge possibility i dont have an original engine, just want to know it's origins.......no stamped number on base of generator stand, but rather a vw symbol and hints of a number on the filler neck?
1 THING
1 THING is offline
PostPosted: Tue Dec 27, 2011 10:23 pm    Post subject: Reply with quote
but please expand as much as your able or id really appreciate guidance in the right direction for the data
Semper_Dad
Semper_Dad is offline
PostPosted: Tue Dec 27, 2011 11:15 pm    Post subject: Reply with quote
Just what do you want to decode? Based on the information you given to date sounds like you have some sort of replacement engine and not the original AM engine.
74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
World 181 Registry Map:
http://bit.ly/1axDF1r
Gitm registared boys!
Officially, there are only 112 181s in the world
wbrown45
wbrown45 is offline
PostPosted: Wed Dec 28, 2011 8:49 am    Post subject: Reply with quote
We have all read your entry, and you wanted to know if you have an original engine. According to the case part numbers you do not have an original one. You can verify this by obtaining the numbers on the case where it meets the generator stand. That is your engine number.
OK Thang
kubelmann
PostPosted: Wed Dec 28, 2011 9:24 am    Post subject: Reply with quote
VW Chassis Number
The first two digits of a VW chassis number or VIN are the first two digits of the basic model number of the vehicle. For example 32 is a Dasher, 17 is a Rabbit and 18 is a Thing.
The third digit tells you the year of productions. If the first three digits in a VW VIN are183these number indicate that the vehicle is a 1973 Thing.
The last six or seven digits in the VIN are the numbers that indicate the consecutive order in which the vehicle was produced in its production year.
The VIN number on the Thing is located on a silver plate on the driver’s side under the front bonnet. It is also stamped on the chassis tunnel just in front of the inspection plate for the shifter coupler.
The VW Parts Numbering System
VW parts have 9 digits and sometimes a letter at the end
The first three numbers indicate the VW model, for which the type or version that the part was built. For example a part number that starts 181 is a Thing only part. On the other hand a part that starts with 111 is a part that was for a Bug, but now comes the tricky part, but could easily and was used on many other VWs. For example a 111 937 093A is an in line fuse holder that was used on every VW model produced from 1954-1968. The 111 indicated it was designed for a Bug but then VW used it on all of its cars from 1954-1968.
Here is a list of the VW Types and their model numbers
* Models numbers not identified will be added as data is confirmed
Type 1
Bug
111 Standard Bug
117 Bug *
113 Bug *
133 Super Beetle
141 Ghia
143 Ghia
151 Bug Convertible
181 The Thing
Type 2
211 Bus
Type 3
311 Fastback
313 Fastback *
361 Squareback
363 Squareback *
* to be identified
Type 4
411
421
412
461
Rabbit,
171
175
173
177
Scirocco
531
Dasher
321
323
331
The fourth number in the part numbering series indicates what main group or system the parts functions under.
Main Groups
1 Engine
2 Fuel tank, exhaust system, heating system, (air conditioning)
3 Transmission
4 Front axle, steering, (differential)
5 Rear axle
6 Road wheels, brakes
7 Hand lever system, brake cluster (frame)
8 Body
9 Electrical equipment
The next two numbers (or the 5th and 6th number) indicate the subgroup system
If the 5th and 6th number are “98” this indicated a repair kit
The final three numbers the actual part number within the main group
A letter at the end of a part number indicates that the part is a modification of the originally designed part. It denotes an upgrade or change. Sometimes it indicates a model specific part that was modified to meet a specific need such as the Thing CVs.
citroen
citroen is offline
PostPosted: Wed Dec 28, 2011 10:30 am    Post subject: Reply with quote
the numbers i think he is seeing is the casting numbers on the side of the engine case halfs on the bottom side of the case it sounds like you have a replacment case that has not had a number stamped on it or it is a rebuilt engine with a new case that has never been stamped
///Mink
///Mink is offline
PostPosted: Wed Dec 28, 2011 11:18 am    Post subject: Reply with quote
That's because those are the part numbers of the case halves, not the engine serial number. They will not be in any list.
kubelmann
PostPosted: Wed Dec 28, 2011 11:29 am    Post subject: Reply with quote
Here is an example of the engine number stamp on the engine case below the generator stand.
kubelmann
PostPosted: Wed Dec 28, 2011 11:41 am    Post subject: Reply with quote
Here is a factory Thing case #AM 013099
uberautowerks
uberautowerks is offline
PostPosted: Wed Dec 28, 2011 11:52 am    Post subject: Reply with quote
The numbers on the filler are 1-4-3-2, which is the firing order
The lack of numbers on the case directly under the filler most likely indicate a replacement engine of some kind either dealer provided of aftermarket built with what was at some time a new, replacement case.
OR
If memory serves, the type 3 engines had their case number to the right of the distributor on the ridge at the case half seam.
Keep in mind that the VIN has ZERO relation to the original engine serial number.
The only thing to "Decode" about the VIN is the year or production, which is the 3rd number of your VIN. The third number is the last number of the year.
So...
183 = 1973
184 = 1974
Got it??
--- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black)
1 THING
1 THING is offline
PostPosted: Wed Dec 28, 2011 4:17 pm    Post subject: Reply with quote
i do not have numbers in either of those PLaces....engine or generator stand....all i see is that vw stamp in the upper left of your photo on the neck of the fill tube......my fault, i should have been more clear i guess.....the post above where the individual numbers of the "VIN" are what i was wanting to decode........that tell what each digit means, but i couldnt find a list for what the individual numbers mean (where made, etc)
thanks so much for the help....ill have to try and find an engine stamp somewhere Laughing
1 THING
1 THING is offline
PostPosted: Wed Dec 28, 2011 4:19 pm    Post subject: Reply with quote
OR
So...
183 = 1973
184 = 1974
Got it??
i do understand, i really appreciate the info!!!! ill look beside the distributor to see if i can find my numbers, i guess it's possible there are none?
uberautowerks
PostPosted: Thu Dec 29, 2011 9:49 am    Post subject: Reply with quote
1 THING wrote:
I do understand, I really appreciate the info!!!! I'll look beside the distributor to see if I can find my numbers, I guess it's possible there are none?
The replacement cases had no serial numbers.
- Douglas Adams -
'74 Thing (White)
citroen
citroen is offline
PostPosted: Thu Dec 29, 2011 5:26 pm    Post subject: Reply with quote
if you had a type 3 case the numbers would be on the top but the main difference is there would not be a hole for the dipstick it sounds like you have a replacement case
1 THING
1 THING is offline
PostPosted: Thu Dec 29, 2011 6:36 pm    Post subject: Reply with quote
im guessing ido, looked over the whole case(everything not blocked by the body of the car) and couldnt find serials anywhere
replacement it is......pewp! Laughing
