Bassyaks Samba Member
Joined: October 06, 2010 Posts: 1137 Location: S.E. Connetitcut
Posted: Fri Dec 23, 2011 8:49 pm Post subject: 2.1 Temp gauge questions |
87 2.1 westy
My temp gauge in the dash cluster is dead, my question is "does the gauge have any correlation to the ECM. Or does the temp signal going to the brain come from another source.
Here's my problem, poor gas mileage, I went from 16 to 12 , But it runs great, starts great , idles great.
I'm not sure if I'm running in a rich setting from the brain or if the O2 sensor is acting up.
Does "winter" gas effect the mileage that much?
THX.
Happy Holidays everyone |
msewalson Samba Member
Joined: September 14, 2009 Posts: 544 Location: Grand Junction, Colorado
Posted: Fri Dec 23, 2011 9:20 pm Post subject: |
I remember reading a recent thread that someone mentioned gas mileage will decrease during the winter. I think it's because the time it takes to get to operating temperature is longer. My commute to work is pretty short and my mileage wasn't the best but noticed a huge difference on a recent trip down to Ouray to go ice climbing.
Matt _________________ 87 Syncro w/EJ22 |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Dec 23, 2011 9:49 pm Post subject: |
The gauge is fed directly from the temp sender on the front of the t-stat housing...
(edit: removed reference to incorrect sender #)
Crawl under the van ahead of the driver's rear tire, check your connections & report back.
Someone else will have to help w/the MPG problem... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9940 Location: Orbiting San Diego
Posted: Fri Dec 23, 2011 10:04 pm Post subject: |
The gauge sender is number #3.
#1 and #2 are used by the fuel injection. #1 is in the airflow meter and is part of it. Calling the gauge sender #1 misleads people because the fuel injection trouble shooting references the true #1.
Mark
dhaavers wrote: |
The gauge is fed directly from the temp sender (#1) on the front of the t-stat housing.
Someone else will have to help w/the MPG problem... |
Posted: Sat Dec 24, 2011 11:01 am Post subject: |
Thanks, That's what I was looking for.
Happy Holidays Everyone |
Timwhy Samba Member
Posted: Tue Dec 27, 2011 8:00 pm Post subject: |
crazyvwvanman wrote: |
The gauge sender is number #3... |
Edited and corrected - thanks.
I tried but had not seen sender #'s specified anywhere in Bentley...???
FWIW, still suspicious of the gauge sender &/or connection for the OP's problem... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Thu Dec 29, 2011 2:39 pm Post subject: |
I and II are labeled as such in various places, though their generic names are used in other places instead or in addition.
Bentley page 24.28 has the Temp I test procedure.
Page 24.32 has Temp II.
The wbx models have 3 temp senders. Since the two fuel injection temp senders use the official labels Temp 1 and Temp 2 that leaves the third for the gauge, unlabeled by a number, so lets call it #3 rather than a number already in use by the other senders.
Mark
dhaavers wrote: |
FWIW, still suspicious of the gauge sender &/or connection for the OP's problem... |
Posted: Thu Dec 29, 2011 2:52 pm Post subject: |
...I and II are labeled...wbx models have 3 temp senders...lets call it #3... |
Got it. Consider me scolded.
Happy New Year! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
