What starter to buy.
livy
livy is offline
PostPosted: Thu Dec 29, 2011 5:21 pm    Post subject: What starter to buy. Reply with quote
i just put in a new heavy duty battery, but my car cranks real slow, not only when it hot but when it's cold too. I think my starter is dragging and will have to be replaced. I am asking the question of "What is the best starter to buy for my stock 1600 Thing? Any help will be appreciated.--Larry
citroen
citroen is offline
PostPosted: Thu Dec 29, 2011 5:35 pm    Post subject: Reply with quote
bosch SR17X the same one that came on the thing it is the heavy bosch starter, the sr15 x is the one for the bug it uses a bushing in the transmission the sr17x does not
FV195
FV195 is offline
PostPosted: Thu Dec 29, 2011 6:20 pm    Post subject: Reply with quote
it could just be your bushing, had that problem in my formula vee race car, fully charged battery, would start one, then needed jumped. bushing was baly worn and moving in the hole causing binding. check that before you spend the $$$ for a starter, but the ones that don't use the bushing are the way to go, is the one on your car a gear reduction? they spin slower. Fv's use a 6volt starter with 12volt system, spin real fast, hope this helps
citroen
citroen is offline
PostPosted: Thu Dec 29, 2011 9:56 pm    Post subject: Reply with quote
all things use the no bushing model unless someone changed the tranny or starter
livy
livy is offline
PostPosted: Fri Dec 30, 2011 4:11 am    Post subject: Reply with quote
Thanks for the info. What do you think about one listed as a gear reduction starter motor. My Thing might not need it but if it will last longer it might be a good investment.--Larry
citroen
citroen is offline
PostPosted: Fri Dec 30, 2011 6:13 am    Post subject: Reply with quote
stay with bosch it works
kubelmann
kubelmann is offline
PostPosted: Fri Dec 30, 2011 6:21 am    Post subject: Reply with quote
Another name for the OE Thing starter is auto-stick or semi-automatic starter. As a result of its heavier duty service this starter was used on the type one cars with the auto-stick transmission. This starter was also the stock unit on 68-79 auto-stick bugs and 68-74 ghias, 73-75 buses and Porsche 911 65 - 71
If you search ebay <vw starter sr17x> today you will find 21 of these items ranging in price from $35 - $175
citroen
citroen is offline
PostPosted: Fri Dec 30, 2011 7:05 am    Post subject: Reply with quote
compare starters thing on top bug on bottom
kubelmann
PostPosted: Fri Dec 30, 2011 7:27 am    Post subject: Reply with quote
yes!! great comparison images.. The top higher powered sr17x has a .80 kw power rating. While the standard bug sr15x has a power rating of .70 kw Additionally the sr17x has a significantly stronger nose.
livy
livy is offline
PostPosted: Fri Dec 30, 2011 4:09 pm    Post subject: Reply with quote
Thanks for the pictures. I also noticed on the bottom view that it looks like it is supposed to go into a bushing and the top one is self contained.--Larry
kubelmann
PostPosted: Fri Dec 30, 2011 5:14 pm    Post subject: Reply with quote
This has been a great thread. Like the old days. A guy had a real question. but was not able to use the lingo of the inside clan. Then old guys hooked up to what the new cat was after. and, it was like a craft guild where knowledge was shared asn scent to the next group. PERFECT. Thanks guys...
1 THING
1 THING is offline
PostPosted: Sun Jan 01, 2012 8:04 am    Post subject: Reply with quote
does the sr17x vary for auto or manual transmission? most advertisement is "auto transmission", but im pretty sure all Things are manual
citroen
citroen is offline
PostPosted: Sun Jan 01, 2012 9:42 am    Post subject: Reply with quote
17x works for auto or stick 15x works for only stick
1 THING
1 THING is offline
PostPosted: Sun Jan 01, 2012 10:09 am    Post subject: Reply with quote
well, im thinking about replacing mine......it takes four separate turnovers/start attempts for mine to start AND idle (barely).......first three tries and there's a turnover but no start (cold engine)........seems like the starter tries immediately but sounds like it's dragging
it, however, does do better with one compression of accelerator instead of pumping it, which is what ive done before
Windisch
Windisch is offline
PostPosted: Sun Feb 19, 2017 2:58 pm    Post subject: Re: Bosch SR17X starter motor--who sells them NEW? Reply with quote
I need a Bosch SR17X starter for my 1973 Type 181 Thing, but I want a NEW (not remanufactured or rebuilt) unit. Does anyone know who sells new stock that are NOT remanufactured units? Thanks!
1974 Super Beetle
1973 Type 181 'KubelThing'
Der Volkswagen ist ein Ausdruck der deutschen Kultur der Allrad Art ...
kubelmann
PostPosted: Sun Feb 19, 2017 3:40 pm    Post subject: Re: What starter to buy. Reply with quote
One thing that might help your search:
Bosch SR17X is the part number for a rebuilt starter
Bosch SR17N is the part number for a new starter
Wagonwerks sells new SR15N
here is a NOS unit
http://www.thesamba.com/vw/classifieds/detail.php?id=1659206
[email protected]
waugamans@aol.com is offline
PostPosted: Sun Feb 19, 2017 5:44 pm    Post subject: Re: What starter to buy. Reply with quote
Wonderful thread, I might have to get one to add to the spare parts shelf, thanks guys.
kubelmann
PostPosted: Sun Feb 19, 2017 5:53 pm    Post subject: Re: What starter to buy. Reply with quote
Consider this "spare parts" for $99
http://www.thesamba.com/vw/classifieds/detail.php?id=1737897
a pair for $40 ea. clean and check
http://www.thesamba.com/vw/classifieds/detail.php?id=1908853
Bargain of the post $19.95 plus ship
http://www.thesamba.com/vw/classifieds/detail.php?id=1947912
Crown Jewel of the Post NOS (actual) $150 get this one folks...
[email protected]
PostPosted: Sun Feb 19, 2017 6:05 pm    Post subject: Re: What starter to buy. Reply with quote
Thanks kubelman.
kubelmann
PostPosted: Sun Feb 19, 2017 6:07 pm    Post subject: Re: What starter to buy. Reply with quote
Especially for you... Always a pleasure....
