HoustonPhotog Samba Member
Joined: February 20, 2013 Posts: 1514 Location: Houston, TX
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Wed May 07, 2014 1:37 pm Post subject: |
Our extinguisher is mounted vertically just inside the front edge of the slider mounted to the side wall. Might install a second mounted horizontally on the front of one of the seat pedestals, just in case.
Flashlights? we have several of the small LED ones and headlight ones sprinkled around. _________________ '87 Westy in Wolfram Grey Metallic |
WestiCoast Samba Member
Joined: June 25, 2012 Posts: 194 Location: Oceanside Ca
Posted: Wed May 07, 2014 1:53 pm Post subject: |
I keep my flash light behind the drivers seat. Mind is in a small basket but you could mount yours to the cabinet and run power thru the cabinet or down thru the battery box. |
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1417 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Wed May 07, 2014 1:58 pm Post subject: |
Where ever you decide to put them, IMO it’s best that they not be placed where passengers could encounter them in a crash VW and other OEM’s are quite careful not to put any hard & pointy object near belted in passengers :0) _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
the craigness Samba Member
Joined: March 25, 2014 Posts: 188 Location: Queens, NYC
Posted: Wed May 07, 2014 2:28 pm Post subject: |
You might want to consider an automatic unit in the engine bay. There is plenty of room in there to the right next to the air box. When these things burn, it's like the LA Riots... And it always starts in the engine bay.
http://www.vwcampervansuk.co.uk/servicingmot.html |
gene l Samba Member
Joined: August 31, 2013 Posts: 136 Location: LOS OSOS,CA.
Posted: Wed May 07, 2014 4:09 pm Post subject: |
I keep my 5lb halon secured by the front table leg and parking brake so I can grab it from front or back. I also keep a 1 lb halon right inside the sliding door. Have flashlights all over the place. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Wed May 07, 2014 8:22 pm Post subject: |
Wow, thought I was the only one with a Halon still around.... Great stuff when you need it.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1530 Location: Vancouver BC
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Wed May 07, 2014 10:25 pm Post subject: |
Thinking you really need two extinguishers, one at the open sliding door and one near you in the drivers seat when your driving so it is at hand ready to go if something happens when your going down the road.
My own choice spot is on the inside of the drivers door so if you have to open the door to get it it is right in front of you, Trying to mount it on the door panel is a challenge I'm working on. |
