Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Jan 02, 2012 6:51 pm Post subject: Tools for Bays |
On the Vanagon forum there is a thread for Luxury Tools
http://www.thesamba.com/vw/forum/viewtopic.php?t=410934&highlight=tools
Rockerarm suggested a thread for bays.
" ... but wish Everett would start a section on tools, tips, ideas, basic diagnostics, etc."
This is an attempt to get a thread started on common, specialty, and homemade bay tools.
Hopefully we'll soon have a photo of Aeromech's engine run stand and brake bleeder
Aloha
tp
Malokin Martin Samba Member
Posted: Mon Jan 02, 2012 7:06 pm Post subject: |
I'm sure folks have seen this before, and I'm sure there will be some more spectacular additions, but I've found the $2 "brake adjustment tool" invaluable in getting the bales/valve cover springs off and on. No more bloody knuckles!
Completely worth it. |
louis-123 Samba Member
Joined: March 21, 2004 Posts: 438 Location: Montréal, Québec!
Posted: Mon Jan 02, 2012 7:15 pm Post subject: |
heres one tool i got to adjust the valve, did not try it yet but seems like its gonna make the job easier!
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Mon Jan 02, 2012 7:50 pm Post subject: Re: Tools for Bays |
Tom Powell wrote: |
a lift
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
grandpa pete Samba Member
Posted: Mon Jan 02, 2012 9:26 pm Post subject: |
I have a candidate for the best luxury tool...How about this...LUXURY TOOL; 14 carat gold plated 1/4 inch drive craftsman rachet in a nice wooden case with a felt liner ...sears offered them in 2002 to commemorate 75 years of the craftsman name...I will try to get a photo tomorrow..the wife still has all the christmas photos in the camera _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Desertbusman Samba Member
Posted: Mon Jan 02, 2012 9:32 pm Post subject: |
louis-123 wrote: |
To adjust what valve? _________________ 71 Superbug
71 Westy |
Posted: Mon Jan 02, 2012 9:36 pm Post subject: |
Valves. |
Posted: Mon Jan 02, 2012 10:46 pm Post subject: |
I sure don't see anything there that will work on my valves. _________________ 71 Superbug
71 Westy |
levi20AE Samba Member
Joined: June 24, 2005 Posts: 485 Location: Las Vegas, NV
Posted: Tue Jan 03, 2012 12:53 am Post subject: |
Gotcha! Thanks. I didn't understand the machining in the top picture. _________________ 71 Superbug
71 Westy |
Posted: Tue Jan 03, 2012 1:38 am Post subject: |
levi20AE wrote: |
i believe the idea is that you insert a flat head screwdriver through the hole he has drilled. |
I've looked at those photos and I don't see how that tool would work on valve adjustments. A screwdriver would fit through the hole, but what holds and tightens the locking nut? Better photos of the working end might clarify how it is used. I googled Elite valve adjustment tool, but no results. In the process found this tool on Amazon http://www.amazon.com/Motion-Pro-Tappet-Adjustment...mp;sr=8-42
The photo shows 8mm, but the description says "Fits any screw-type tappet adjuster with 8mm, 9mm or 10mm adjusting nut combined with either a 3mm, 4mm, square or straight screwdriver type adjusting screw" I don't recall the size of the adjusting nut on the 1600. If it's 10mm this tool should work.
Edit: Word from louis-123 and DBM is the locking nut is 13mm so this tool would not work on a type 1 engine, but it sure is pretty. It looks easy to use: Turn the handle to loosen the nut. Hold the handle with three fingers and turn the knob with thumb and index finger. Insert feeler gauge with the other hand. Turn the knob to adjust and tighten the nut with the handle. Only requires two hands, instead of three for a wrench, screwdriver, and feeler gauge.
For me, I'll stick with my box end wrench and screwdriver.
Aloha
tp
Posted: Tue Jan 03, 2012 4:57 am Post subject: |
Tom Powell wrote: |
Aloha
tp |
^^^Ditto Tom.^^^
Our box end wrenches can hang on the nut while those other things will fall off if they arn't held. And they are so fancy they would be a bitch to clean off if they fell in the dirt.
I've always been a bit curious about this other type. First saw them in Rocky Mtn. Motorworks catalog in the '90's. http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D7073%2D11
As far as the one up higher in this thread evidently it has a hex or 12 point socket in the head but it still looks like it has some machining other than just a hole for a screwdriver. Photo doesn't show it real well. _________________ 71 Superbug
71 Westy |
Posted: Tue Jan 03, 2012 4:59 am Post subject: |
its open all thrue, once the bolt is slacked and you can keep the tool hanging from the screw driver and adjust the valve with the screw driver. The 90 degree angle can spare your knuckles. It was bought this way..
Its nothing super special but according to my friend it works really well. havent tried the tool since the bus is stored for winter...
I believe the nut is 13mm. |
Posted: Tue Jan 03, 2012 5:04 am Post subject: |
Let us know how well it works and how well you like it Louis. Don't know about T-4's, but T-1's are 13mm. _________________ 71 Superbug
71 Westy |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3850 Location: Ann Arbor, Michigan
Posted: Tue Jan 03, 2012 5:22 am Post subject: |
The two crucial tools I acquired early in my VW days were a 13mm S-shaped box end wrench for the rear nut of the carb-intake manifold connection (upright engine) and a 10mm deep offset box end wrench for the intake manifold-to-head nuts on a single port engine. (still the only snap-on tools I own - except for wobble drive socket extensions)
I always tell myself I am going to buy a brake spring tool but still manage with a pair of needle nose pliers... _________________ '71 Westy |
birddog1148 Samba Member
Joined: June 03, 2005 Posts: 921 Location: Sandusky Ohio at my Brewery playing with cars.
Posted: Tue Jan 03, 2012 6:25 am Post subject: |
my home made oil pump puller
Another tools and tips area on another forum but should have some familiar people.
http://www.shoptalkforums.com/viewforum.php?f=49 _________________ '69 Baja, Crusty 62 bug
I Got Your Jeep Thing! Now It Hurts When I pee.
Cigarettes are like squirrels, they are both harmless until you put one in your mouth and light it on fire. |
thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Tue Jan 03, 2012 11:02 am Post subject: |
A good metric wrench set and good beer. Everything else falls into place _________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
Tcash Samba Member
