Mundopacheco Samba Member
Joined: November 14, 2006 Posts: 439 Location: Durango, Colorado
Posted: Mon Feb 20, 2012 10:14 pm Post subject: |
Ha, I see that...it was actually me thinking it was a tire carrier of some kind. Pretty clever. |
2doorsdown Samba Member
Posted: Mon Feb 20, 2012 11:10 pm Post subject: |
It seems like a great idea for some weatherproof storage in an area most of us with bigger tires have available. I think I might look into it. I have often thought of what I would carry there that wouldn't be needed often...... you would need a quick release of sorts to get in and out without having to wrench that 19mm bolt off everytime! I really like it. |
danfromsyr Samba Member
childofthewind Samba Member
Joined: October 19, 2010 Posts: 763 Location: Eastern Sierra
Posted: Sat Mar 03, 2012 4:36 pm Post subject: |
dangerbus wrote: |
we just couldn't get enough storage into the westy layout.
here's our solution.
still putting on finishing touches, but its been working great so far and the plan is to (eventually) do some extended travel/live out of it as needed.
It's clearly not piano quality (like nacho's awesome camper), but since we had to build this outdoors with battery powered tools it's meeting our needs and fits two people plus dog fairly comfortably...
tons of rear storage for tents/tools/clothes/guitar and a full wetsuit/snorkeling/fins set.
interior "lounge" setup during the day and all important fridg.
tire will be housed up on the rack during extended trips to allow more room for food storage
bed pulled out (without cushions)
obviously the splitties are a bit smaller than what most of you are dealing with, so you'll see that the cabinet on the back right (holds our bedding) has to be held open to allow my feet to go through to the bulkhead. 2 burner stove is under the black panel by the door with food storage above and water/pump under (have since added a faucet facing the door)
a simple table attached to cargo door for happy hour, and the chairs stash above the rear cabinets (curve matches the roof almost perfectly)
still working on the wiring/lighting
refining storage inside and on top
still need a mount for the propane grill... but at this point most work is stalled until the weather warms up and we can get out to work on it again. |
What a beauty! Great to meet you at Lucky Lab the other day.
Sweet and safe travels to you!
Luka _________________ 1987.5 wolfsburg hardtop; 2.1
“As for me, I am tormented with an everlasting itch for things remote." - Melville |
Posted: Sat Mar 03, 2012 4:47 pm Post subject: |
sageandspirit, do you like this shower? I'm in need of some sort of privacy/shelter whilst showering for my next adventures on the road. _________________ 1987.5 wolfsburg hardtop; 2.1
brab Samba Member
Posted: Mon Mar 05, 2012 10:36 pm Post subject: |
I am looking to put a galley cabinet behind the drivers seat with Stove, sink and fridge (similar to the westy kitchen cabinet). Any reason not to put the stove next to drivers seat and sink to rear of van? Or is there a reason that the sink should be on the right (front of van)? _________________ Trotro - 87 Syncro Vanagon 40K original miles and starting to count. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Tue Mar 06, 2012 8:40 am Post subject: |
brab wrote: |
I am looking to put a galley cabinet behind the drivers seat with Stove, sink and fridge (similar to the westy kitchen cabinet). Any reason not to put the stove next to drivers seat and sink to rear of van? Or is there a reason that the sink should be on the right (front of van)? |
Make sure the burners are not close enough to the drivers headrest or curtain tie back area so that they can get burnt or you may get an unpleasant result. _________________ Dave O
The Western Syncro build
brab Samba Member
Posted: Tue Mar 06, 2012 8:45 am Post subject: |
If I get the Iota 3-stage 115 AC, do I need an AC/DC Fridge when on shore power or can I use the charger to charge both the battery and run a DC only fridge? If so should I get the larger 45Amp charger? Thx _________________ Trotro - 87 Syncro Vanagon 40K original miles and starting to count. |
Wolfphotos Samba Member
Joined: July 31, 2010 Posts: 117 Location: Toronto Ontario
Posted: Fri Jan 04, 2013 12:16 pm Post subject: |
I've been asked by a fellow sambatista to revive this thread and to post some photos of the interior of my van- he's been trying to pull together ideas for a custom interior over the last few months, so let's see what we can do to help him out.
I did not design, or build this interior, so technical questions are a little beyond my realm of knowledge.
Having lived with it now for a couple of years, I would have to say that there is really nothing that I would change, other than I would have probably used a more industrial material than the cherry veneer that was used, probably an industrial rubber surface, much like what I used for the door of the domestic, and the top of the propex. The stuff is indestructible, no need to worry about scratching (important with a Rottie onboard) and can be renewed to look like new with an application of silicon tire cleaner.
The 2 burner Brinkmann stove is removable when fuelled by a small propane tank that's kept in the wide drawer at bottom right, but can also be attached to the van's propane tank for inside use, although for that, I use a cheap ($15) Korean butane stove, usually for the morning coffee. That fits in the top right drawer, along with a chopping block.
The space under the seat holds tools and larger items.
The drawers hold the cleaning stuff, spices, cutlery, pots, pans, and pantry items.
The roll top we use for all of the clothes, towels, etc
Top rear space holds fleece blankets and rain gear, and reminds you that the hangover is not the worst thing in the world when you smack your head into it getting up in the morning.
The rear side holds the bar, and importantly, can be accessed from the inside as well as from the back door.
The rear is pretty self explanatory- the space on bottom left easily holds 2 chairs, and the middle space over the engine has room for a metal roll top table.
Prior to this van, my wife and I toured on a motorcycle, and then a 2 seater convertible, so we are expert at the art of packing sparingly, but with all this space to fill, we now bring more stuff than we've ever really needed- and the bar just keeps expanding.
Cheers, and Happy New Year to all!
Wolf |
lloydy Samba Member
Joined: September 15, 2010 Posts: 715 Location: cheam surrey
Posted: Fri Jan 04, 2013 1:47 pm Post subject: |
I like the drink called knob
Nice layout on the interior though _________________ 16" syncro multivan pop top AHU TDI
“Give a man a fire and he's warm for a day, but set fire to him and he's warm for the rest of his life.” |
Posted: Fri Jan 04, 2013 7:08 pm Post subject: |
"I like the drink called knob "
Yup, a Knob in the hand is worth two in the bush. |
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Fri Jan 04, 2013 8:53 pm Post subject: |
Wolfphotos wrote: |
I've been asked by a fellow sambatista to revive this thread and to post some photos of the interior of my van- he's been trying to pull together ideas for a custom interior over the last few months, so let's see what we can do to help him out. |
Wolf, thanks alot for posting, much appreciated!
This gives me some good ideas for a future remodel. That is a very nice interior.
The one thing I struggle with is that my bed is virtually always down/out, since it saves me having to bunch-up/layout any blankets, and lets my dawg have the life of luxury back there while driving too. This means the back bed is cluttered with luggage during the trip, and then stowed up top on the "shelf" (2nd bed) when we stop.
Because of this, the under-seat storage and the little closet next to the fridge are even harder to utilize for me - so factoring that into things will be the challenge.
Currently, i'm thinking of putting a 1/2-sized pull-out drawer box under the bed, in front of the rear bench storage box. This would leave the rear heater vent unrestricted, give accessible storage, and if/when the seat is ever up for guest passengers, i can just move the box forward (just behind the front passenger seat). The box can also make a good step to get up to the upper bunk (again, in case of guests)
Thanks!
P.S.
Really do love the bar - how much clinking/clunking do you get from the bottles? _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Sat Jan 05, 2013 7:23 am Post subject: |
My dog has a life of luxury back there as well- but NEVER on our bed. He has his own bed, as you can see, which we slip under the bed when we pull out the back seat. Whatever the configuration, he can't believe his luck that we are sharing his "crate" with him and he couldn't be happier.
My wife insists we have a port-pottie on board for her midnight necessities- this fits perfectly on top of the propex, and also serves as my step to get to the penthouse, where I sleep.
Both the port-pottie and the bed block access to the 2 bottom left drawers, but we keep stuff there that we only use when cooking dinner, so getting at them is never really an issue. The porta-pottie and the footstool that I use to anchor my camera bag while driving is removed from the interior, which transforms into the pre dinner cocktail lounge, with fluid access to everything.
And no, there's not much clinking- I've lined all the shelves and drawers with non slip rubber mats, and the bar is kept packed tightly enough that any movement is not an option.
Cheers.
Wolf |
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Sat Jan 05, 2013 10:04 am Post subject: |
Wolf,
That is an absolutely stunning interior you have! I've got a few crafty ideas just looking at it. I appreciate you posting up these photos.
The whole idea of slide out drawers as opposed to a static shelf is a phenomenal improvement over stock. For Westfalia do this originally was probably cost prohibitive, but if you want to build your dream interior from the ground up, this clearly seems way to go.
And yes, your strategy to keep the bar tightly packed avoid bottles clinking together is a good one.
Cheers,
CJ _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
mathieux46 Samba Member
Posted: Sun Jan 06, 2013 7:59 am Post subject: |
Hi,
Here's mine:
rc3 Samba Member
Posted: Sun Jan 06, 2013 10:15 am Post subject: 1987 weekender |
Just finishing my weekender
Posted: Sun Jan 06, 2013 11:30 am Post subject: |
Nice units!
Those are some serious kitchens. How much cooking do you guys do in your vans?
I've only done it once, and I found that the ventilation and cleanup issues caused me not to want to do it again. Indoors now, it's coffee or soup only.
Am I missing something here? |
Posted: Wed Jan 16, 2013 9:43 am Post subject: |
Wolfphotos wrote: |
Nice units!
I cook in mine, but if I had an awning, camp stove, and foldy table is probably cook outside.
Never use my sink.
Wolf, do you have a table? Or slide out "cutting board"? _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Wed Jan 16, 2013 12:19 pm Post subject: |
I do have a table, stored in the slot under the rear bed, just over the engine compartment, which I've seldom had to use- picnic tables provide more work space. If it's raining we usually pull a picnic table under the awning, otherwise the table gets set up.
Unfortunately, I have no photos of it, but here's the kitchen in full operation in picnic table mode-
We use a couple of large stainless steel bowl for wash-up- both ourselves and dishes. They also do multiple duty as salad bowls, etc.
Water we carry in a 25 litre jerry can, clearly labeled so no one takes us for pyromaniacs when we start pouring.
