cage66 Samba Member
Joined: January 14, 2005 Posts: 2039 Location: reno,nv. cultwagen.com
Posted: Sun Jan 08, 2012 6:55 pm Post subject: 62 turkis standard lowering and lots of cutting. |
I have had this bus for almost 2 years now. And figured I might as well start a build thread here.
PLEASE DO NOT read any more if you feel it is a sin to cut/hack up a VW to lower it.
When I first got the bus I wasnt 100% sure what the plans were. The bus is pretty rusty but fairly complete.
Got a nice tukis decklid from Chris just needed to take off the respray. And a good rear bumper that was flat in the middle.
Bumper before
Bumper after beating on it.
I decided to do something different than I normally would do. So I went through the whole bus suspension and brakes and tossed on some 215/75 15s on some crows feet rims and took it to the hills.
This was fun but I am only 5'6" and hated jumping into it so it had to be lowered.
LAST CHANCE TO TURN AWAY!!
First cutting/hacking was the steering box. Raised it 1.5"
Pulled the beam out and narrowed it 4.75" , sent the spindles to Widefive to be flipped.
Notched frame for tierods
I wanted to do something more than I did on my last bus so I decided to narrow the rear also.
Cut the torsion bars down to match
Now the IRS trans bolts right in with no spacers and gives all sorts of room.
I then modified the arms with a 3" step so I didnt have to notch the frame and made new upper and lower shock mounts
Then I made some adjustable spring plates so I dont have to unbolt the rear to get the tires on and off and I will also be able to set the rear perfectly. If I ever need to get it on a trailer I can raise the front and rear now.
Here it is sitting, will be a little lower when I finish the tubs and put the trans and engine in.
With the rear jacked up you can see how the springplates make a HUGE difference.
I fixed the fenderwells to (one so far)
I just started on the front tubs. Only cut one out so far gotta figure out a nice way to do it.
south_island_surf Samba Member
Joined: September 23, 2004 Posts: 149 Location: Victoria, BC, Canada
drumming123 Samba Member
Joined: April 04, 2004 Posts: 723 Location: Merced, California
Posted: Sun Jan 08, 2012 7:17 pm Post subject: Re: 62 turkis standard lowering and lots of cutting. |
[quote="cage66"]
quote]
I like the hubcaps, where are those from?
Long spoons look good on there. |
cage66 Samba Member
Posted: Sun Jan 08, 2012 7:31 pm Post subject: |
They are KDF caps, they used to be on the 15 window that WagenWest built. Nate let them rust then hit them with clear. they turn up from time to time.
Thanks for the long spoons they made a huge difference.
kanniff Samba Member
Joined: October 12, 2009 Posts: 811 Location: West Coast
Posted: Sun Jan 08, 2012 7:34 pm Post subject: |
I'm glad you started a thread for this pile!
Great job! _________________ 1958 PGSG Standard |
61TXghia Samba Member
Joined: July 17, 2009 Posts: 950 Location: El Paso, TX
Posted: Sun Jan 08, 2012 7:52 pm Post subject: |
Wow, I have a 62 Turkis also. I have to admit, I loved the pics with the tall tires. But I also think you are doing a kick ass job lowering it. Either way, it's your bus, enjoy it man. Great job. what tires were you sporting in the offroading pics? _________________ 62 Standard Type 2 (Nothing Fancy)
my bus: http://www.thesamba.com/vw/forum/viewtopic.php?t=464719
bill may wrote: |
Camping is cheaper than therapy. |
exciter Samba Member
Posted: Sun Jan 08, 2012 8:03 pm Post subject: |
Nice fab work!!!!!! Keep us posted! _________________ Joe
419-236-9781 |
cage66 Samba Member
Posted: Sun Jan 08, 2012 9:10 pm Post subject: |
Thanks, I am excited to do the tubs because I have never used the bead roller I bought and beefed up.
I am sure the bus will get some more rust repair with the help of my friend Mitch Case.
Here is the bead roller. Still need to paint it and maybe get some pinstriping on it.
what I stated with.
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Sun Jan 08, 2012 10:27 pm Post subject: |
WOW! Nice work. Just one improvement to suggest-More Pictures!
PS-Nice job on that decklid (whoda thunk, Huh?) and that rear pretzel! Amazing what a BFH and a concrete slab in concert can achieve! _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
cage66 Samba Member
Posted: Sun Jan 08, 2012 10:44 pm Post subject: |
Thanks again Chris. Both the decklid and bumper look right at home on the bus.
Here is the decklid after stripping the respray and blue paint.
Sorry for the poor quality pics a lot of these are cell pics. |
NAES Samba Member
Joined: September 10, 2003 Posts: 2120 Location: AREA-52 Southern Killafornia
Posted: Mon Jan 09, 2012 12:43 am Post subject: |
HACK! _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
durfeec Samba Member
Posted: Mon Jan 09, 2012 10:28 am Post subject: |
do you have more pics of the adjustable spring plates? im going to build the same for my swing axle cause i have one weaker torsion bar and can never get it perfectly level. right now its within a 1/4 of each other.
how big of tubs are you gonna do? and get some pics of the seat frames when you modify them. lol. still havent had time away from school to get tubs in my bus. _________________ 1960 Bus Panel/Camper |
Mitch Case Samba Member
cage66 Samba Member
Posted: Mon Jan 09, 2012 10:53 am Post subject: |
HAHA
Yeah I need to work on it more.
I basically did the spring plates like this guy
http://www.airsouls.com/how-tos/adj_spr_plates.htm
But to get the hole perfect I torched a hole then cut thin pieces of DOM tubing and welded them inside the hole then ground it flush.
As for the tubs and seat I am thinking I will do 1.5" flat tubs then make a new frame (dont want to hack up a hump back) then use layers of different density foam (harder on bottom to softer on top) taking out 1"-1.5". For the back frame I will move the side mounts down .5" so everything works the same and then shape the foam to look like a humpback.
Hope it works.
And YES Mitch I cant wait to be able to come over and have you work your magic.
Look at Mitches sig line links to see the amazing work he does. |
Posted: Mon Jan 09, 2012 3:26 pm Post subject: |
whoa! didnt even look at the title of the thread. just the author and knew itd be slammed. lol.
anyways, the front turn signals threw me off. they cut in or just a late production date? i though fried eggs started in 64 (late 63 models) with the widehatch stuff. i could be wrong though.
can you remake a newer seat instead of building the seat from scratch? i guess it wouldnt be hard either way since its just round tubing and basic 90* bends.
either way, cant wait to see it. good luck. ill be waiting and watching. _________________ 1960 Bus Panel/Camper |
cage66 Samba Member
Posted: Mon Jan 09, 2012 3:42 pm Post subject: |
Nice, haha
62 is a bastard year, has fried eggs, big tail lights and still has small hatch, fat doglegs and flat wheel wells. |
tnc19 Samba Member
Joined: November 13, 2008 Posts: 246 Location: San Diego, CA
Posted: Mon Jan 09, 2012 8:27 pm Post subject: |
Outstanding work! Simply tight azz work bro! I'm feelin it! Big ups! |
cage66 Samba Member
Posted: Mon Jan 16, 2012 1:38 pm Post subject: |
I wasnt going to do it but figured now was the best time to trim the cradle.
SO, now if the next owner decided to do Air ride it would only need a crossmember and bag mounts welded on, the adjustable plates would also be a HUGE plus for a bag system.
silvertonguedevil Samba Member
Joined: September 26, 2010 Posts: 1692 Location: Vale, OR
Posted: Mon Jan 16, 2012 1:49 pm Post subject: |
Next owner? _________________ -Greg |
cage66 Samba Member
Posted: Mon Jan 16, 2012 1:56 pm Post subject: |
Yeah, just being honest with myself. I always think I will keep something but I think I enjoy the build more than the driving.
If I get rid of this it is only because I need to get rid of it for the 59/60 DD mango project I want next.
It will NOT be cut though.
I do want to get this to a few shows this year. I am in no hurry to off it so it will have to be a good number.
