mrdctaylor Samba Member
Posted: Mon Jan 09, 2012 8:28 am Post subject: Oil change interval + do I have to clean screen each time? |
I have a 1968 Beetle with 53K miles. I've had some recent work done to it and it is running well. My daughter is going to just drive it around our small town so I only expect maybe 2K miles per year max.
My questions are:
1) How often should I change the oil? I go 7500 miles with synthetic in my other vehicles, but obviously this is out of the question for my VW. 1500 miles? Yearly?
2) Is it necessary to clean the screen every time? Or is it acceptable to clean every other time? What if I just changed the oil at 1000 or 1500 miles and did a full screen clean every other time?
I'm just trying to get a feel for what is acceptable for these engines. I did a search on this forum and didn't really find anything addressing it. My apologies if this is something that has been gone over many times. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Mon Jan 09, 2012 9:40 am Post subject: |
You should clean the screen at every oil change. VW even eliminated the drain plug on later engines so the entire plate had to come off just to drain the oil.
As to how often ... I do 2000 to 3000 miles, depending on how dirty the oil looks on the dipstick. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32637 Location: Reading Pennsylvania
torsionbar Samba Member
Posted: Mon Jan 09, 2012 10:04 am Post subject: |
every 3000 miles or 12 months, whichever is shorter, if driven regularly.
every 1500 miles or 6 months, whichever is shorter, if only driven occasionally, and/or only for short trips.
there are other even tighter oci recommendations depending on your climate and driving conditions. see your owners manual: http://www.thesamba.com/vw/archives/manuals/73bug/73T1-62.jpg
you need to take the screen off and clean it and inspect it only for the first few oil changes after you buy a used beetle. there's usually crap in the crank case from neglect, and from the car sitting outside abandoned and undriven. dead animals and insects, leaves, etc. after the first few oil changes, you will have caught all of that on the screen and cleaned it out.
the screen is not an oil filter! every car has an oil pump pickup screen inside the oil pan. it is not unique to beetles. on nearly all other cars however, it is not accessible because it's inside the oil pan. the reason it's accessible on the beetle is that air-cooled engines can run hotter that watercooled engines, and this caused the old 1960's and 1970's oil formulas to sludge. the original reason for removing and cleaning the pickup screen at each oil change was to clean away the sludge! modern oil formulations are much more highly resistant to sludge, and if you use a synthetic oil, the issue is completely non-existant. _________________
Max Welton wrote: |
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed. |
vwible Samba Member
Joined: January 02, 2005 Posts: 160 Location: East Windsor, NJ
Posted: Mon Jan 09, 2012 10:38 am Post subject: Oil Drain Plate |
I took the oil screen out of my car after I added the Berg 1.5 quart sump on my 1600 beetle. The oil drain plate my engine has does not have a drain plug.
I attached a strong magnet to the bottom of the oil drain plate. The entire plate becomes the magnet, rather than only a magnetic plug (as on some other cars). I got the idea from TheSamba, of course.
Most of my driving is short trips of 15 miles or less. I definitely remove the plate at each oil change (1500 miles). There's always a small accumulation of gray gook on the plate, which easily wipes off.
Another plus is that all those electromagnetic waves circulate within the engine -- providing a little bit of downward pull on the crankshaft counterweights on every revolution! _________________ 1970 Tin Top Walk Through Bus |
Posted: Mon Jan 09, 2012 11:10 am Post subject: Re: Oil Drain Plate |
vwible wrote: |
Another plus is that all those electromagnetic waves circulate within the engine -- providing a little bit of downward pull on the crankshaft counterweights on every revolution! |
don't forget to put some of those magnets around your fuel lines. it'll improve your gas mileage up to 27%. _________________
Max Welton wrote: |
jlex Samba Member
Joined: January 23, 2009 Posts: 2902 Location: NW Pennsylvania
Posted: Mon Jan 09, 2012 12:22 pm Post subject: Re: Oil Drain Plate |
torsionbar wrote: |
vwible wrote: |
don't forget to put some of those magnets around your fuel lines. it'll improve your gas mileage up to 27%. |
Yeah... also, I'm not sure it will pick much of anything up if used on the crankcase... isn't most everything inside the engine non-ferrous? Could a magnet really catch anything? I've got a great one from the innards of a magnetron (microwave) but I don't think it would do any good... comments? _________________ jlex.
'70 std. "Elsie"
'88 Carrera |
dembus Samba Member
Joined: February 02, 2005 Posts: 1272 Location: Fleming Island, Florida
Posted: Mon Jan 09, 2012 12:33 pm Post subject: Re: Oil Drain Plate |
vwible wrote: |
Um, theoretically, wouldn't these magnets have the same pull on the upward throws rendering them neutral??
Sorry, I'm calling BS on this one. _________________ "Want a little peace of mind, grab the lowest branch and start to climb"
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy |
vwible Samba Member
Posted: Mon Jan 09, 2012 2:19 pm Post subject: Oil Drain Plate |
I agree with both of you.
1) non-ferrous stuff will still circulate, so the screen would be better. However, the mesh of the screen is too large to catch much of anything except sludge build.
2) It's true BS about the magnetic waves. But I thought to be an interesting concept to toss in! _________________ 1970 Tin Top Walk Through Bus |
PatterBon Samba Engine Connoisseur
Joined: September 27, 2008 Posts: 3446 Location: Copperas Cove, TX
Posted: Mon Jan 09, 2012 2:47 pm Post subject: |
As far as things being farrous and non-farrous, the bearings, though coated, are farrous, as well as the cam and crank. So actually, having a magnet in there isn't too bad of an idea. The only non farrous parts that come to mind is the brass drive gear on the crankshaft that drives the distributor. But if you are getting chunks of metal on your magnet..You'll have more to worry about than just wear. As far as the silverish sludge you're getting on the bottom of the plate, that is bearing material, the coating that's on them. It's pretty normal to see when your engine is first built and also when the bearings start wearing and the crank starts having more play...How I love having worked at a VW shop _________________ PNW Dub Folk & Kitsap dub Folk (KdF)
Austin Aircoolers VW Gang
2020 Ford F-150
1973 Standard Beetle
1969 Cessna 172K Airplane
1959 Karmann Ghia
US Army CH-47 Chinook Helicopter Repairer |
Posted: Mon Jan 09, 2012 2:52 pm Post subject: |
PatterBon wrote: |
As far as things being farrous and non-farrous, |
how about farrah faucet? _________________
Max Welton wrote: |
Fordman49 Samba Member
Really...do you perform oil changes in your car without changing the filter?
It takes all of a few minutes to clean the screen, and even though it mainly grabs sludge and large objects...it's better than nothing. |
Posted: Mon Jan 09, 2012 2:54 pm Post subject: |
Fordman49 wrote: |
beetle's don't have an oil filter.
if there's no sludge, and no large debris, then what's the point?
the risk if your average back-yard hack over-tightening the sump plate bolts and pulling the studs out of the case is far greater than the chances of modern oils sludging, or large chunks of debris being in your engine. _________________
Max Welton wrote: |
cferry7 Samba Member
Joined: February 17, 2011 Posts: 400 Location: S.E. U.S.A
Posted: Mon Jan 09, 2012 4:45 pm Post subject: Re: Oil Drain Plate |
torsionbar wrote: |
vwible wrote: |
How do the magnet's on the fuel lines help MPG ?
IF you are trapping metal shavings with the magnet's in the fuel lines,
what happens to the metal shavings ? _________________ 1st : ' 71 Super , 1641 cc , ~ Stock - a keeper !
2nd: ' 70 Standard , Totaled 7-14-01 , R.I.P. |
Q-Dog Samba Member
Posted: Mon Jan 09, 2012 4:48 pm Post subject: |
torsionbar wrote: |
Fordman49 wrote: |
the risk if your average back-yard hack over-tightening the sump plate bolts and pulling the studs out of the case is far greater than the chances of modern oils sludging, or large chunks of debris being in your engine. |
How do you know whether or not it has sludge if you don't pull the plate off? Just did an oil change on my buggy about an hour ago. Nothing unusual came out the drain plug and the screen was clean, but there was most certainly a thin layer of sludge stuck to the drain plate. There is a lip on the inside of the drain hole that kinda keeps the gunk from going out the drain when you pull the plug. _________________ Brian
'69 Dune Buggy
'70 Beetle |
burdpete Samba Member
Joined: October 24, 2007 Posts: 544 Location: Nebraska
Posted: Mon Jan 09, 2012 4:59 pm Post subject: |
The screen on a VW only protects you from items that would be in your oil after you engine has gernaded itself. Small damaging metal particles will flow through the screen like water through a sieve. Thats why modern vehicle use an oil filter and then on their forums they argue on how small of micron filter they need to protect there engine. _________________ 72 Beetle |
Posted: Mon Jan 09, 2012 5:01 pm Post subject: Drain Plug |
I don't think VW intended for the Lip around the Drain Nut to withhold sludge. I tend to believe it [Lip] was required to have sufficient material in the Drain Plate for Drain Nut threads. _________________ 1st : ' 71 Super , 1641 cc , ~ Stock - a keeper !
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Mon Jan 09, 2012 5:09 pm Post subject: |
torsionbar wrote: |
PatterBon wrote: |
how about farrah faucet? |
Farrah has passed on, but she had really tall n*pples. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Jan 09, 2012 5:38 pm Post subject: |
Cusser wrote: |
torsionbar wrote: |
PatterBon wrote: |
Farrah has passed on, but she had really tall n*pples. |
Yes She Did. And I liked it! _________________ 72 Beetle |
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4589 Location: Central Maryland
Posted: Mon Jan 09, 2012 7:21 pm Post subject: |
I suggest cleaning the screen at every oil change when you get a new beetle. After a few changes you will learn how much crud/sludge accumulates in the engine over 1500-3000 miles.
For me, armed with that info I now only clean the screen every other oil change. _________________ Mike
Sold my sedan
Parts... |
