Oldbug.com Pheasant Plucker
Joined: October 12, 2001 Posts: 1054 Location: Aguanga California
Posted: Mon Jan 09, 2012 8:43 pm Post subject: Early panel hinge covers and seals? |
I'm restoring a 1960 Double Door Panel and it has the metal dealies that go behind the hinges on the cargo doors. If I remember correctly there should be rubber seals that go between the body and this cover...anyone know where to find them or have photos of them that I can see so I can try to make some? _________________ Cheers!
Randy Carlson
http://www.oldbug.com
951-795-1175 |
Clara Samba Member
Posted: Mon Jan 09, 2012 8:54 pm Post subject: |
Ronnie had those seals a while back, hit him up. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Tue Jan 10, 2012 10:36 am Post subject: seals |
Thanks Clara...he says he is out of stock for the next few weeks. Hopefully he can get them. If anyone has a photo though I would love to see it. If it is just flat rubber it would be easy enough to make them. _________________ Cheers!
Randy Carlson
951-795-1175 |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Tue Jan 10, 2012 1:47 pm Post subject: |
Gallery search for cargo and wedge:
Posted: Tue Jan 10, 2012 1:56 pm Post subject: Thanks |
cool...so my memory of them is right...a molded piece. I searched the gallery but not "wedge"...thanks Greg.
Anyone have any decent used ones or should I just wait for Ronnie to get em? (I think I know my answer already...) _________________ Cheers!
Randy Carlson
951-795-1175 |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2357 Location: In the woods, Ontario
Posted: Tue Jan 10, 2012 4:59 pm Post subject: |
What function do those serve? When were they used? |
Posted: Tue Jan 10, 2012 5:14 pm Post subject: why |
Im not sure exactly what years they were used or exactly why...but they fill in the gap between the body and the hinge to make it look a bit cleaner. _________________ Cheers!
Randy Carlson
951-795-1175 |
type241 Samba Member
Joined: June 02, 2006 Posts: 972 Location: MOSES LAKE, WA
Posted: Tue Jan 10, 2012 5:19 pm Post subject: WEDGY |
On a 1960 Bus the forward cargo door hinges(both upper and lower) have a wedge painted to match body with those seals above going underneath. The hinges themselves are countersunk for flathead screw and have a panel nut to secure them.
The million dollar question: What is the wedge function? I have no clue.
I couldn't think of any other progressive refinement that reverted a part/change back to the PRIOR model like the wedge. |
Posted: Tue Jan 10, 2012 5:27 pm Post subject: 60 |
Was it only 1960?
And on all models or just the Panels?
Looking at my hinges it looks like all of them have the countersunk hole front and back...yet I only have the covers for the front...which I guess is correct? _________________ Cheers!
Randy Carlson
951-795-1175 |
Posted: Tue Jan 10, 2012 5:39 pm Post subject: |
1960 only. My 15 Window has them in front only. Vin #581XXX
I also had a 1960 panel and it had them only in front while all four hinges had the countersunk hole |
Posted: Tue Jan 10, 2012 5:46 pm Post subject: |
Hmm...interesting!
Thanks for the info! _________________ Cheers!
Randy Carlson
951-795-1175 |
Posted: Tue Jan 10, 2012 5:50 pm Post subject: |
1960 only is why Ronnie(Splitpile) has a lead on them seals. He was collecting only 1960 Busses wasn't he.
And as far as the rear hinges, at first I thought I was missing the rears then I was educated by Ronnie(I believe) that the hinges could be swapped for a double door bus, so all hinges got the countersunk hole(?).
Funny thing is I haven't even looked at the back hinges on my 15w yet .
Just went and checked my 15w and YES it has the countersunk holes in rear hinges with no evidence of hinge cover wedge. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Jan 10, 2012 6:24 pm Post subject: |
Okay- I'm trying to channel a wee bit o' Lind here. Stay with me. I read a couple decades ago that those wedges were a safety requirement by some European agency in that the hinges stuck out so far- damage to people alongside was eminent. The hinge covers act as meat spoilers, if you will.
I'll accept my licks if that's the most ridiculous thing you ever heard... _________________
EverettB wrote: |
FU#5 |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jan 10, 2012 6:28 pm Post subject: |
We have a walk thru panel camper conversion built DEC59 and only the lower front cargo door hinge has the hole for the cover. Cargo doors look to be original, and have seen a few other panels with same single front lower hinge with mounting hole. _________________ In Stereo, Where Available! |
Posted: Tue Jan 10, 2012 6:31 pm Post subject: |
So Everett is saying all 1960 and 1961 had the wedges. If so, you would think a lot more would of survived. I will definitely look at ALL 1961ish buses from now on that is for sure. |
Aiko Samba Member
