mxracer Samba Member
Posted: Tue Jan 10, 2012 9:01 am Post subject: First run on my re-re-built 1904 for my square.... |
I recently had someone "help" me with a build of a 1904 for my square which turned into a DISASTER. I had to pull it and redo it again myself only after 2000 miles. Some of the aftermath is here... http://www.thesamba.com/vw/forum/viewtopic.php?t=490341&highlight=reuse+existing+rings
I got it all sorted and put back together finally.
Here's a short vid of the first start up for cam burnishing. It did obviously smooth out and run nice. It's back in the car now and I'm going thru the breakin.
I ended up with....
OG AS41 case from a donor square (line bored .020 over)
Gene Berg T3 Full Flow Kit
CB 4140 74mm CW crank (now ground .010-.010 )
Mahle 90.5 pistons and cylinders
Engle W110
Wizemann lifters
SCAT I-beam rods (vw journal, 5.394")
CB 1.25:1 super stock rockers
stock type 3 heads P&P and HD springs
Manton chromoly pushrods
Tri-Mil over the top exhaust
Dell 40mm carbs
Glenn Ring rebuilt 019 distributor
9.1:1 CR
Time will tell if I'm a better "builder" than the hack I had help me.
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Tue Jan 10, 2012 9:26 am Post subject: |
Sounds like a fun motor! _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Jan 10, 2012 9:33 am Post subject: |
Sounds good Dan! Hope this time your motor is gtg for the distance. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2252 Location: hickory,nc
Posted: Tue Jan 10, 2012 11:09 am Post subject: |
happy as shit to hear that thing run again. i think we both know this version is gonna be better than the last. i have no doubt MUCH better. if i can ever get past this damned cold and stupid coughing my head off i gotta get over there and check it out....ken.... _________________ ITMC
Secret Service |
