oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Mon Aug 20, 2018 3:26 pm Post subject: Re: Buggy's With Centerline Rims |
Just wondering if you could put a tube in it. |
oprn Samba Member
joescoolcustoms Samba Member
Posted: Mon Aug 20, 2018 3:41 pm Post subject: Re: Buggy's With Centerline Rims |
Funny this popped back up.
The buggy I am building right now is finally getting those Centerline rims. Over the years, I found some NOS units still in their Centerline boxes. 15 X 8's and 15 X 6's.
And yes, they can take tubes just fine. But watch running low pressures, the tire will pinch the tube and cause it to go flat in a hurry. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
vwjim Samba Member
Joined: November 14, 2003 Posts: 135 Location: Hampshire, UK
Posted: Mon Aug 20, 2018 10:40 pm Post subject: Re: Buggy's With Centerline Rims |
oprn wrote: |
Morning,
I could if the leak was on a rear wheel, as I have larger tyres on the rear. But the front tyres have 135/65-15 and no one makes a tube for a low profile tyre. Not listed here in the UK at least.
One supplier said it needed to be an 80 profile tyre to work.
Another supplier said "I could try their smallest, but it wasn't correct, plus running tubes in tyres not designed for tubes increases the risk of failures"..... So as this is a road vehicle I didn't like the idea of a rapid deflation at 70mph in traffic. |
oprn Samba Member
Posted: Tue Aug 21, 2018 4:18 am Post subject: Re: Buggy's With Centerline Rims |
Ah yes! And your rear rims are wider so you can't just switch them around. |
vwjim Samba Member
Posted: Tue Aug 21, 2018 6:02 am Post subject: Re: Buggy's With Centerline Rims |
Yes, unfortunately that is the case.
One more go, then I'm looking for replacement. |
slalombuggy Samba Member
Posted: Tue Aug 21, 2018 6:09 am Post subject: Re: Buggy's With Centerline Rims |
You can buy tubes made specifically for 135s. I have a pair sitting in my basement. I personally hate such a skinny tire on the street so will never use them.
I ran tubes in radial tires for years after I got a set of big rear tires for cheap that had been vandalized with an ice pick . Like joe said, just keep the pressures up.
brad |
oprn Samba Member
Posted: Tue Aug 21, 2018 5:54 pm Post subject: Re: Buggy's With Centerline Rims |
There are flat fixing liquids that you put in your tire that are supposed to find the leaks and seal them up as you drive. I have never tried any of them to know it they work. |
oprn Samba Member
Posted: Wed Aug 22, 2018 7:10 pm Post subject: Re: Buggy's With Centerline Rims |
oprn wrote: |
I highly recommend using those for an emergency fix, only. They are very corrosive and can in a short period of time, eat through your wheel. If you do use one of those products, have it cleaned out ASAP once you make it to safety. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
oprn Samba Member
Posted: Wed Aug 22, 2018 8:47 pm Post subject: Re: Buggy's With Centerline Rims |
I would have never guessed. It no doubt says so on the can then if it's that bad? |
Posted: Thu Aug 23, 2018 5:47 am Post subject: Re: Buggy's With Centerline Rims |
oprn wrote: |
The propellant, R134a, when combined with water, (second component in fix a flat) turns highly corrosive. Last can I bought to use on my riding lawn mower stated on the can temp fix only. One lazy on my part year later, my two front rims rusted from the inside out.
Search the internet. Lots of photos of alloy rims eaten up from the inside when using fix a flat. Testimonials and warnings from tire manufactures. BMW recommends replacing the tire after using the material do to tire break down from the material.
Would I use it? Heck yes for a temp situation. I carry a can with me in the buggy. But ASAP after getting somewhere to get a proper repair, it would get cleaned out. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Thu Aug 23, 2018 9:37 am Post subject: Re: Buggy's With Centerline Rims |
There is a non corrosive liquid you can put in tires for sealing them up. We used it in ice racing and I pour about a cup in each of my LSR rear tires because they are so thin they leak. It's available at tire shops that do commercial tires. I'm sure if you go in and ask them for some tire sealant snot, they could get you some. it comes in 1 gallon jugs and will last you a lifetime. IT stays liquid and will seal any puncture in the tire.
brad |
oprn Samba Member
Posted: Sat Aug 25, 2018 9:58 pm Post subject: Re: Buggy's With Centerline Rims |
Interesting! I also do not carry a spare on my Buggy. I will have to look into that option. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Aug 26, 2018 7:23 pm Post subject: Re: Buggy's With Centerline Rims |
I ran 155/SR-15 tubes in my Centerlines for years.
They even worked on the 3 1/2 inch wide rims I used. I never had trouble with them in all the miles I put on.
Both sets of front Centerlines I used would not hold air without tubes.
I used them with multiple sized tires.
155/SR-15 tires
165 size tires.
205/70-15 tires and finally
185/60-15 tires.
I now have Weld Draglites on front and don't need tubes with them.
I have the tubes and wide 5 Centerlines sitting in the garage. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
